I'm currently evaluating the CCS compiler and am testing the serial comms program SIOW V4. Has anyone else experienced the following problems or is there something wrong with my install...
1. A GUI annoyance - If I select /configuration menu/invert bytes or /configuration menu/local echo then pressing the button does have the desired effect on operation. But there is no real way of telling if the button is selected or not (it looks identical in both states).
2. Macros. Macro manager does not seem to work properly, I can type macros in but when I select them they do not run, neither are they saved when I close the program.
3. Saving settings and then reloading them does not seem to work.
Would appreciate any comments on this.
Kind Regards
Dave
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Sun Nov 25, 2007 11:44 am
I just recently submitted item 1 to ccs - haven't tried the others.
