joven
Joined: 30 Jan 2007 Posts: 56 Location: Viana do Castelo - Portugal
I2C Slave |
Posted: Sun Oct 21, 2007 11:39 am |
Hi
I'm trying work with i2c slave for my school project.
I have 18F4685 in software master and 18F2550 in hardware slave.
First i'm trying with ex_Slave from CCS.
When the master tell the slave to write the slave the led turn on.
When the master tell the slave to read the slave don't turn on.
Master:
#include "pic18.h"
#use i2c(Master, sda=PIN_D7, scl=PIN_D6)
#include <pcf8833.c>
int8 data;
char escreve[30];
TRISD=0b00000000;
TRISB=0b01111110;
PORTB_RB0=1;
glcd_init(65);
glcd_cls(WHITE);
sprintf(escreve,"ola");
glcd_text57(5, 3, escreve, 1, BLACK, WHITE);
// Write the letter 'B' to the slave board.
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_write('B');
sprintf(escreve,"escreveu");
glcd_text57(5, 20, escreve, 1, BLACK, WHITE);
// Read from the slave board and display the data.
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_start();
i2c_write(0xa1);
data = i2c_read(0);
i2c_stop();
sprintf(escreve,"%c",data);
glcd_text57(5, 40, escreve, 1, BLACK, WHITE);
Slave:
#use i2c(SLAVE, SDA=PIN_B0, SCL=PIN_B1, address=0xa0, FORCE_HW)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
BYTE incoming, state;
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
RB7=1;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
RB6=1;
void main ()
enable_interrupts(INT_SSP);
TRISB=0b00111111;
RB7=0;
RB6=0;
while (TRUE) {}
The leds is RB6 and RB7
What I make wrong.
Thanks |
Posted: Sun Oct 21, 2007 1:11 pm |
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
You need a 'stop' statement. It's missing from your code. Add the
line shown in bold above.
Also, you don't really need to put in TRIS statements, and you don't
need to write directly to bits to turn on the LEDs. If you use
"Standard i/o" mode and also use the CCS pin i/o functions, then the
compiler will setup the TRIS for you. "Standard i/o" mode is the
default mode of the compiler. You don't need to specify it.
Just use CCS functions, such as:
Code: | output_high(PIN_B6);
output_low(PIN_B6);
output_high(PIN_B7);
output_low(PIN_B7);
Make sure you have pull-up resistors on SDA and SCL, and a ground
connection between the two PIC boards. You can use 4.7K ohms for
the pull-up resistors. |
joven
Posted: Sun Oct 21, 2007 1:44 pm |
hi
I've put the "i2c_stop();" continue not working.
The two pics are in the same circuit. |
Posted: Sun Oct 21, 2007 1:53 pm |
1. Post your compiler version.
2. Post the #include, #fuses, and #use delay() statements for both
the Master and Slave programs.
3. Post the statements which declare 'RB6' and 'RB7'. |
joven
Posted: Sun Oct 21, 2007 2:36 pm |
The compiler version is 4.049
#BYTE PORTB=0xF81
#BIT RB7=PORTB.7
#BIT RB6=PORTB.6
Master:
#include <18F4685.h>
#device adc=8
#FUSES HS
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES BBSIZ1K //1K words Boot Block size
#include "pic18.h"
//See the program below which shows some corrections for your code.
//The following program works OK with EX_SLAVE.C
int8 data;
char escreve[30];
TRISD=0b00000000;
TRISB=0b01111110;
PORTB_RB0=1;
glcd_init(65);
glcd_cls(WHITE);
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_start();
i2c_write(0xa1);
data = i2c_read(0);
i2c_stop();
Slave:
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN,WRTB,MCLR,NOCPD,NOWRTC
#use delay(clock=48000000)// full speed USB device
// START OF bootloader definition
#define LOADER_END 0x7FF
#define LOADER_SIZE 0x6FF
#build(reset=LOADER_END+1, interrupt=LOADER_END+9)
#org 0, LOADER_END {} // nothing will replace the bootloader memory space
// END OF bootloader definition
#include "picram18Fx550.h"
#INT_SSP
address = incoming;
RB7=1;
RB6=1;
void main ()
TRISB=0b00111111;
RB7=0;
RB6=0;
while (TRUE)
joven
Posted: Tue Oct 23, 2007 12:08 pm |
can be not working because of fuses? |
robotam
Posted: Mon Nov 19, 2007 9:53 am |
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_start();
i2c_write(0xa1);
data = i2c_read(0);
i2c_stop();
I dont understand why i2c_write(0xa1); what this value 0xa1 means? |
joven
Posted: Mon Nov 19, 2007 2:53 pm |
is the mode you read/write, can easly find a example on I2C eeprom |
kender
Posted: Fri Jan 11, 2008 6:09 pm |
robotam wrote: | I dont understand why i2c_write(0xa1); what this value 0xa1 means? |
0xA1 = 0xA0 | 0x01, where 0xA0 is the I2C address of the slave defined in the #use i2c(slave, ... , address=0xA0), and 0x01 is a R/W# bit. _________________ Read the label, before opening a can of worms. |
