16F88.h
kd5bfm
16F88.h
PostPosted: Sun Nov 25, 2007 9:52 am     Reply with quote
can someone tell me where i can get a copy of 16F88.h include file?? i have searched and i cannot seem to locate it. thanks in advance.
PostPosted: Sun Nov 25, 2007 10:15 am     Reply with quote
Repeat after me:
If the compiler, supports a chip, the include file comes with it. If the compiler doesn't have the include file, then it doesn't support the chip. Adding the file, _won't_ make the compiler support the chip....
kd5bfm
PostPosted: Sun Nov 25, 2007 11:24 am     Reply with quote
Anonymous wrote:
Repeat after me:
Ok well thank you for your input but before you get all high and mighty with your 'Repeat after me' self. take a look at this 1st. i am looking for the header file for the PIC16F884. this is directly from the compiler.
PostPosted: Sun Nov 25, 2007 11:30 am     Reply with quote
1) You asked for the 16F88 file, not the 16F884 file.
2) The list, shows the chips supported by the _current version_. If you update to the current version, the files for these chips are included. Older versions _do not_ include files for latter chips.
3) Your original install disks, will include all the files for the chips that the version you bought supports.
kd5bfm
PostPosted: Sun Nov 25, 2007 12:01 pm     Reply with quote
your right i did say 16F88 originally, however look:
PostPosted: Sun Nov 25, 2007 1:40 pm     Reply with quote
If you truly own the compiler and it's not the limited demo version, then
1. Re-install the compiler and see if the .H files are now present.
2. Email CCS support and explain the problem to them. Be sure to
give them your customer reference number and compiler version.
The Customer Reference number is in this format, xxxx-x-xxxxx,
and you should have received it in an email from CCS when you
bought the compiler.
