Sorry for simple question regarding ADCs
arunb
PostPosted: Fri Nov 02, 2007 2:26 am     Reply with quote
I am using an MCP3208 ADC to measure signals.
Do I have to give a separate reference voltage to the ADC or can I use the same +5V supply that is required for the ADC ??
thanks
arunb
libor
PostPosted: Fri Nov 02, 2007 8:08 am     Reply with quote
With the reference you determine the maximum measurement range. Yes you can use the same 5V if you are measuring up to the 5V range. (if you have a lower level of input range you can increase resolution by setting the reference to a lower voltage, this reference voltage will be the max scale value on the ADC reading)
For improved precision, there a caveat regarding digital noise on the supply rail, so you can decouple the Vref using an RC filter (e.g. a series resistor of 100-500 Ohm, with a capacitor to the ground of 1uF - 100nF will do I think)
rnielsen
PostPosted: Fri Nov 02, 2007 8:35 am     Reply with quote
It is recommended to have your grounds separated. Have digital parts and analog parts on different ground traces. This will help minimize noise on the analog A/D parts. Always use caps (~.1uf) to help with this as well.
Ronald
Humberto
PostPosted: Sun Nov 04, 2007 12:57 pm     Reply with quote
The MCP3208 is a 12 bit ADC. 2^12= 4096
To get the best resolution and range for this family devices, using the MCP1541
-or equivalent- as Reference Voltage, you will get full range (4096 steps) with 1mV granularity.
Humberto
