How Can I Declare Global Variables?
PostPosted: Tue Nov 13, 2007 12:27 pm     Reply with quote
I have a function that i would like to take in an integer and return two integers. I figure an easy way to do this is to create two global integers but i can seem to find the syntax for that.
PostPosted: Tue Nov 13, 2007 12:56 pm     Reply with quote
This board is about using the CCS compiler. For questions of that type
you should look at a C tutorial. Example:
http://www.cs.cf.ac.uk/Dave/C/node4.html#SECTION00441000000000000000
http://cslibrary.stanford.edu/101/EssentialC.pdf
You can find more tutorials with Google.
