Get warning by compiler graphic.c example
The Puma
PostPosted: Thu Nov 08, 2007 5:03 pm     Reply with quote
I get this error
>>> Warning 206 "F:\CCS\PICC\User Projects\pg320240d\graphics.h" Line 531(1,1): Variable of this data type is never greater than this constant
Hoiw can i remove this Warning???
#ifdef LARGE_LCD
void glcd_text57(int16 x, int16 y, char* textptr, int8 size, int1 color)
#else
void glcd_text57(int8 x, int8 y, char* textptr, int8 size, int1 color)
   int8 j, k, l, m;                       // Loop counters
   int8 pixelData[5];                     // Stores character data
   for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
      if(*textptr < 'S') // Checks if the letter is in the first font array
         memcpy(pixelData, FONT[*textptr - ' '], 5);
      else if(*textptr <= '~') // Check if the letter is in the second font array
         memcpy(pixelData, FONT2[*textptr - 'S'], 5);
         memcpy(pixelData, FONT[0], 5);   // Default to space
      // Handles newline and carriage returns
      switch(*textptr)
         case '\n':
            y += 7*size + 1;
            continue;
         case '\r':
            x = 0;
            continue;
      THIS LINE GIVE THE ERROR
      if(x+5*size >= GLCD_WIDTH)          // Performs character wrapping
         x = 0;                           // Set x at far left position
         y += 7*size + 1;                 // Set y at next position down
      for(j=0; j<5; ++j, x+=size)         // Loop through character byte data
         for(k=0; k < 7; ++k)             // Loop through the vertical pixels
            if(bit_test(pixelData[j], k)) // Check if the pixel should be set
               for(l=0; l < size; ++l)    // These two loops change the
               {                          // character's size
                  for(m=0; m < size; ++m)
                     glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
PostPosted: Thu Nov 08, 2007 5:24 pm     Reply with quote
Here are some clues about what to do:
#ifdef LARGE_LCD
#else
The Puma
PostPosted: Fri Nov 09, 2007 9:53 am     Reply with quote
OK thanks
I insert this and it works now
#define LARGE_LCD 1
The Puma
PostPosted: Fri Nov 09, 2007 11:04 am     Reply with quote
An question, the included driver is for the SED1335 chipset
my lcd use an s1d13305 chipset
Must i change something to get it to work?
PostPosted: Fri Nov 09, 2007 11:41 am     Reply with quote
What you must do is use Google.
s1d13305 SED1335 part number
The Puma
PostPosted: Fri Nov 09, 2007 12:21 pm     Reply with quote
In my opinion it is the same
The Puma
PostPosted: Sat Nov 10, 2007 5:20 am     Reply with quote
Last question about the supplied driver
Where must i connect the data bus on what PIC port
The rd,wr,ao,cs,rst pins are defined, but not the data bus
PostPosted: Sat Nov 10, 2007 5:33 am     Reply with quote
PortD
Look at the first line of the 'sendbyte' routine.
The Puma
PostPosted: Sat Nov 10, 2007 5:36 am     Reply with quote
Ttelmah wrote:
PortD
Ok thx
I can change it to another port, i think this is not a problem
I will put the data to port C
and the control lines to port B
Gives this problems?
PostPosted: Sat Nov 10, 2007 6:04 am     Reply with quote
Shouldn't be any problem. There are about half a dozen places you'll need to change things. Fast_io for this port, the TRIS commands in the read byte routine, the actual data input and output lines. However it should run fine.
The Puma
PostPosted: Sat Nov 10, 2007 6:19 am     Reply with quote
Ok, i have change the following
int8 getStatus() {
   int8 status;
   TGLCD_DATA
   output_low(GLCD_CS);
   output_low(GLCD_RD);
   delay_us(1);
   status=input_c();
   output_high(GLCD_RD);
   output_high(GLCD_CS);
   return status;
int8 glcd_readByte() {
   int8 data;
   set_tris_c(0xFF);
   delay_cycles(1);
   delay_cycles(2);
   data=input_c();
   return data;
void glcd_sendByte(byte data) {
   output_c((data));
   delay_cycles(1);
   output_low(GLCD_WR);
   delay_cycles(2);
   output_high(GLCD_WR);
This must be all?
The Puma
PostPosted: Sat Nov 10, 2007 7:59 am     Reply with quote
It did't work Sad Sad
Only the whole screen of pixel and other strange pattern
