Glcd doesnt work!
Gu
Glcd doesnt work!
PostPosted: Sat Nov 17, 2007 8:23 am     Reply with quote
I´m using a PIC16F877A to controll the tech 12864, a 128x64 glcd.
I can set the display contrast very well and the pic is working fine. I have a flat cable connecting the GLCD to board. Bu the displays seems not to work!!
I could see in an oscilloscope that the bits are going right withou the connection to the GLCD. When I plug the cable in the GLCD, my DATA bus get stuck to "zero".
By the way, i dont use the PORT D for the Data bus, I have de data bus splitted in ports B and C.
I made a simulation of my program at Proteus and it´s working fine.
Evem a simple code doesnt make the display to wotk!!
Can anyone help me please???
chrisaljar
PostPosted: Sun Nov 18, 2007 3:32 pm     Reply with quote
hello gu
post your code dude,
chris
Gu
PostPosted: Mon Nov 19, 2007 12:15 pm     Reply with quote
Hi, Chris
My code is way too long, so I´m posting here only the part I've changed to work with my data bus. I have de data0-4 in port B (B3-B7) and data5-7 in port C (C0-C2).
Mostly, I used the GLCD.h and changed as I wanted...
#ifndef GLCD_CS1
#define GLCD_CS1     PIN_C3   // Chip Selection 1
#ifndef GLCD_CS2
#define GLCD_CS2     PIN_C5   // Chip Selection 2
#ifndef GLCD_DI
#define GLCD_DI      PIN_B0   // Data or Instruction input
#ifndef GLCD_RW
#define GLCD_RW      PIN_B1   // Read/Write
#ifndef GLCD_E
#define GLCD_E       PIN_B2   // Enable
#ifndef GLCD_RST
#define GLCD_RST     PIN_C4   // Reset
#define GLCD_LEFT    0
#define GLCD_RIGHT   1
// Purpose:    Write a byte of data to the specified chip
// Inputs:     1) chipSelect - which chip to write the data to
//             2) data - the byte of data to write
void glcd_writeByte(int1 side, int data)
   if(side)                   // Choose which side to write to
      output_high(GLCD_CS2);
      output_high(GLCD_CS1);
   output_low(GLCD_RW);       // Set for writing
   set_tris_b(0x00);
   set_tris_c(0x00);
   output_bit(pin_B3,bit_test(data,0));            // Put the data on the port
   output_bit(pin_B4,bit_test(data,1));
   output_bit(pin_B5,bit_test(data,2));
   output_bit(pin_B6,bit_test(data,3));
   output_bit(pin_B7,bit_test(data,4));
   output_bit(pin_C0,bit_test(data,5));
   output_bit(pin_C1,bit_test(data,6));
   output_bit(pin_C2,bit_test(data,7));
   delay_cycles(1);
   output_high(GLCD_E);       // Pulse the enable pin
   delay_cycles(5);
   output_low(GLCD_E);
   output_low(GLCD_CS1);      // Reset the chip select lines
   output_low(GLCD_CS2);
// Purpose:    Reads a byte of data from the specified chip
// Ouputs:     A byte of data read from the chip
int glcd_readByte(int1 side)
   int data, datab, datac, i;                 // Stores the data read from the LCD
   set_tris_b(0xF8);              // Set port b and c to input
   set_tris_c(0x07);
   output_high(GLCD_RW);      // Set for reading
   delay_cycles(1);
   delay_cycles(4);
   datab = input_b();   // Get the data from the display's output register
   datac = input_c();
   set_tris_b(0xF8);
   set_tris_c(0x07);
   output_low(GLCD_E);
   for (i=3;i<8;i++)          //data é composto de B3 a C2
      if(bit_test(datab,i))
         bit_set(data,i-3);
         bit_clear(data,i-3);
   for (i=0;i<3;i++)
      if (bit_test(datac,i))
         bit_set(data,i+5);
         bit_clear(data,i+5);
   return data;               // Return the read data
Thanks a lot![/code]
Gu
PostPosted: Mon Nov 19, 2007 12:24 pm     Reply with quote
Anyway, I know the PIC is working, so I think the GLCD is gone...
I will try another one also.
