problem with TELIT GE864 GPRS modem and PPP library
azuolas
PostPosted: Tue Nov 20, 2007 5:46 am     Reply with quote
hello
I am trying to connect TELIT GE864 GPRS modem to PIC18F4620 by using CCS PPP library. After I send command to dial up, modem returns CONNECT, but PPP session does not start. It might happen because TELIT modem does not start PPP session by itself. Have anybody tried to connect GPRS modem by using CCS libraries?
Any ideas what should I do?
andreasx
PostPosted: Tue Nov 20, 2007 2:31 pm     Reply with quote
Just use the easy GPRS feature of the telit modul. It takes not more then 8 strings to connect to the internet.
best regards
Andreas
azuolas
PostPosted: Wed Nov 21, 2007 1:38 am     Reply with quote
Thank you for your advice. I tried this feature, but in my project I must use more than one socket (multi connection). With easy GPRS feature it takes much time to switch from one socket to other. It does not meet the requirement of project.
azuolas
PostPosted: Wed Dec 12, 2007 1:31 am     Reply with quote
Does this silence mean that nobody ever tried this library?
