I would imagine CCS would update these compiler to suit at some stage in the future _________________ What has been learnt if you make the same mistake?
Posted: Mon Nov 12, 2007 5:02 pm
The PIC32 is based on a MIPS core, completely different of the other PIC processors. MIPS Technologies Inc. produces several processor cores of which the M4K is the entry level. A free GNU compiler (GCC) is available. The only backwards compatibility right now seems to be a compatibility at the hardware pin level (64 and 100 pin based devices only).
Largest competitor in this area are the ARM based processors of which Atmel already has a license for several years.
Posted: Mon Nov 12, 2007 6:41 pm
ckielstra - thanks for the info - that saved me some searching!
Steve H.
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
FYI
Posted: Wed Nov 14, 2007 2:47 am
found update mplab to v8 and download c32 student version to write code to the new PIC32 micro _________________ What has been learnt if you make the same mistake?
