I2C Slave will not work on PIC16F690
tanyamahen
PostPosted: Sun Nov 04, 2007 10:23 pm     Reply with quote
Hi
In my project I need to communicate with other hardware via I2C.
Currently I can't get I2C working. Interrupt naver happen.
Here is my code
#include <16F690.h>
#device *=16 ICD=TRUE
#fuses INTRC, NOWDT, NOPROTECT
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
#LIST
#use i2c(SLAVE, SDA=PIN_B4, SCL=PIN_B6, address= 0x60,  FORCE_HW)
#include <input.c>
#include <stdlib.h>
#include <string.h>
#byte SSPSTAT = 0x014
#byte SSPADD = 0x013
#byte SSPCON = 0x014
#byte STATUS = 0x003
#byte SSPBUF = 0x013
#byte PIE1 = 0x8c
#bit SSPOV1 = 0x014.6
#bit SSPSTART = 0x014.3
#define  MY_I2C_ADDR  0x60
void I2C_Reset_Hardware();
//------------------- Synchronous Serial Port I2C ---------------------------
#define  I2C_MASTER_MASK 0x0B // SSPCON.SSPM3-0 = 1011 firmware master mode, slave idle
#define  I2C_SLAVE_MASK  0x0E // SSPCON.SSPM3-0 = 1110 - slave mode, 7-bit addr, S & P
                              // interrupts enabled
#define  I2C_CLK_ENABLE          0x10
#define  I2C_MODE_SETUP          0x20
// this is our current i2c address
static int8 I2C_Address = MY_I2C_ADDR;
//I2C Interrupt Service Routine
#INT_SSP
void ssp_interupt ()
   BYTE incoming, state ;
 // change the bank to 1
  bit_set(STATUS, 6);
  bit_clear(STATUS, 5);
  output_low(PIN_A5);
  output_high(PIN_A5);
  output_low(PIN_A5);
    state = i2c_isr_state();
    if(state == 0x80)                     //address Master is sending data
    //  output_low(PIN_A5);
    //  output_high(PIN_A5);
        incoming = i2c_read();
   // printf("Address %x\n\r", incoming );
    else if(state < 0x80)
   //     incoming = i2c_read();
    //   printf("i2c read %x\n\r", incoming );
  // change the bank back to 0
  bit_clear(STATUS, 6);
// Main star here
void main ()
 int addr1;
 disable_interrupts(GLOBAL);
  // ************** Intialise All Veriables ********************
  setup_adc_ports(NO_ANALOGS);
  // 1 = Input,0 = Output
  set_tris_A ( 0x1B );      // Port A 00011011
  set_tris_B ( 0x30 );      // Port B 00110000 ( Bit5/7 - RS232- Rx/tx)
  set_tris_C ( 0x87 );        // Port C 00011111
  printf( "\n\r\n\rInitialising \n\r");
  setup_wdt(WDT_OFF);
  output_float(PIN_B6);
  output_float(PIN_B4);
// Change the Bank to set the address
  bit_set(STATUS, 6);
  SSPADD = 0x60;
  addr1 = SSPADD;
   bit_set(PIE1,3);
  printf(" get Address %X \n\r",addr1);
  enable_interrupts(INT_SSP);
  disable_interrupts(INT_RB);
   bit_set(STATUS, 6);
  SSPADD = 0x60;
  addr1 = SSPADD;
   bit_set(PIE1,3);
  while (TRUE)
void I2C_Reset_Hardware(void)
 int tmp;
  // Reset the I2C if we timeout, this should prevent us from ever
  // locking up the I2C
  SSPADD = I2C_Address;
  SSPCON = (I2C_SLAVE_MASK);
  SSPCON = (I2C_SLAVE_MASK | I2C_CLK_ENABLE | I2C_MODE_SETUP);
  // Clear the buffer
  tmp =SSPBUF;
  SSPOV1 = 0;
  clear_interrupt(INT_SSP);
  return;
Did anyone had any issue with I2c using PIC16F690.
Can someone help me out here
Compiler Ver PCM 4.058
PostPosted: Sun Nov 04, 2007 10:59 pm     Reply with quote
#byte PIE1 = 0x8c
bit_set(STATUS, 6);
SSPADD = 0x60;
addr1 = SSPADD;
bit_set(PIE1,3);
CCS automatically selects the correct bank if you specify the correct
address of the SSP registers. You don't need to manually switch banks
with CCS.
tanyamahen
PostPosted: Mon Nov 05, 2007 2:21 am     Reply with quote
I have chaged as you said but still problem
rnielsen
PostPosted: Mon Nov 05, 2007 10:03 am     Reply with quote
I haven't compiled this code so I'm not 100% that it works but, try something like this:
#INT_SSP
unsigned int8 state;
  output_toggle(PIN_A0);// indicate that the ISR has at least been entered
  if(!state)
    output_toggle(PIN_A1)// toggle output, assign whatever pin you want here
    output_toggle(PIN_A2)
  else if(state == 0x80)
    output_toggle(PIN_A3)
  else if(state > 0x80)
    output_toggle(PIN_A4)
}// end of ISR
If you get my drift you'll see that we're simply trying to see if the PIC is responding to I2C commands. Assign what ever pins you want to toggle. I would suggest using LEDs for visual indication on what the slave is seeing. If none of the outputs toggle then there might be a hardware issue between the master and slave.
Make your master code very simple. Maybe something like:
i2c_start();
i2c_write(0x60);
i2c_stop();
This should cause the slave to ACK and toggle one of the outputs. Use this to start with and then expand the master code to write and read data. I've found it's best to start from the most simplest code, doing only one thing, and then adding to it.
Best of luck.
Ronald
tanyamahen
PostPosted: Mon Nov 05, 2007 11:59 pm     Reply with quote
Thanks Ronald
Today holiday in melbourne.... I will go to work tomorrow to check this out... I have CRO to check the toggled PIN (In my code PIN_A5).
Thanks for your help
Tanya
PostPosted: Wed Nov 14, 2007 6:52 pm     Reply with quote
Thank you all
I have fix the problem. (Two Problem)
1) In PIC16f690 when you set "enable_interrupts(INT_SSP) " This interrupt setting goes and set the "RB interrupt" I have now set the interrupt in ASM and I get I2C interrupt.
2) Master send wrong address (0x10) My address is 0x60.
Once I finish coding I will post my code
ymoona
PostPosted: Sun Dec 30, 2007 12:26 pm     Reply with quote
Anonymous wrote:
Thank you all
currently I face the same problem. I've connected to 16F690 via I2C. Both line have 10k pullups to the +5V. The master source is:
#include <16F690.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPUT                    //No Power Up Timer
#use rs232(baud=19200, xmit=PIN_B7, rcv=PIN_A5)
#use i2c(Master, Slow, sda=PIN_B4, scl=PIN_B6)
Pin defines
#define led PIN_A5
#int_SSP // i2c activty
SSP_isr()
   return;
void main(){
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   //setup_timer_2(T2_DIV_BY_1,255,1);
   setup_timer_2(T2_DIV_BY_16, 124, 1);  // 1000 Hz, the pwm frequention
   setup_oscillator(OSC_8MHZ);
   printf("I2C engine driver\n\r");
   while(1){
      output_high(led);
      // Write the letter 'B' to the slave board.
      i2c_start();
      i2c_write(0xA0);
      i2c_write(0x00);
      i2c_write(0b01001111);
      i2c_stop();
      output_low(led);
      i2c_start();
      i2c_write(0xA0);
      i2c_write(0x00);
      i2c_write(0b10001111);
      i2c_stop();
This is the slave code:
#include <16F690.h>
#device adc=8
#use rs232(baud=19200, xmit=PIN_A5, rcv=PIN_A4)
#use i2c(Slave, Slow, sda=PIN_B4, scl=PIN_B6, address=0xa0)
Pin defines
#define driver_a PIN_C0
#define driver_b PIN_C1
Variables
Function prototypes
// description: This funtion enables or disables the LM298 both H-bridges.
// arguments:   Boolean enable
// return:      None
void EnableDrivers( int1 enable );
// description: This funtion sets both the h-bridges to the desired value
// arguments:   int8 config
//              The four MBS configure the side and direction.
//              The four LSB configure the duty cycle.
// return:      None
void SetDrivers( int8 config );
// There are some issues with the PWM module, before changing pinout please clear.
void clear( void );
SSP_isr()
   printf("interrupt!\n\r");
   return;
void main(){
   setup_adc(ADC_OFF);
   //enable_interrupts(INT_RB);
   printf("I2C engine driver Updated with I2C\n\r");
   EnableDrivers( true );
   while(1){
      // recht vooruit
      SetDrivers( 0b10000111 );
      delay_ms( 2000 );
      // recht achteruit
      SetDrivers( 0b01000111 );
      delay_ms( 2000 );
      // rechtsom
      SetDrivers( 0b00100111 );
      delay_ms( 2000 );
      // linksom
      SetDrivers( 0b00010111 );
      delay_ms( 2000 );
      // stop
      SetDrivers( 0b00000111 );
      delay_ms( 2000 );
Funtion boddies
void EnableDrivers( values ){
   if( values ){
      output_high( driver_a );
      output_high( driver_b );
   else{
      output_low( driver_a );
      output_low( driver_b );
void SetDrivers( int8 config ){
   int8 settings = 0;
   int8 duty = 0;
   duty = config & 0b00001111;
   duty = duty * 8;
   set_pwm1_duty( duty );
   settings = config & 0b11110000;
   settings = settings >> 4;
   if((settings & 0b1000) >  0 &&  // forward
      (settings & 0b0100) == 0 &&
      (settings & 0b0010) == 0 &&
      (settings & 0b0001) == 0 ){
       clear();
       setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_A | CCP_PULSE_STEERING_C );
       output_low( PIN_C4);
       output_low( PIN_C3);
   else if((settings & 0b1000) == 0 &&
           (settings & 0b0100) >  0 &&  // backward
            clear();
            setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_B | CCP_PULSE_STEERING_D );
            output_low( PIN_C5);
            output_low( PIN_C2);
           (settings & 0b0010) >  1 &&  // turn right
            clear();
            setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_A | CCP_PULSE_STEERING_D );
           (settings & 0b0001) > 0 ){  // turn
            clear();
            setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_B | CCP_PULSE_STEERING_C );
   else{
      clear();
      setup_ccp1(CCP_PWM | CCP_PWM_H_H );
      output_low( PIN_C5);   }
void clear( void ){
   setup_ccp1(CCP_PWM | CCP_PWM_H_H | CCP_PULSE_STEERING_A | CCP_PULSE_STEERING_B | CCP_PULSE_STEERING_C | CCP_PULSE_STEERING_D );
The slave code is a bit big, but otherwise it doesn't compile.
The problem is that I get no interrupt.
I get this code on the slave in ASM
....................    enable_interrupts(INT_SSP);
0226:  BSF    03.5
0227:  BSF    0C.3
....................    enable_interrupts(GLOBAL);
0228:  MOVLW  C0
0229:  BCF    03.5
022A:  IORWF  0B,F
Is this correct?
checkout my site: www.ymoona.com/wiki
PostPosted: Sun Dec 30, 2007 2:26 pm     Reply with quote
It worked for me. Here's the output of the 16F690:
interrupt!
interrupt!
interrupt!
interrupt!
I don't have two 16F690's, so I used a 16F877 for the master, but with
similar code. I tested this with vs. 4.064 of the compiler.
What is your compiler version ?
Also, you don't need SSP interrupts in the Master code. Remove the
#int_ssp routine, and remove the enable interrupts for INT_SSP and
GLOBAL. You only need SSP interrupts in the slave code.
Another thing is you don't need a 'return' statement in an interrupt
routine. The compiler puts in code to handle exiting from the routine.
Delete the 'return' statements.
ymoona
PostPosted: Sun Dec 30, 2007 2:40 pm     Reply with quote
interrupt!
interrupt!
interrupt!
interrupt!
I had a little break, an suddenly interrupts seem to work. The return statement in a function is a habbit, a function always returns.
ymoona
PostPosted: Sun Dec 30, 2007 4:49 pm     Reply with quote
I thought the problem was fixed, but still it isn't working as I expect.
This is my master code:
   while(1){
      output_high(led);
      i2c_start();
      delay_ms(10);
      i2c_write(0xA0);
      delay_ms(10);
      delay_ms(10);
      i2c_stop();
      delay_ms(10);
      output_low(led);
      i2c_start();
      delay_ms(10);
      i2c_write(0xA0);
      delay_ms(10);
      delay_ms(10);
      i2c_stop();
      delay_ms(10);
So I send a single byte (plus of course the address)
This is my slave code:
SSP_isr(){
   output_high(led);
   // you will only be interrupted if the address is correct.
   // first check the mode: read or write
   if(state < 0x80){                     //Master is sending data
      if(state == 1){                     //First received byte is byte I want
          value = incoming;
   output_low(led);
I expected the led to flash 2 times quick (I probably cannot see two pulses) per half second. But this is not what happens. The led flahes very irregularly, and it stays on for way too long sometimes. Up to 500 to 1500 ms. How does this happen?
Compiler version: 4.013
Edit:
I've done some tests, and this is the result: working code.
SSP_isr(){
   output_high(led);
      if(state == 0){
         value = incoming;
   output_low(led);
As you can see I ignore state 0 (the address byte) and then I don't read. Only the first data byte is read. Why is this working?
