Hello all CCS fans,
is the expression "weak pull-up" the same as "internal pull-up" resistors of the portB? Otherwise, can anyone explain it to me, please?
cheers, meereck
Posted: Mon Nov 19, 2007 4:19 pm
Yes, here is a statement from the 16F877 data sheet:
PORTB is a bi-directional I/O port. PORTB can be software
programmed for internal weak pull-up on all inputs.
