Struct and bubble sort
Orcino
PostPosted: Fri Nov 02, 2007 9:12 am     Reply with quote
Hi, i am with a problem in struct and bubble sort, with 10 elements this work right but more not right. I write a small code for test, sees below.
Compiler version is 4.058
forgives for my bad English
#include <18F4525.h>
// #DEVICE ICD=TRUE
#FUSES H4                       //High speed osc with HW enabled 4X PLL
#FUSES MCLR                     //Master Clear pin enabled
#use delay(clock = 40 Mhz)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(E)
#byte PORT_A=0XF80
#byte PORT_B=0XF81
#byte PORT_E=0XF84
#BIT STD   =      PORT_B.0
#BIT B_SALVA =    PORT_B.4
#BIT B_PROXIMO =  PORT_B.6
#BIT B_SAIR =     PORT_B.5
#BIT B_APAGA    = PORT_B.7
#BIT BUZZER     = PORT_B.3
#include <giga_lcd.c>
int8 posicao=0;
//                                 Estrutura
struct SGPSCoord
    int32 buffer_latitude;
    int32 buffer_longetude;
    int distancia;
    int16 ponto;
    int8 status;
    int1 flag_lido;
struct SGPSCoord GPSCOORD[100];
//                                  Funções
void InverteElementos(struct SGPSCoord *pCoordenadas, int nE1, int nE2 );
void BubbleSort( int nQtdElementos, struct SGPSCoord *pCoordenadas );
void preenche_estrutura(void);
void mostra(void);
void calcula_distancias_ordena(void);
//                            Função principal
   lcd_init();
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128); // overflow a cada 840ms
   setup_timer_1(T1_DISABLED);
   disable_interrupts(INT_RTCC);
   disable_interrupts(GLOBAL);
   setup_oscillator(False);
    set_tris_B(0B11110111); // STD, SALVA , RS232, BOTOES
 printf(LCD_PUTC,"   TESTE     ");
 preenche_estrutura();
 BubbleSort(50,GPSCOORD);
           if(!b_proximo)
                  printf(LCD_PUTC,"\f");
                  printf(LCD_PUTC,"Posicao %u\r",posicao );
                  printf(LCD_PUTC,"\nDistancia %u\r",GPSCOORD[posicao].distancia);
                  posicao++;
//                                Ordenação
    int nBase, nCursor;
      for( nBase = 0; nBase < nQtdElementos - 1; ++nBase )
       for( nCursor = nBase + 1; nCursor < nQtdElementos; ++nCursor )
         if( pCoordenadas[ nBase ].distancia > pCoordenadas[nCursor ].distancia )
               InverteElementos( pCoordenadas, nBase, nCursor );
//                                 swap
  struct SGPSCoord sTemp;
     memcpy( &sTemp, &pCoordenadas[ nE1 ], sizeof( sTemp ));
     memcpy( &pCoordenadas[ nE1 ], &pCoordenadas[ nE2 ], sizeof( sTemp ));
     memcpy( &pCoordenadas[ nE2 ], &sTemp, sizeof( sTemp ));
//                               for test
     int8 i=0, cont2=0;
        for(i=0; i < 50 ; i++)
                 GPSCOORD[i].buffer_latitude  = cont2;
                 GPSCOORD[i].buffer_longetude = cont2;
                 GPSCOORD[i].ponto            = cont2;
                 GPSCOORD[i].distancia = cont2;
                 cont2++;
PostPosted: Fri Nov 02, 2007 1:34 pm     Reply with quote
Hi, in other small code for test, in 18F452 work right, but in the 18F4525 not work right, see below
18F4525 -------------------------------- 18F452
Valor 0 posicao 0 --------------- Valor 0 posicao 0
Valor 0 posicao 1 --------------- Valor 1 posicao 1
Valor 0 posicao 2 --------------- Valor 3 posicao 2
Valor 0 posicao 3 --------------- Valor 4 posicao 3
Valor 0 posicao 4 --------------- Valor 8 posicao 4
Valor 0 posicao 5 --------------- Valor 9 posicao 5
Valor 1 posicao 6 --------------- Valor 11 posicao 6
Valor 4 posicao 7 --------------- Valor 12 posicao 7
Valor 8 posicao 8 --------------- Valor 13 posicao 8
Valor 9 posicao 9 ---------------- Valor 15 posicao 9
Valor 12 posicao 10 ------------- Valor 19 posicao 10
Valor 19 posicao 11 ------------- Valor 32 posicao 11
Valor 32 posicao 12 ------------- Valor 33 posicao 12
Valor 33 posicao 13 ------------- Valor 34 posicao 13
Valor 34 posicao 14 ------------- Valor 45 posicao 14
Valor 45 posicao 15 ------------- Valor 56 posicao 15
Valor 56 posicao 16 ------------- Valor 65 posicao 16
Valor 65 posicao 17 ------------- Valor 67 posicao 17
Valor 67 posicao 18 ------------- Valor 73 posicao 18
Valor 73 posicao 19 ------------- Valor 100 posicao 19
// #include <18F452.h>  // Work Right
#include <18F4525.h>    // Nor work
// ***#DEVICE ICD=TRUE
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed osc with HW enabled 4X PLL
#use delay(clock = 20 Mhz)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(E)
//#byte PORT_A=0XF80
//#byte PORT_B=0XF81
//#byte PORT_E=0XF84
//#byte DTMF_IN = PORT_A
//#BIT CLK  = PORT_E.0   //|
//#BIT DADO = PORT_E.1   //| HT 9200A
//#BIT CE   = PORT_E.2   //|
//#BIT STD   =      PORT_B.0
//#BIT B_SALVA =    PORT_B.4   //  |
//#BIT B_PROXIMO =  PORT_B.6   //  |   Botoes p/ navegação nas coordenadas salvas
//#BIT B_SAIR =     PORT_B.5   //  |
//#BIT B_APAGA    = PORT_B.7   //  |
//#BIT BUZZER     = PORT_B.3
#include <giga_lcd.c>   // Drive de LCD modificado
#define scl pin_C3  // Define pinos de comunicação com EEPROM
#define sda pin_C4
struct SGPSCoord
    int buffer_latitude;    // Longetude
    int buffer_longetude;   // Latitude
    int distancia;          // Dist. do ponto atual até a coordenada
    int ponto;               // N. do ponto
    int status;              // status do eqpt monitorado
    int flag_lido;           // Indica se coordenada já foi lida
//                                  Funções
void mostra(void);
//                            Função principal
 int cont1;
 BubbleSort(20,GPSCOORD); // Ordena pela distancia
 for(cont1=0;cont1 < 20 ; cont1++)
      printf("\nValor %u posicao %u\r",GPSCOORD[cont1].distancia, cont1 );
//                                Ordenação
    int nBase, nCursor;
//                     inverte os elementos
//                               For test
         GPSCOORD[0].distancia = 12;
         GPSCOORD[1].distancia = 33;
         GPSCOORD[2].distancia = 32;
         GPSCOORD[3].distancia = 45;
         GPSCOORD[4].distancia = 67;
         GPSCOORD[5].distancia = 34;
         GPSCOORD[6].distancia = 65;
         GPSCOORD[7].distancia = 73;
         GPSCOORD[8].distancia = 56;
         GPSCOORD[9].distancia = 19;
         GPSCOORD[10].distancia = 0;
         GPSCOORD[11].distancia = 1;
         GPSCOORD[12].distancia = 4;
         GPSCOORD[13].distancia = 8;
         GPSCOORD[14].distancia = 9;
         GPSCOORD[15].distancia = 3;
         GPSCOORD[16].distancia = 11;
         GPSCOORD[17].distancia = 13;
         GPSCOORD[18].distancia = 15;
         GPSCOORD[19].distancia = 100;
