MFK
LCD Display with T6963c and PIC18F4520 |
Posted: Thu Nov 22, 2007 3:19 pm |
Hi ,
i'm using the Software Protoype Board from CCS and the PIC18F4520.
I got a LCD Display from Displaytech 128240A ( Datasheet http://www.displaytech.com.hk/pdf/graphic/128240a%20series-v11.PDF ). The Display has a T6963c Controller onboard.
I use the PCWH Compile Ver. 3.249.
I'm a beginner with Microcontrollers and although with LCD Displays :-(
I have tried to use the Extended GLCD Driver http://www.ccsinfo.com/forum/viewtopic.php?p=88147&sid=d9d0d4b9b5aa8d853cec821fb14fb251 but it didnt't worked until now.
Is it possible for me to use this Driver ? In the Display Datasheet it's said that ther must be Status Check before using the Display. Do I have to add this to the driver, or do I have to make this Status Check in my own Programm ?
The Driver is for 240 x 64 , how can i adjust the resolution ?
At the beginning of the Driver is written " LCD's FS is tied low (FS = 0 is 8x8 font) " is not a connection or ?
I know thats a lot of question for the beginning.
Thanks a lot.
Greetz |
Posted: Fri Nov 23, 2007 1:53 pm |
Quote: |
In the Display Datasheet it's said that there must be Status Check before
make this Status Check in my own Program ? |
The driver already does a status check. Here's the code from the driver:
while (status != 0x03) { // is LCD busy?
LCD.r_bar= 0;
temp = LCD.data;
LCD.r_bar = 1;
status = temp & 0x03;
Quote: | The Driver is for 240 x 64 , how can i adjust the resolution ? |
The driver has this comment at the beginning:
Quote: |
* Works with all resolutions (240x128, 240x64, 128x128),
use glcd_init(240,128); |
This implies that you should call the glcd_init() function with parameters
of 240 and 128, no matter what the actual resolution of your LCD.
(FS = 0 is 8x8 font) " is not a connection or ? |
Yes, the FS signal is on pin 19 of the LCD. Look on page 22 of the LCD
data sheet to see this. You should connect it to Ground. |
MFK
Posted: Sun Nov 25, 2007 9:53 am |
Thanks a lot.
Thats really helps me. Unfortunately i cannot test it at the weekend, but i will do on Monday and i hope it works. |
MFK
Posted: Mon Nov 26, 2007 7:02 am |
Hi
it nearly seems to working but just nearly.
I tried the example programm
#include <18F452.h>
//#device *=16
//#device adc=10
#use delay(clock=4000000)//,RESTART_WDT)
#use rs232(baud=9600, xmit=PIN_A2,rcv=PIN_A3)
#fuses XT, BROWNOUT, BORV27, PUT, STVREN, NOLVP
#include <T6963C.c>
int n;
int8 bt_logo[11] = { //8x11 picture
0b00010000, // XX
0b00011000, // XXXX
0b00010100, // XX XX
0b01010010, // XX XX XX
0b00110100, // XXXX XX
0b00011000, // XXXX
0b00011000, // XXXX
0b00010000 // XX
glcd_init(240,128);
glcd_WriteByte(1, (LCDModeSet|LCDMode_XOR));
glcd_WriteByte(1, (LCDDispMode|LCDDisp_TXT|LCDDisp_GRH));
glcd_gotoxy(3,0,1); // 1 = text area of memory; note that there are only
// 8 rows of text possible
glcd_putc("Hi there.");
glcd_line(30,6,200,50,1);
glcd_line(3,6,20,50,1);
glcd_line(100,40,210,20,1);
glcd_box(14,14,100,60,1);
glcd_box(60,30,100,60,0);
glcd_square(20,12,180,50,1);
glcd_image8(&bt_logo[0],212,40,8,11);
glcd_image8(&bt_logo[0],216,40,8,11);
glcd_line(30,6,200,100,1);
glcd_square(2,32,130,113,1);
glcd_image8(&bt_logo[0],26,110,8,11);
but when i run it i just only see some stripes runnig over my display for maybe two seconds and than it stops at the end.
I can see at the PCW Debugger " Ready MCU at 1 MHZ " . Can someone please give me a hint what the problem could be.
Somestimes the programm just get only stucked in one of these while loops.
void glcd_WriteByte(int1 cd, int data)
int status = 0, temp = 0;
set_tris_lcd(0xff);
LCD.w_bar = 1;
LCD.r_bar= 1;
LCD.cd = 1;//defaults
LCD.r_bar= 0;
temp = LCD.data;
LCD.r_bar = 1;
set_tris_lcd(0x00); // All outputs
LCD.cd = cd; // Command/Data bar
LCD.data = data;
LCD.r_bar = 1; // not read
LCD.w_bar = 0; // write
LCD.w_bar = 1; // release
void glcd_WriteByteAuto(int data)
int status = 0, temp = 0; // status bits ARE DIFFERENT BITS THAN NORMAL
set_tris_lcd(0xff);
LCD.w_bar = 1;
LCD.r_bar = 1;
LCD.cd = 1; // defaults
while (status != 0x08) { // is LCD busy?
LCD.r_bar = 0;
temp = LCD.data;
LCD.r_bar = 1;
status = temp & 0x08;
LCD.cd = 0; // This is always data, cd=0
LCD.data = data; // Put data on data bus
How can i check if my display is really busy ?
The last question , i don't really understand this command.
" #byte LCD = 0xf82 // portC address on 18F452 " ? Im using the PIC 18F4520, shouldnt make a difference , or ?
Thanks a lot. |
treitmey
Posted: Mon Nov 26, 2007 9:41 am |
Quote: | The last question , i don't really understand this command.
This overlays the int8 variable know as LCD onto the chip at address 0xF82
And at 0xF82 is port C for the 18F4520.
http://ww1.microchip.com/downloads/en/DeviceDoc/39631d.pdf
page 65 or 63.
So if you read from LCD you are really reading port C
ie: mynewvar=LCD;
and if you write to it you are writing to port C
ie: LCD=0x02;
But the tris must be set for this to work.
btw I would first try simple text in the text area. Save the bit map stuff for when you have read and write working. |
MFK
Posted: Tue Nov 27, 2007 9:03 am |
Hi ,
i tried it again today , with no success at the beginning. Than i made the bt sample again and it works fine. Maybe just only a connection was wrong yesterday.
Thanks a lot for the support. I will surely write again :-)
greetz |
Izzy
Character problem |
Posted: Thu Jan 01, 2009 1:49 pm |
I am using T6962C graphics driver for my project that uses 24064A LCD from "crystalfontz.com". However I have been encountering this one small problem and I am not sure whats wrong with it.
When ever I print something using glcd_putc(); it prints one extra random character on the screen at the end, like 50% of the time.
For eg. If I try to print
glcd_gotoxy(6,0,1);
glcd_putc(" G-Force");
Then it will print:
G-ForceĆ
I am not sure why some random character are appearing at the end of the word. I would really appreciate if anyone could shed some light.
I am using CCS compiler, PIC18f4685 (40Mhz).
Thanks in advance
Izzy |
Izzy
Posted: Thu Jan 01, 2009 2:53 pm |
Also, one more question,
What do I need to change in the driver code to use 6x8 font?
I have made couple of changes, but the graphics shifted along with the text.
const int8 TextArea =0x0028;
const int8 GraphicsArea = 0x0028;
TextHome = (res_x/6)*res_y; //0x0F00;//0x0780;
Code: | // 240 x 64 in the 8x8 font mode means that 30 characters across by
// 8 rows of characters may be displayed
#define set_tris_lcd(x) set_tris_d(x)
#define LCDColorBlack 0b1
#define LCDColorWhite 0b0
//TRIS DataBus=x, note:control bus (PORTC) always outputs
unsigned int16 TextHome = 0x0F00;//0x0780;
const int8 TextArea =0x0028; // how many bytes before a new line // 0x28 = 40
const int16 GraphicsHome = 0x0000;
const int8 GraphicsArea = 0x0028; // how many bytes before a new line
const int8 AutoModeWrite = 0xB0;
const int8 AutoModeRead = 0xB1;
const int8 AutoModeReset = 0xB2;
const int8 LCDModeSet = 0x80; // send this OR'd with the following
const int8 LCDMode_OR = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0011;
const int8 LCDMode_TA = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr = 0x21; // cursor address
const int8 LCDSetCursorSize = 0xA0; // 1 line cursor
const int8 LCDDispMode = 0x90; // send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
const int8 LCDBitSet = 0xF8;
const int8 LCDBitReset = 0xF0;
const int8 LCDBit0 = 0b000;
const int8 LCDBit1 = 0b001;
const int8 LCDBit2 = 0b010;
const int8 LCDBit3 = 0b011;
const int8 LCDBit4 = 0b100;
const int8 LCDBit5 = 0b101;
const int8 LCDBit6 = 0b110;
const int8 LCDBit7 = 0b111;
const int8 LCDSetPtr = 0xE0;
struct lcd_pin_def
BOOLEAN unused1; // C0
BOOLEAN unused2; // C1
BOOLEAN unused3; // C2
BOOLEAN unused4; // C3
BOOLEAN w_bar; // C4 Write bar active low
BOOLEAN r_bar; // C5 Read bar active low
BOOLEAN cd; // C6 Command/Data BAR 1=command 0=data
BOOLEAN reset_bar; // C7 Reset active low
int data : 8; // PortD=Data bus
struct lcd_pin_def LCD;
#inline
void glcd_init(unsigned int16 res_x, unsigned int16 res_y) {
int16 counter;
set_tris_c(0x00); // graphic lcd control lines all output
set_tris_lcd(0xff); //TRIS DATA bus,note:control bus always outputs
LCD.w_bar = 1; // INITIAL STATES OF CONTROL PINS
LCD.r_bar = 1; //
LCD.cd = 1; // command
LCD.reset_bar = 0; // perform a reset
delay_us(10); // delay for a reset
LCD.reset_bar = 1; // run
// Set up the graphics and text areas
glcd_WriteCmd2(TextHome, 0x40);
glcd_WriteCmd2(TextArea, 0x41);
glcd_WriteCmd2(GraphicsHome, 0x42);
glcd_WriteCmd2(GraphicsArea, 0x43);
// set address to 0
// glcd_WriteCmd2(0x0000, 0x24);
// Clear all RAM of LCD (8k)
glcd_WriteByte(1, AutoModeWrite);
for (counter = 0; counter < 0x1fff; counter++)
glcd_WriteByteAuto(0); // fill everything with zeros
glcd_WriteByte(1, AutoModeReset);
} | [/code] |
Posted: Thu Jan 01, 2009 3:20 pm |
There are several T6963C drivers out there. Post a link to the source
code for it. Also post the name of the person who wrote it. That will
help to identify exactly which one you are using. |
Izzy
Posted: Thu Jan 01, 2009 3:42 pm |
From his driver:
Quote: | void glcd_gotoxy(int x, int y, int1 text) {
// sets memory location to screen location x, y
// location 1,1 is upper left corner; text = 1 (text area), text = 0 (graphics area) |
The description says the origin is at (1,1) but you are using 0-based
coordinates in your code below:
Quote: | glcd_gotoxy(6,0,1); |
Change the y-coord to 1. |
Posted: Thu Jan 01, 2009 4:01 pm |
If I use
glcd_gotoxy(6,1,1);
then the text will appear in second line.
Probably (0,0) was supposed to be the top left hand corner. |
Posted: Thu Jan 01, 2009 4:04 pm |
Post your compiler version. |
Izzy
Posted: Thu Jan 01, 2009 4:11 pm |
Compiler version: 4.013 |
Posted: Thu Jan 01, 2009 4:22 pm |
That's what I thought. You probably have this problem here:
https://www.ccsinfo.com/forum/viewtopic.php?t=24661&start=74
One possible work-around would be to change the glcd_putc() routine
so it only accepts printable characters. Example:
Changes are shown in bold below:
Quote: | void glcd_putc(char c) {
if(c >= 0x20)
glcd_WriteCmd1(c - 0x20, 0xc0);
Try that. See if it fixes the problem. |
