Hardware multiplication MULWF
treitmey
PostPosted: Thu Nov 08, 2007 11:50 am     Reply with quote
Am I wrong to expect to find a few MULWF asm instruction in my list file.
Does the compiler use the hardware mul if it is available?
Does anyone do/force this an a known good workable way?
I thought that is what the _mul() function did. but it doesn't seem to be the
case in 3.249
PostPosted: Thu Nov 08, 2007 11:58 am     Reply with quote
The code below was compiled with PCH vs. 4.062. It uses MULWF.
.... c = a * b;
0014: MOVF 06,W
0016: MULWF 07
0018: MOVF FF3,W
001A: CLRF 09
001C: MOVWF 08
#include <18F452.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
int8 a, b;
int16 c;
c = a * b;
PostPosted: Thu Nov 08, 2007 1:21 pm     Reply with quote
Same result in the ancient v3.226 I'm using.
PostPosted: Thu Nov 08, 2007 1:38 pm     Reply with quote
It's possible that you're not seeing the code because it's hidden.
Some library routines are not normally shown in the .LST file.
To see them, edit the .H file for your PIC and comment out the
#nolist statement. Example:
#device PIC18F452
//#nolist
Then re-compile and look near the start of the .LST file. You should now
see the library routines with the MULWF statements.
treitmey
PostPosted: Thu Nov 08, 2007 2:58 pm     Reply with quote
The simple case ref: above does show the mulwf... so I guess i just
have to dumb down the code so the compiler sees it as a
int16 =int8 * int8
Thanks...
PostPosted: Thu Nov 08, 2007 3:14 pm     Reply with quote
The code that I posted above won't actually work. You have to cast
one of the variables to an int16 to get the correct result. But the
LST file code still uses the hardware multiply.
0004: MOVF 0C,W
0006: MULWF 0E
0008: MOVFF FF3,01
000C: MOVFF FF4,00
0010: MULWF 0F
0012: MOVF FF3,W
0014: ADDWF 00,F
0016: MOVF 0D,W
0018: MULWF 0E
001A: MOVF FF3,W
001C: ADDWFC 00,W
001E: MOVWF 02
0020: GOTO 0056 (RETURN)
I tried it with the _mul() routine and it creates code for a software
multiply. Now I understand the reason why you posted the question.
The method shown below should work for you.
#include <18F452.h>
int8  a, b;
int16 c;
a = 250;
b = 133;
c = a * (int16)b;
printf("%lu", c);
treitmey
PostPosted: Thu Nov 08, 2007 3:19 pm     Reply with quote
still no joy on v3.249
but change to _mul and you get the mulwf
c = _mul(a,b);
Don't sweat it. All my code is working.
Just optimizing,.. trying to understand.
treitmey
PostPosted: Thu Nov 08, 2007 3:31 pm     Reply with quote
I think it just happens that my large programs all are using the mullw
(Multiply Literal with W)
so no mulwf.. sorry for the confusion.
