PIC16F690.. trying to code PWM auto shutdown on CCP1
elder
PostPosted: Tue Nov 27, 2007 8:19 pm     Reply with quote
Hi guys, I'm trying to use the PWM feature on pic16f690 where the comparator module can be configured as feedback to shutdown the PWM.
Here is my test code...
-LED toggles as I change the voltage on pin A1 (ie comparator is working)
-The output on the ccp1 pin is 50khz with 50% duty cyc. (ie PWM working)
Problem is the PWM is always on, it doesn't shutdown with the comparator. Is the setup_ccp1() line I'm using the way your meant to set this up?
#include <16F690.h>
#fuses INTRC_IO, NOPROTECT, PUT, NOWDT, NOBROWNOUT
#use delay(clock=8000000)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
void setup_PWM(){
   long dutyVal;
   setup_vref (VREF_LOW | 12);
   setup_comparator(CP1_A1_VR);
   output_low(PIN_C5);    // Set CCP1 output low
   setup_ccp1(CCP_PWM | CCP_SHUTDOWN_ON_COMP1);   // Configure CCP1 as a PWM with shutdown on ccp1
   setup_timer_2(T2_DIV_BY_1, 39, 1);   // Setup for 50khz
   dutyVal = 80;
   set_pwm1_duty(dutyVal);             // 50% duty cycle
//lets try PWM&CCP1 function alone
void main(){
   delay_ms(200);            //start up delay
   output_high(PIN_C0);      //'power' LED ON
   setup_PWM();
   while(1){
      if (C1OUT){
         output_high(PIN_C1);    //toggle LED on comparator change
      }else{
         output_low(PIN_C1);
elder
PostPosted: Tue Nov 27, 2007 9:14 pm     Reply with quote
OK problem solved by doing the register bits myself... heres the change in case anyone comes searching down the track...
I replaced this line from the above code:
with these lines:
#byte ECCPAS  = 0x1D
#byte PWM1CON = 0x1C
setup_ccp1(CCP_PWM);
ECCPAS = 0x10;       //set PWM to shutdown on CCP1
PWM1CON = 0x80;      //set PWM to autorestart after shutdown condition clears.. equivalent of CCP_SHUTDOWN_RESTART I imagine.
