ADC-- RA0 has a non-zero voltage on it
Jomile
PostPosted: Wed Nov 07, 2007 3:03 pm     Reply with quote
I am using the A port for ADC (16F877A). When i use RA1 i have no problem but for some reason I am having issues with RA0. I measured the voltage on the pin and it is 2.14V (open). I tried two chips. Is there something I am missing in code?
#include "C:\Program Files\PICC\Projects\11-7-07\main.h"
  #include <string.h>
   int value;
   setup_adc_ports(RA0_RA1_RA3_ANALOG);
   //setup_adc_ports(AN0_AN1_AN2_AN4_VSS_VREF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //SET_TRIS_A( 0xFF );
   // B7,B6,B5,B4 are outputs
   // B3,B2,B1,B0 are inputs
   printf("Start");
   set_adc_channel( 0 );
  output_high(PIN_C0);
  while(TRUE){
  output_low(PIN_C0);
  spi_write(0x30);
  spi_write(0x0F);
  output_high(PIN_C1);
  value = read_adc();
  printf("A/D value = %2x\n\r", value);
  delay_ms(2000);
  output_low(PIN_C0);
  spi_write(0x3F);
  spi_write(0x00);
  output_low(PIN_C1);
  value = read_adc();
  delay_ms(2000);
.h file
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
PostPosted: Wed Nov 07, 2007 3:07 pm     Reply with quote
Are you trying to do this on a floating input ? If so, you could read
any value. Put a 47K pull-down resistor on that pin. Then read it
with read_adc(). It should read 0.
