Question about glcd_text57 routine
The Puma
PostPosted: Fri Nov 23, 2007 1:23 pm     Reply with quote
I want do the following, but this did't work, why???
char info_text[];
glcd_text57(20,25,sprintf(info_text,"%04.3fv  %4LU Value",volts,adc_value),2,ON)
The following works.
Is there a method to get it to work??
sprintf(info_text,"%04.3fv  %4LU Value",volts,adc_value);
      glcd_text57(20,25,info_text,2,ON);
PostPosted: Fri Nov 23, 2007 1:34 pm     Reply with quote
Look at the function definition for glcd_text57() in the GLCD.c file.
What does it expect as the 3rd parameter ?
void glcd_text57(int x, int y, char* textptr, int size, int1 color)
Look at the function definition for sprintf() in the CCS manual.
What does it return ?
SPRINTF( )
Syntax: sprintf(string, cstring, values...);
Parameters: string is an array of characters.
cstring is a constant string or an array of characters null terminated.
Values are a list of variables separated by commas.
Returns: Nothing
The Puma
PostPosted: Fri Nov 23, 2007 2:30 pm     Reply with quote
Ok, thats is clear.
Is there another way to do that? (return a string to glcd_text57)
Like the charaterlcd method with lcd_putc or so?
Dimlow
PostPosted: Sat Nov 24, 2007 3:22 am     Reply with quote
Yes, there is another way . i redirect the output of printf with your own putc routine. here is the code i use.
#ifndef GLCD_PUTC_FOR_PRINTF
#define GLCD_PUTC_FOR_PRINTF
#define GLCD_PUTC_LCD_WIDTH 128
#define GLCD_PUTC_LCD_HEIGHT 64
#define GLCD_PUTC_CHARWIDTH 5+1
#define GLCD_PUTC_CHARHEIGHT 7+1
int glcd_putc_x=0,glcd_putc_y=0;
char glcd_putc_text[2]=" ";
void glcd_putc (char c)
   switch(c)
      case '\n' : {
                  glcd_putc_x=0;
                  glcd_putc_y+=GLCD_PUTC_CHARHEIGHT;
      default   : {
                  *glcd_putc_text=c;
                  glcd_text57(glcd_putc_x,glcd_putc_y,glcd_putc_text,1,1);
                  glcd_putc_x+=GLCD_PUTC_CHARWIDTH;
   if(glcd_putc_x>=GLCD_PUTC_LCD_WIDTH-GLCD_PUTC_CHARWIDTH) {glcd_putc_x=0;glcd_putc_y+=GLCD_PUTC_CHARHEIGHT;}
   if(glcd_putc_y>=GLCD_PUTC_LCD_HEIGHT) glcd_putc_y=0;
#endif
use it like this
 printf(glcd_putc,"Hello World");
it does not handle many control character, you will have to code that yourself
Hope that helps
Gary[/code]
The Puma
PostPosted: Sat Nov 24, 2007 3:29 am     Reply with quote
Ok, thanks i will try
The glcd_text57 did not clear unused pixels
Then you must always clear area when updated value comes,
this gives flickering
Is it possible to change the glcd_text57 routine to do that
maybe someone has already change it
void main() {
   long int adc_value;
   float volts;
   char text[];
   setup_adc_ports(AN0|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_20);
   set_adc_channel(0);
   glcd_init(ON);
   sprintf(text,"PIC18 10-bits ADC Sampling Ch AN0:");
   glcd_text57(5,10,text,1,ON);
   while(TRUE) {
      adc_value=read_adc();
      volts=(float)(adc_value*5)/1023.0;
      sprintf(text,"%04.3fv   %4LU Value",volts,adc_value);
      glcd_text57(5,50,text,2,ON);
The code sprintf(text,"%04.3fv %4LU Value",volts,adc_value) overwrite only the new values (volts and adv_value) and is unreadeble
Is there an solution?
Dimlow
PostPosted: Sat Nov 24, 2007 3:39 am     Reply with quote
Well i wrote that routine last week so i don't think anyone has already done it with my code. But I'm sure if you work hard enough at it you can do it.
If you get stuck i will help out. As I'm sure i will useone day.
Gary
Dimlow
PostPosted: Sat Nov 24, 2007 3:43 am     Reply with quote
what you will have to do is store that old values, then when you come to print the new one , erase the old value with glcd_text57(5,50,text,2,OFF); then print the new values, etc.
Gary
The Puma
PostPosted: Sat Nov 24, 2007 4:00 am     Reply with quote
I change it to this
      delay_ms(1);
But this overwrite the new values
Dimlow
PostPosted: Sat Nov 24, 2007 4:13 am     Reply with quote
try something like this
      sprintf(text,"%04.3fv   %4LU Value",old_volts,old_adc_value);
      old_volts=volts;old_adc_value=adc_value;
Gary
The Puma
PostPosted: Sat Nov 24, 2007 6:24 am     Reply with quote
This works
Dimlow
PostPosted: Sat Nov 24, 2007 7:05 am     Reply with quote
Yep will do, i was assuming you would reuse the text variable for other texts.
Gary
MegatroniC
View user's profile Send private message ICQ Number
PostPosted: Thu Mar 15, 2012 8:40 am     Reply with quote
Hello
excuse me, that lift so old topic ...
My test code, pic18f4620 and TG12864D0 (KS0108):
void main() {
    long int adc_value, old_adc_value;
    float volts;
    char text[20];
    char time[9];
    setup_adc_ports(AN0);
    setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_16);
    set_adc_channel(0);
    porta=0;
    trisa=0x3F;
    glcd_init(ON);
    delay_ms(200);
    sprintf(text,"Voltage:  ACD:");
    glcd_text57(0,10,text,1,ON);
    sprintf(text,"Time is:");
    glcd_text57(0,30,text,1,ON);
    while(TRUE) {
       if(adc_value != old_adc_value){
           glcd_text57(0,20,text,1,OFF);
           sprintf(text,"%04.3fv   %4LU units",volts,adc_value);
           glcd_text57(0,20,text,1,ON);
      ds1307_get_time(hrs,min,sec);
       if(sec != old_sec){
           old_sec=sec;
           glcd_text57(0,40,time,1,OFF);
           sprintf(time,"%02d:%02d:%02d" hrs,min,sec);
           glcd_text57(0,40,time,1,ON);
When change the time value does not flicker, this code works perfectly.
But when changing the voltage, value on the display flickers.
How to prevent this flickering?
