PIC18F4520 Bootloader
vamsi_ak
PostPosted: Wed Nov 14, 2007 11:50 am     Reply with quote
Hi all,
I am new to bootloaders. Can any one give me the code for 18F4520 bootloader. And how do i flash it on to my PIC.
Thank you,
Vamsi
curt2go
PostPosted: Wed Nov 14, 2007 3:05 pm     Reply with quote
There is a ton of info alreay on that stuff. Search on bootloaders and you will get tons of info.. Hope that helps.. TTY
Vamsi
boot loader for 18F4520.h
PostPosted: Wed Nov 14, 2007 3:29 pm     Reply with quote
This is my code
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F4520.h>
#define _bootloader
#include <bootloader.h>
#include <loader.c>
 #org LOADER_END+1,LOADER_END+10
 #org LOADER_END+2,LOADER_END+20
void application(void) {
  output_toggle(PIN_B0);
#if defined(__PCH__)
#org 0x20,0x7F
#else
#org 0x20,0x3F
void main(void) {
   if(!input(PIN_B5))
      load_program();
   application();
#ORG default
#int_global
void isr(void) {
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
The error i get is
Out of ROM , A segment or the program is too large application
seg 00500-00512,014 left,need 0016
When i change the line
 #org 0x40,0x7F
to
 #org 0x15,0x7F
i get the following error
invalid ORG range
Please pass your suggestions
Thank you,
Vamsi
it gives the
PostPosted: Wed Nov 14, 2007 4:01 pm     Reply with quote
The interrupt handlers are using the memory region from 0x0008 to about 0x0025. That's why you got a different error message after you changed the 0x40-0x7F region.
Have another close look at the error message
The reserved memory region from 0x500 to 0x512 is two bytes too small. Search your source code for where this region is defined and increase it's size a little.
Vamsi
Thank you
PostPosted: Wed Nov 14, 2007 5:02 pm     Reply with quote
Thank you...it helped i am able to work on it now.....
