abc Guest
Need help on RF out |
Posted: Thu Nov 01, 2007 10:26 pm |
Code: | #include <12F683.h>
#device adc=8
#FUSES PROTECT //Code protected from reads
#FUSES NOBROWNOUT //Reset when brownout detected
//#FUSES FCMEN //Fail-safe clock monitor enabled
#use delay(clock=4000000,RESTART_WDT)
#ZERO_RAM
#define RFOUT PIN_A0
unsigned int8 ii=0;
INT1 k=0;
struct {
unsigned int8 aa;
unsigned int8 bb;
unsigned int8 cc;
unsigned int8 dd;} cmd;
void RF_send(void);
setup_adc(ADC_OFF);
setup_timer_0(RTCC_INTERNAL);
//setup_wdt(WDT_DIV_32768);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ);
cmd.aa = 0x22;
cmd.bb = 0x33;
cmd.cc = 0x44;
cmd.dd = 0x55;
delay_ms(3);
RF_send();
void RF_send()
for(ii=1;ii<=32;++ii) {
if(shift_left(&cmd,4,1))//1
output_high(RFOUT);
delay_us(300);
output_low(RFOUT);
delay_us(600);
else//0
output_high(RFOUT);
delay_us(600);
output_low(RFOUT);
delay_us(300);
what wrong?
i always got 0xffffffff on receiver site...
it should be:
cmd.aa = 0x22;
cmd.bb = 0x33;
cmd.cc = 0x44;
cmd.dd = 0x55;
i need help... ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Thu Nov 01, 2007 11:35 pm |
Post your compiler version. |
abc Guest
Posted: Fri Nov 02, 2007 12:21 am |
compiler version=pcwh 3.249 |
Posted: Fri Nov 02, 2007 12:23 am |
why this always is 1??
any suggestion? |
Posted: Fri Nov 02, 2007 1:32 am |
I installed vs. 3.249 and added the lines shown below in bold to your
program. I then compiled the program and ran it in the MPLAB
simulator. I put a breakpoint on the delay_cycles(1) line. I opened
a Watch Window and watched the 'c' variable. I pressed the F9 key
repeatedly to step through the for() loop. The 'c' variable changed in
this pattern for the first 8 bits:
That's correct.
I also looked at the CCS start-up code that the compiler inserts at
the beginning of main(). It turns off the comparators correctly and
it sets all analog pins to be digital i/o. It also sets up the oscillator
correctly for internal operation. The config bits also look correct.
So, I think you should look at the external connections to your RF
transmitter and also look at the transmitter.
Quote: | void RF_send()
int c;
c = 1;
output_high(RFOUT);
delay_us(300);
output_low(RFOUT);
delay_us(600);
else//0
c = 0;
output_high(RFOUT);
delay_us(600);
output_low(RFOUT);
delay_us(300);
delay_cycles(1); // Put a Breakpoint here.
abc Guest
Posted: Fri Nov 02, 2007 2:57 am |
thanks PCM programmer,
i have tested the rf out using osiloscope,it always :
when
the rf out always is:
output_high(RFOUT);
delay_us(300);
output_low(RFOUT);
delay_us(600);
when
if(shift_left(&cmd,4,0))//0
the output always is:
output_high(RFOUT);
delay_us(600);
output_low(RFOUT);
delay_us(300);
i will test again,
i dont know why it cant point to the address:
cmd.aa = 0x22;
cmd.bb = 0x33;
cmd.cc = 0x44;
cmd.dd = 0x55;
abc Guest
Posted: Fri Nov 02, 2007 3:19 am |
hi, i found the problem, it only work correctlly at first loop, second and so on loop is wrong, how to solve this problem?
delay_ms(3);
RF_send();
first loop ok only.... |
Wayne_
Posted: Fri Nov 02, 2007 6:16 am |
It is because you are shifting in to your 4 byte data array a 1 for each bit you shift out.
To fix it you need to either reset you data for each iteration of the loop or shift back in the value you shifted out! |
