tavioman
debug/release versions |
Posted: Fri Nov 02, 2007 1:33 pm |
Hi all.
Can anybody point me to way of doing printf in debug version with a macro?
The same macro in "release" version would do nothing?
It's possible do do this with CCS C?
Thank you. |
Humberto
Posted: Fri Nov 02, 2007 2:49 pm |
Did you try with #ifdef preprocessor directives?
I canĀ“t fully understand what do you need, please could you write an example of
what do you want to show/hide while in "debugg mode or in "release mode"?
Humberto |
tavioman
Posted: Fri Nov 02, 2007 4:08 pm |
A macro.
Code: | trace("Something %d, else %Ld", x, y); |
that in release just won't do anything... |
Posted: Fri Nov 02, 2007 4:33 pm |
Try this. It uses a debug macro from the CCS file Ex_Macro.c.
Code: | #include <16F877.H>
#use delay(clock = 4000000)
//#define DEBUG 1
#ifdef DEBUG
#define debug_printf(x) printf("%s variable value is %d\r\n",#x,x);
#else
char c;
c = 0x55;
debug_printf(c);
tavioman
Posted: Sat Nov 03, 2007 12:44 am |
I wish to be more generic like: Code: |
trace("This is debug value no. %u with address %u", value, address);
trace("Just a line");
trace("Three numbers: %u, %u, %u", number1, number2, number3); |
I believe this can be done with va_arg, etc.
I've never worked with this, and I don't know the usage.... |
