PIC18F1320 and digital I/O pin config
rina_1220
PostPosted: Mon Nov 19, 2007 8:08 am     Reply with quote
Hey all. I need some help with port_b configuration for pic18f1320.
I have set a small routine to test if my program is working fine and I have a problem with pins B0, B1 and B4.
My routine would light on and off a led on pin_B0 and pin_B3.
I've noticed pin_B3 works fine, but not pin_B0.
I have already set LATB=0 and ADCON1=0x70, as its told in the datasheet, because of the digital/analog i/o configuration of these pins, but it still ain't working.
Is there anything I'm missing?
here my code
#include <18f1320.h>
#fuses   INTRC_IO, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOLVP
#FUSES NOMCLR
#use rs232(baud=9600, bits=8, parity=N, xmit=PIN_B1, rcv=PIN_B4)
#byte port_b=6
#byte OSCCON=0xFD3
#byte LATB=0xF8A
#byte ADCON1=0xFC1
   OSCCON=0b01100010;   //4MHz
   port_b = 0;
   set_tris_b(0);   //Initialize data direction. (Set = input; reset = output)
   LATB = 0;    //Alternate method to clear output data latches
   ADCON1 = 112;//0x70;   //Set RB0 (AN4), RB1 (AN5), RB4 (AN6) as digital I/O pins
   port_b = 0;
      output_high(PIN_B0);
      output_low(PIN_B3);
      output_low(PIN_B0);
      output_high(PIN_B3);
return;
PostPosted: Mon Nov 19, 2007 11:13 am     Reply with quote
#byte port_b=6
#byte OSCCON=0xFD3
#byte LATB=0xF8A
#byte ADCON1=0xFC1
Download the 18F1320 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39605F.pdf
Look in this section:
5.9.2 SPECIAL FUNCTION REGISTERS
What should be fixed with the line shown in bold above ?
rina_1220
PostPosted: Mon Nov 19, 2007 3:50 pm     Reply with quote
#byte port_b=0xF81
#byte OSCCON=0xFD3
#byte LATB=0xF8A
#byte ADCON1=0xFC1
right?
But tell me. Do you know why the other LED on pin_B3 worked fine and just B0 didn't?
thanks a lot
PostPosted: Mon Nov 19, 2007 4:28 pm     Reply with quote
Do you know for certain if the LED on Pin B0 is a good LED ?
Describe the circuit on Pin B0. Do you have a series resistor between
pin B0 and the LED ? What is the value of the resistor ?
rina_1220
PostPosted: Mon Nov 19, 2007 6:59 pm     Reply with quote
yeah. I have one 330ohm resistor between the led and the port. And I had 2 different leds tested on both ports. they only work on pin b3.
another thing is that if I connect pin b0 to an osciloscope it'll show its working fine (output goes from 0 to 5).
PostPosted: Mon Nov 19, 2007 7:04 pm     Reply with quote
The LED has probably been installed backwards.
LEDs are polarized. One pin is the cathode and the other pin is the
anode. They must be installed correctly.
rina_1220
PostPosted: Mon Nov 19, 2007 7:42 pm     Reply with quote
I am going to check that again when I get the chance.
Thank you again Smile
The led on pin b0 was not grounded. that was the problem.
