CCS-C Driver SED1335 (Powertip PG320240D-p5) is not working
The Puma
PostPosted: Sat Nov 03, 2007 5:05 pm     Reply with quote
I used the ccs-c driver that is included.
But this driver don't work.
Has someone got it worked??
The Puma
PostPosted: Mon Nov 05, 2007 7:39 am     Reply with quote
Nobody has working with a S1D13305 +(SED1335) graphic lcd?
rnielsen
PostPosted: Mon Nov 05, 2007 9:42 am     Reply with quote
You posted your first request on Saturday, which could be thought of as a Holy day (meaning the weekend and a NON work day). You gave it almost a day and a half for responses which still fell inside of the weekend. Now, I, personally, don't check this forum on the weekend. I'm off doing fun things like doing the laundry, cleaning the house, mowing the lawn, digging in the garden and so forth.
Wait a couple more days and see if somebody has something to say. I've never played with graphic displays, yet, but have wanted to mess around with them. Hopefully somebody has something to contribute.
Ronald
The Puma
PostPosted: Tue Nov 06, 2007 1:14 pm     Reply with quote
Question about the sample files in the CCS-dir
The driver files are:
graphics.c and sed1135.c
Where is the main file that uses this driver files???
PostPosted: Tue Nov 06, 2007 4:50 pm     Reply with quote
- Open Windows Explorer
- Go to C:\Program Files\PICC
- Right click on this directory name and select 'Search'
- Type in the second field: 'graphics.c'
The Puma
PostPosted: Wed Nov 07, 2007 11:45 am     Reply with quote
@ckielstra
These files graphics.c and sed1335.c are the driver files.
But which file (in example directory) calls these driver files?
See EX_GLCD.C for example for ks0108 driver
amcfall
PostPosted: Wed Nov 07, 2007 1:08 pm     Reply with quote
The [spam] wrote:
@ckielstra
But wich file (in example directory) callsl these driver files?
And if you do what he said it will show any files that include graphics.c. He gave you instructions on finding the info yourself.
Avery
The Puma
PostPosted: Sat Nov 10, 2007 8:12 am     Reply with quote
I can't get the lcd to work
I get 5 vertical bars
Did anybody has to get to work this driver with a sed1335 compatible display???
The Puma
PostPosted: Sat Nov 10, 2007 1:06 pm     Reply with quote
The initialising works.
I can switch the lcd on and off with glcd_power.
But i can get no text or graphics on it,
only strange chars
Is there a difference in memory allocation in the sed1335 and s1d13305 chip
Must i somewhere change
The Puma
PostPosted: Sun Nov 11, 2007 11:04 am     Reply with quote
I have play with these parameters, and i get some "a" on my lcd
How can i get the correct parameters for my display
// The following defines setup the memory used by different regions
// Currenty one text area is defined at the beginning of memory
// and a graphics area follows immediately after
#define GLCD_TEXT_ADDR              0x0000
#define GLCD_GRAPHICS_ADDR          GLCD_WIDTH * GLCD_HEIGHT / 64
#define GLCD_GRAPHICS_ADDR_END      GLCD_GRAPHICS_ADDR + (GLCD_WIDTH * GLCD_HEIGHT / 8)
