PIC is not working, sometimes working...
Goto page 1, 2  Next
denkid
PostPosted: Wed Nov 21, 2007 11:14 am     Reply with quote
Hello.
Thank you for reading.
My country is not use english.
So, My english might be very poor, sorry.
I made many Target Board using PIC18F6520
but, 10% is right.
left 90% is not working.
I think it is problem of OSC.
But it is just my thinking.
I am gonna show the pcb picture
I use paste when I solder this pcb myself.
And, I attached 8 LEDs
Sometimes, 2 LEDs is same working on following codes
   porte++;
as you know, Every led should different flicking.
So I think, 18F6520 has many pin it is so close.
Is the Solder Paste problem?
Can I hear your opinion..?
Thankyou..
Best Regards
PostPosted: Wed Nov 21, 2007 11:24 am     Reply with quote
From what you show, the oscillator should not be a problem. What the picture is not quite large enough to show, is the decoupling on the Vss line (hopefully the parts on the edge of the picture a decoupling capacitors).
On the oscillator, what is the crystal, make, type, frequency?.
What is not working?.
How is the supply generated?.
You have a very large number of 'NC' pins. Are you programming these as outputs on bootup?. If not, some 'odd' effects can result.
PostPosted: Wed Nov 21, 2007 12:24 pm     Reply with quote
Your ground connections are not very good. Each Vss pin should have
a very short trace that goes to its own via, which goes to the ground
plane. The Vdd connections should also be kept short, and each Vdd
pad should have its own 0603 capacitor (100 nF) to ground.
However, I don't think your layout is so bad that it will cause 90% of
the boards to fail. They should still work.
1. Post the schematic of your MCLR circuit.
2. Post your #fuses statement and #use delay() statements.
3. Post your compiler version.
denkid
Thankyou
PostPosted: Wed Nov 21, 2007 12:39 pm     Reply with quote
Thankyou for your answer.
I posted the picture of schematic
Thankyou
SET
PostPosted: Wed Nov 21, 2007 12:45 pm     Reply with quote
MCLR has 10k pullup which should be fine. The grounds are bad, also the supply decouplers (which you can just see one end of) must ground even further away - whether this is bad enough to cause malfunction or not I'm not sure.
PostPosted: Wed Nov 21, 2007 12:52 pm     Reply with quote
Please post these things:
denkid
Addition
PostPosted: Wed Nov 21, 2007 1:27 pm     Reply with quote
1. fuses configuration
Oscillator : HS
Osc.Switch Enable : Enabled
Power up Timer : Disabled
Brown out Detect : Disabled
Brown out Voltage : 2.5V
Watch Dog Timer : Disabled - Controlled by SWDTEN bit
Watch Dog Postscaler : 1: 128
CCP2 MUX : RC1
Stack OverFlow reset : Enabled
Low Voltage program : Disabled
Any Code Protect is Disabled
8Mhz OSC is used.
#use delay(clock=8000000)
I use ICD2 Programmer
2. Compiler version : 3.249
FULL SOURCE
#include <18f6520.h>
#byte porte=0x0f84
#zero_ram
   set_tris_e(0x00);
      porte++;
Thankyou so much
Humberto
PostPosted: Wed Nov 21, 2007 1:40 pm     Reply with quote
If you are using the ICD2 Programmer, you can´t attach the MCLR pin to +5V directly,
it must be done through a 47K resistor.
Humberto
denkid
The Grounds
right side of Vdd and Vss pins are near the OSC
The pins is this.
Vss
OSC1
OSC2
Vdd
So, How can I connect Vdd and Vss Shortly.
Because, It is placed with OSC1,2 very near
As you can see the PCB figure.
I think, if The Vss, Vdd should be shortly then the OSC parts must be placed bottom layer.
Thankyou so much
SherpaDoug
PostPosted: Wed Nov 21, 2007 4:17 pm     Reply with quote
I don't like the grounding of the upper 22pF cap on the crystal. It connects to ground plane, but how does that ground plane connect to the GND of the PIC? That whole loop from PIC pin through the cap and back to the PIC should be very short. I would like to see both caps grounded to a point between them.
PostPosted: Wed Nov 21, 2007 4:41 pm     Reply with quote
Try the program shown below. Your program is doing read-modify-write
operations directly on the Port E pins. The program below will do it
to the Latch register. This prevents any possible RMW problems.
Also, you are manually setting the Config bits in MPLAB, which could
easily allow some mistake to be made. The program below embeds
the fuse settings in the program. That's much better.
#include <18F6520.h>
#fuses HS,NOWDT,NOBROWNOUT,PUT,NOLVP
int8 value;
value = 0;
   output_e(value);
   value++;
denkid
Thankyou so much
PostPosted: Wed Nov 21, 2007 11:48 pm     Reply with quote
Thank you so much.
I got much information from you.
Thank you
denkid
I modified my pcb.
PostPosted: Thu Nov 22, 2007 12:35 am     Reply with quote
[img] http://www.mindcolor.com/pcb3.jpg [/img]
Thank you for your help
I have modifed my pcb following your opinion.
(please click upper link to see the figure of pcb)
Please watch my pcb, again.
Have I still problem?
And, some Target Board seems to be right for moment.
but, The Target Board will be broken soon,
LED is very strange working.
I can not asume that working
Thankyou so much
Best regard.
Wayne_
PostPosted: Thu Nov 22, 2007 8:17 am     Reply with quote
You say 10% of boards are working and 90% not ?
How many boards have you made ?
As some boards work and others not answer the following:-
do the boards that work ALWAYS work ?
If YES then it is most likely a fault in the assembly of the boards, either bad soldering or faulty components etc.
If the good boards also fail then it may be a design fault.
Wayne
Humberto
PostPosted: Thu Nov 22, 2007 9:37 am     Reply with quote
It is evident that there are many doubts from different problems, even in the title
"PIC is not working, sometimes working..."
According to the info posted in this thread, I guess that the poster is still in a learning
stage, trying to know:
1) How to draw electrical schematic with a PCB design tool
2) How to draw the lay out using the same PCB design tool
3) How to handle an array of LEDs using an MCU
4) How to write C code to handle such LEDs
5) How to make the project using an oversized and complex MCU
6) How to make the project using a 2 face PCB plenty of through holes
7) How to be proficient soldering SMD at once.
8) How to make a pile of co$tly PCB´s and that once mounted and programmed all
the set of components, it works successful in the first attempt
In my opinion, this is not the way.
The key is to get all the improvements step-by-step, not all together.
To get the needed skill level to solve all the proposed tasks in the first attempt, first
you must burn a lot of MCU and PCB to gain experience.
My $0,02.
Humberto
PD: A famous Argentine boxer defined the experience like:
"a comb that gives the life when one have lost the hairs".
Goto page 1, 2  Next
Page 1 of 2
