Help with Optimization
umka
PostPosted: Fri Nov 16, 2007 1:10 am     Reply with quote
I am trying to write a program that tests differant types of hand controllers that all use the same plug at the end but have differant functions and pin wirings. They use a DB15 connection so 15 pins maximum.
I want to use adc0 to select what type of hand controller is connected using if adc0 <10 controller x, if adc0>10 controller y etc. Then when the controller is selected it configures the pins and there functions. Then when a button is pressed on the control handle it displays the function of the pressed button on a lcd display.
so far i have written code like below to display the function when the corosponding pin goes high.
//                      Mini-Me Right Hand Sure-Grip                          //
#define P_1   Pin_A1   //
#define P_2   Pin_A2   //
#define P_3   Pin_A3   // Define Pins for DB15 connection
#define P_4   Pin_A4   //
#define P_5   Pin_A5   //
#define P_6   Pin_C0   //
 void MM_RH_SG (void)
//PIN 1
            output_high(P_1); //Supply voltage to handle
//PIN 2
            if( input(P_2) == 1 ) //Spare button 1
               printf(lcd_putc, "\nSpare            B-1");
               delay_ms(50);
//PIN 3
            else if( input(P_3) == 1 ) //Spare button 2
               printf(lcd_putc, "\nSpare            B-2");
               delay_ms(50);
//PIN 4
            else if( input(P_3) == 1 ) //Rotate CW button 3
               printf(lcd_putc, "\nRotate CW        B-3");
               delay_ms(50);
//PIN 5
            else if( input(P_3) == 1 ) //Head open button 4
               printf(lcd_putc, "\nHead Open        B-4");
               delay_ms(50);
//PIN 6
            else if( input(P_3) == 1 ) //Head close trigger 1
               printf(lcd_putc, "\nHead Open        T-1");
               delay_ms(50);
//PIN 7
//PIN 8
//PIN 9
//PIN 10
//PIN 11
//PIN 12
//PIN 13
//PIN 14
//PIN 15
               printf(lcd_putc, "\fMini Me R/H SureGrip");
               printf(lcd_putc, "\nNo Button Pressed");
               delay_ms(50);
then a differant controller
//                      T10 Right Hand Sure-Grip                              //
#define P_7   Pin_C1   //
#define P_8   Pin_C2   // Define Pins for DB15 connection
#define P_9   Pin_C3   //
#define P_10  Pin_D0   //
#define P_11  Pin_D1   //
 void T10_RH_SG (void)
//PIN 1
//PIN 9
            output_high(P_9); //Supply voltage to handle
//PIN 10
            output_high(P_10); //Supply voltage to handle
//PIN 2
            if( input(P_2) == 1 ) // Urea Button 2
               printf(lcd_putc, "\nUrea             B-2");
               delay_ms(50);
//PIN 3
            else if( input(P_3) == 1 ) // Motor Reverse Button 6
               printf(lcd_putc, "\nMotor Rev        B-6");
               delay_ms(50);
//PIN 4
            else if( input(P_4) == 1 ) // Motor Forward Button 5
               printf(lcd_putc, "\nMotor FWD        B-5");
               delay_ms(50);
//PIN 5
            else if( input(P_5) == 1 ) // Drive arm close Trigger down
               printf(lcd_putc, "\nDrive Arm Close  T-1");
               delay_ms(50);
//PIN 6
            else if( input(P_6) == 1 ) // Drive arm open Trigger up
               printf(lcd_putc, "\nDrive Arm Open   T-2");
               delay_ms(50);
//PIN 7
            else if( input(P_7) == 1 ) // Grapple open Button 7
               printf(lcd_putc, "\nGrapple Open     B-7");
               delay_ms(50);
//PIN 8
            else if( input(P_8) == 1 ) // Bottom delimb open Button 3
               printf(lcd_putc, "\nBtm Delimb Open  B-3");
               delay_ms(50);
//PIN 9  -- Supply
//PIN 10 -- Supply
//PIN 11
            else if( input(P_11) == 1 ) // Grapple close Button 8
               printf(lcd_putc, "\nGrapple Close    B-8");
               delay_ms(50);
//PIN 12
//PIN 13
//PIN 14
//PIN 15
               printf(lcd_putc, "\fT10 R/H Sure-Grip");
               delay_ms(50);
how do i tie them all together including the control selector so as to optimize the memery as i have about 16 controller to do listed in the #include below. all of the #includes are writen the same as the above two but can be changed if there is a better way to do it. i was thinking an interupt thats why i set out the main code like below.
#include <16F877a.h>
#device adc=8
#fuses XT NOLVP NOWDT NOPROTECT
#include <Flex_LCD420.c>
#include <MM_RH_SG.c>      //Mini-Me Right Hand Sure-Grip
#include <MM_LH_SG.c>      //Mini-Me Left Hand Sure-Grip
#include <T10_RH_SG.c>     //T10 Right Hand Sure-Grip
#include <T10_RH_SG_BUT.c> //T10 Right Hand Sure-Grip 8 Button
#include <T10_LH_SG.c>     //T10 Left Hand Sure-Grip
#include <T10_RH_DF.c>     //T10 Right Hand Danfoss
#include <T10_LH_DF.c>     //T10 Left Hand Danfoss
#include <T10_PRE_KEY.c>   //T10 Preset Keypad
#include <LR_RH_SG.c>      //Logrite Right Hand Sure-Grip
#include <LR_RH_SG_BUT.c>  //Logrite Right Hand Sure-Grip 8 Button
#include <LR_LH_SG.c>      //Logrite Left Hand Sure-Grip
#include <LR_LH_SG_BUT.c>  //Logrite Left Hand Sure-Grip 8 Button
#include <LR_RH_DF.c>      //Logrite Right Hand Danfoss
#include <LR_LH_DF.c>      //Logrite Left Hand Danfoss
//#include <T20_RH_SG.c>     //Timberrite Right Hand Sure-Grip
//#include <T20_LH_SG.c>     //Timberrite Left Hand Sure-Grip
unsigned int8 model = 0;   //ADC Control Model Selector
   MM_RH_SG();
   MM_LH_SG();
   T10_RH_SG();
   T10_RH_SG_BUT();
   T10_LH_SG();
   T10_RH_DF();
   T10_LH_DF();
   T10_PRE_KEY();
   LR_RH_SG();
   LR_RH_SG_BUT();
   LR_LH_SG();
   LR_LH_SG_BUT();
   LR_RH_DF();
   LR_LH_DF();
   lcd_init();             //LCD Initialize and Clear
   printf(lcd_putc, "\f");
   delay_ms(50);
   setup_adc( ADC_CLOCK_INTERNAL ); //Setup ADC use timer 0 divide 1
         OUTPUT_A(0x00);   //Clear Port A
         OUTPUT_C(0x00);   //Clear Port C
         OUTPUT_D(0x00);   //Clear Port D
         set_adc_channel(0);
         delay_ms(50);
         model = read_adc();  //Read Control Model Selector
  //NOTE:   check if can leave out repition of all the top
  //        lines after initial selection
any help appretiated
SET
PostPosted: Fri Nov 16, 2007 12:53 pm     Reply with quote
I'm intrigued - how can you tell which controller is connected by reading an analog voltage?
umka
PostPosted: Fri Nov 16, 2007 3:15 pm     Reply with quote
i will use a ref value form the adc and then have and if statment if adc <10 do x if adc>10<20 do y if adc >20<30 do z and so on.
