restman Guest
The variables after the 0x60 RAM address. |
Posted: Tue Nov 27, 2007 6:44 am |
Hi.
I can not use the variables after the 0x60 RAM address on 18f4620. I have a lot of variables above 0x60 number. How can i fix this situation?
Thanks for your helps. |
treitmey
Posted: Tue Nov 27, 2007 8:59 am |
I can.
Code: | #include <18F4620.h>
#fuses hs,wdt32,noprotect,nolvp,put
#use delay(clock=18432000,RESTART_WDT)
#use rs232(baud=19200,xmit=PIN_B3,invert,stream=debug)
#use rs232(xmit=PIN_C6,rcv=PIN_C7,enable=PIN_C5,baud=1200,bits=8,parity=e,errors,stream=CIM)
#case
#zero_ram
int8 var;
#byte var=0x61 //note no semicolin
//====prototype=====//
void init(void);
//========================= Main ====================================//
init();
fprintf(DEBUG,"var=%u\n\r",var);
restart_wdt();
//========================= Functions ==============================//
//=== init ===// setup the initial settings
void init(void){
int8 tmp;
setup_wdt(WDT_ON);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
set_tris_a(0);set_tris_e(0);set_tris_c(0xFF);
set_tris_b(0xFF);
port_b_pullups(TRUE);
fprintf(DEBUG,"START\n\r");
restart_wdt();
Perhaps showing us your code, or giving more info can help us solve your problem. You have a TON of ram on the 18F4620 (??64K flash) If you could only use 0-0x60 we would be in very deep trouble.
Did you mean flash, or sram, or EEPROM? |
restman Guest
Posted: Tue Nov 27, 2007 9:42 am |
I tried this solution but it didn't work.
The compiler allocates the 0x60 data Memory address for the variable but when i use it in my program, the program doesn't work properly. But when i use the variable before the 0x60 adress, it works. i don't know if i miss smth. I suspect indirect addressing mode but i can't figure what the real problem is.
treitmey
Posted: Tue Nov 27, 2007 10:24 am |
Show your program. |
restman Guest
Posted: Tue Nov 27, 2007 12:06 pm |
The program's size is approximately 8kb (program memory) and it's a commercial program. Here is an example:
int8 var1; ---> Data Memory address is 0x59
int8 var2; ---> Data Memory address is 0x60
int8 var3; ---> Data Memory address is 0x61
the program segment is something like:
if(var2 == 5)
When i use var1, the program works properly, but when using var2 or var3 it always skips the if statement and jumps to the else statement. |
treitmey
Posted: Tue Nov 27, 2007 12:28 pm |
So this is just a guess..
I searched the spec for 0x60. I noted that it is used for indexed literal offset addressing mode. Could it be something like that??
tho CCS compiler isn't using the extended instructions as far as I know. |
Posted: Tue Nov 27, 2007 12:36 pm |
As Treitmey says, make sure you don't have 'XINST' in your #fuses
statement. The code will behave in strange ways if you have that fuse. |
Posted: Tue Nov 27, 2007 12:42 pm |
Even better, make sure to set NOXINST on the fuses list. Some compiler versions default to enabling the extended instruction set when the fuse is not specified. |
restman Guest
Posted: Tue Nov 27, 2007 3:59 pm |
It is not important whether i write NOXINST or XINST. The compiler always writes NOXINST in lst file. It doesn't change anything. Thanks everyone for helps. |
Posted: Tue Nov 27, 2007 4:05 pm |
1. Post your compiler version.
2. Can you write a small test program that shows the problem ?
Or does it only occur with a large program ? |
restman Guest
Posted: Wed Nov 28, 2007 4:42 am |
1. CCS PCH C Compiler, Version 4.023
2. This is a very simple example:
#include <18f4620.h>
#fuses NOXINST, HS,NOWDT,NOPROTECT,NOLVP
#byte var1 = 0x60
#byte var2 = 0x5F
main()
set_tris_b(0xFF);
set_tris_d(0x00);
var1 = 0xF1;
var2 = 0x12;
while(true)
output_d(var1);
output_d(var2);
In this example var1 appears at portd but var2 doesn't. |
restman Guest
Posted: Wed Nov 28, 2007 4:43 am |
Very sorry. var2 appears at portd but var1 doesn't. |
Posted: Wed Nov 28, 2007 5:23 am |
Without looking any further, keyword in the post, Version number 4.023.
Look at the "Version 4 comments" thread at the top of the forum.
I'd not bother trying anything else, before getting a latter version than this. The .02x versions, have major problems.
The oldest version I have kept (I threw away the versions before this), is 4.027, and it runs fine on this.
restman Guest
Posted: Wed Nov 28, 2007 6:15 am |
I tried with CCS PCH C Compiler, Version 4.057. But the result is the same. Would you please write here the lst file. I want to compare with mine. |
treitmey
Posted: Wed Nov 28, 2007 10:11 am |
Is there a reason to #byte the variables to a location 60,61,...
This is usually only done to access a special function register,... ie portD
I still think it has got to be about the indirect addressing mode and extended instruction set.
Can you show the list file from sample program?
Code: | CCS PCH C Compiler, Version 3.249, 30995 28-Nov-07 09:23
Filename: C:\ccs\Projects\CRI\jnk.lst
ROM used: 122 bytes (0%)
Largest free fragment is 65414
RAM used: 6 (0%) at main() level
7 (0%) worst case
Stack: 1 locations
00000: GOTO 002A
.................... #include <18f4620.h>
.................... //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
.................... #fuses NOXINST, HS,NOWDT,NOPROTECT,NOLVP
.................... #use delay(clock=20000000)
00004: CLRF FEA
00006: MOVLW 07
00008: MOVWF FE9
0000A: MOVF FEF,W
0000C: BZ 0028
0000E: MOVLW 06
00010: MOVWF 01
00012: CLRF 00
00014: DECFSZ 00,F
00016: BRA 0014
00018: DECFSZ 01,F
0001A: BRA 0012
0001C: MOVLW 7B
0001E: MOVWF 00
00020: DECFSZ 00,F
00022: BRA 0020
00024: DECFSZ FEF,F
00026: BRA 000E
00028: RETLW 00
.................... #byte var1 = 0x60
.................... #byte var2 = 0x5F
.................... main()
0002A: CLRF FF8
0002C: BCF FD0.7
0002E: CLRF FEA
00030: CLRF FE9
00032: MOVF FC1,W
00034: ANDLW C0
00036: IORLW 0F
00038: MOVWF FC1
0003A: MOVLW 07
0003C: MOVWF FB4
.................... set_tris_b(0xFF);
0003E: MOVLW FF
00040: MOVWF F93
.................... set_tris_d(0x00);
00042: MOVLW 00
00044: MOVWF F95
.................... var1 = 0xF1;
00046: MOVLW F1
00048: MOVWF 60
.................... var2 = 0x12;
0004A: MOVLW 12
0004C: MOVWF 5F
.................... while(true)
.................... output_d(var1);
0004E: CLRF F95
00050: MOVFF 60,F8C
.................... delay_ms(1000);
00054: MOVLW 04
00056: MOVWF 06
00058: MOVLW FA
0005A: MOVWF 07
0005C: RCALL 0004
0005E: DECFSZ 06,F
00060: BRA 0058
.................... output_d(var2);
00062: CLRF F95
00064: MOVFF 5F,F8C
00068: MOVLW 04
0006A: MOVWF 06
0006C: MOVLW FA
0006E: MOVWF 07
00070: RCALL 0004
00072: DECFSZ 06,F
00074: BRA 006C
00076: BRA 004E
00078: SLEEP
Configuration Fuses:
Word 1: 0200 HS NOIESO NOFCMEN RESERVED
Word 2: 1E1F BROWNOUT NOWDT BORV21 NOPUT WDT32768
Word 3: 8300 CCP2C1 PBADEN NOLPT1OSC MCLR RESERVED
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST RESERVED
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
