mcp3208 A/D 12 bit problem
jojos
PostPosted: Mon Nov 26, 2007 2:54 am     Reply with quote
Hello. I am using the MCP3208 A/D converter on my project.
The problem that i am facing up is i cant get a correct result from the A/D.
I am using the exact code from the drivers section of ccs compiler.
I have changed the Pin assignment to meet mine.
Generally i sample my inputs every 2 sec (the sampling i generated
from my 2 sec interrupt routine of Timer 1.
Now to test the A/D i sample only one channel. So i give the instruction
"a2dsolar1=read_analog(0)" and the result in a2dsolar1.
I am showing it on my 2x20 lcd screen.On the screen i can see this:
A symbol for the //thousand digit like : ; < and the next 3 digits are
numbers. I have checked the routine that converts the number to my
lcd screen format and it is correct.
Here is my code:
///every 2 sec the interrupt of timer 1 calls getanalog
//in the init i configure the PORTA
//set_tris_a(0b00100010);
init();
adc_init();
loop:
//show a2dsolarvariable
goto loop;
void getanalog(void)
a2dsolar1=read_analog(0);
/////////////////and the mcp3208 code
#ifndef MCP3208_CS
#define MCP3208_CLK  PIN_A0
#define MCP3208_DOUT PIN_A1
#define MCP3208_DIN  PIN_A2
#define MCP3208_CS   PIN_A3
#endif
void adc_init() {
output_high(MCP3208_CS);
delay_ms(1);
void write_adc_byte(BYTE data_byte, BYTE number_of_bits) {
   BYTE i;
   delay_us(2);
   for(i=0; i<number_of_bits; ++i) {
      output_low(MCP3208_CLK);
      if((data_byte & 1)==0)
      output_low(MCP3208_DIN);
      output_high(MCP3208_DIN);
   data_byte=data_byte>>1;
   delay_us(50);
   output_high(MCP3208_CLK);
   delay_us(50);
BYTE read_adc_byte(BYTE number_of_bits) {
   BYTE i,data;
   data=0;
   for(i=0;i<number_of_bits;++i) {
      delay_us(50);
      shift_left(&data,1,input(MCP3208_DOUT));
      delay_us(50);
   return(data);
long int read_analog_mcp(BYTE channel, BYTE mode) {
   int l;
   long int h;
   BYTE ctrl_bits;
   delay_us(200);
   if(mode!=0)
      mode=1;
   output_low(MCP3208_CS);
   if(channel==1)   // Change so MSB of channel #
      ctrl_bits=4;   //      is in LSB place
   else if(channel==3)
      ctrl_bits=6;
   else if(channel==4)
      ctrl_bits=1;
   else if(channel==6)
      ctrl_bits=3;
      ctrl_bits=channel;
   ctrl_bits=ctrl_bits<<1;
   if(mode==1)    // In single mode
      ctrl_bits |= 1;
   else   // In differential mode
      ctrl_bits &= 0xfe;
   ctrl_bits=ctrl_bits<<1;  // Shift so LSB is start bit
   ctrl_bits |= 1;
   write_adc_byte( ctrl_bits, 7);   // Send the control bits
   h=read_adc_byte(8);
   l=read_adc_byte(4)<<4;
   return((h<<8)|l);
long int read_analog( BYTE channel ) // Auto specifies single mode
 return read_analog_mcp( channel, 1);
What could be wrong?
Do i have to do something else to get my data?I just call read_analog
and i wait to return to me some int16 variable. Thank you.
PostPosted: Mon Nov 26, 2007 5:55 pm     Reply with quote
The problem that i am facing up is i cant get a correct result from the A/D. I am using the exact code from the drivers section of ccs compiler.
1. Post the printf() statement that you are using to display the adc value
on your LCD.
2. Post your PIC
3. Post your compiler version.
jojos
PostPosted: Wed Nov 28, 2007 6:58 am     Reply with quote
Ok i found the problem.I had to shift >>4 the result of the read_analog function to get the correct result.Thank you again
