16F628A internal oscilator
jjude
PostPosted: Thu Nov 01, 2007 12:03 pm     Reply with quote
I need internal oscilator.
How i config?
What is frecuence?
Is internal oscilator reliable (or trustworthy? i dont know this word).
Sorry my bad english.
PostPosted: Thu Nov 01, 2007 12:21 pm     Reply with quote
This code will setup the 16F628A for a 4 MHz internal oscillator.
#include <16F628A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
// Put your code here.
SherpaDoug
PostPosted: Thu Nov 01, 2007 1:07 pm     Reply with quote
Lots of people use it so I would say it is reliable within its specifications. For those specifications you should read that section of the datasheet.
PostPosted: Thu Nov 01, 2007 1:37 pm     Reply with quote
The internal oscillator is reliable but there is a large variation in speed between chips. This is no problem for many applications except when you have special timing requirements, for example RS232 will work on some chips and fails on others. Also temperature changes will change the frequency.
