Math help, I2C 1MHz sspadd calc
treitmey
PostPosted: Tue Nov 13, 2007 9:37 am     Reply with quote
I am trying to verify that the compiler is working right.
I am trying to get a 1MHz I2C setup. I'm using
#use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST,RESTART_WDT)
The list file shows
.................... #use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST,RESTART_WDT)
56E4:  BSF    F94.3
56E6:  BSF    F94.4
56E8:  MOVLW  18
56EA:  MOVWF  FC8
#use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST=1000000,RESTART_WDT)
The list file shows
.................... #use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST=1000000,RESTART_WDT)
56E0:  MOVLW  90
56E2:  MOVWF  FAB
56E4:  BSF    F94.3
56E6:  BSF    F94.4
56E8:  MOVLW  09
56EA:  MOVWF  FC8
The lower 7 bits SSPADD @ 0xFC8 controls the speed. for fast it is set to 18, for fast=1000000 it is set to 9
Is this calculated correctly?
I use a
#use delay(clock=40000000)
#fuses h4,wdt16384,noprotect,nolvp,put
10MHz clock and h4 pll.
treitmey
PostPosted: Tue Nov 13, 2007 9:45 am     Reply with quote
TABLE 17-3: I2C™ CLOCK RATE W/BRG
Fosc     FCY      FCY*2      BRGValue   FSCL
                                     (2 Rollovers of BRG)
40 MHz 10 MHz 20 MHz 18h 400 kHz(1)
40 MHz 10 MHz 20 MHz 1Fh 312.5 kHz
40 MHz 10 MHz 20 MHz 63h 100 kHz
16 MHz 4 MHz 8 MHz 09h 400 kHz(1)
16 MHz 4 MHz 8 MHz 0Ch 308 kHz
16 MHz 4 MHz 8 MHz 27h 100 kHz
4 MHz 1 MHz 2 MHz 02h 333 kHz(1)
4 MHz 1 MHz 2 MHz 09h 100 kHz
4 MHz 1 MHz 2 MHz 00h 1 MHz(1)
PostPosted: Tue Nov 13, 2007 9:58 am     Reply with quote
Two things. Remember the values are hex. The division is by val+1.
So for 400K, is is dividing the clock by twenty five (0x18+1). The clock is selected as master clock/4. So:
40000000/(4*25) = 400000
Spot on.
For the 100K version, it divides by ten. So:
40000000/(4*10) = 1000000
Again spot on.
The compiler is doing it right.
treitmey
PostPosted: Tue Nov 13, 2007 10:07 am     Reply with quote
Cool
Thanks a bunch.
((Ttelmah:100k should read 1M in your post))
Belt and suspenders theory.
I'll also write a tight loop and check with scope.
With scope I get 1uS for half(5v part) cycle of the SCL pin.
I guess thats correct. But not sure. I expected 1us for a FULL cycle.
PostPosted: Tue Nov 13, 2007 4:00 pm     Reply with quote
Er. I don't have '100K'in my post anywhere. The value I have, is 1000000, which is 1M, and is correct.
I'm easily capable of missing a zero, but I haven't...
treitmey
PostPosted: Wed Nov 14, 2007 4:44 pm     Reply with quote
no worries..
Spot on.
Thank you for your help.
Very Happy
