jt06
Does anyone could help me? (Beginner in 18F family) |
Posted: Thu Nov 01, 2007 2:57 am |
Absolute beginner in programming the family PIC 18F.
For starting, I try to have 2 alternatives blinkings LED (one on port A.0 and the second on Port E.0).
This code tested on a 16F877a is OK.
I am not able to migrate this simplest code on a 18F4620 (or a 18F4550)!!!
I think that the problem is in fuse configuration?
Below the fabulous code:
Many thank's in advance for your help.
Regards,
Jo
Quote: | #include <18F4620.H>
#fuses HS,NOWDT,NOPROTECT
#byte portA=0x80 // Port A Address
#byte portE=0x84 // Port E Address
#bit oLed0 = PortA.0
#bit oLed1 = PortE.0
delay_ms(15);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
SET_TRIS_A(0x00); // Port A Output
SET_TRIS_E(0x00); // Port E Output
oLed0 = 0; // LED 0 ON
oLed1 = 1; // LED 1 OFF
oLed0 = 1; // LED 0 OFF
oLed1 = 0; // LED 1 ON
Posted: Thu Nov 01, 2007 3:04 am |
Quote: | #byte portA=0x80 // Port A Address
#byte portE=0x84 // Port E Address |
Look in the PIC data sheet in this section:
Quote: | TABLE 5-1: SPECIAL FUNCTION REGISTER MAP |
Compare the Port addresses above, to the addresses in the data sheet. |
Humberto
Posted: Thu Nov 01, 2007 8:33 am |
If you are a beginner in programing MCU, it is a good practice to read and understand
the manufacturer info published in Datasheets. Are you aware that there is a big
difference between both MCU? Hence it is improbable that the code that was running
in the 16F would run in the 18F. The PIC18F4620 has a complex architecture
compared with the 16F.
It is a good practice to shut down the modules that is not in use.
Most of this is done by the Compiler in background, but as a programmer you are the
responsible of the generated code, not the tools that you are using.
I suggest you to be explicit while coding, do not assume that somebody will do it for you.
Following is an example of what I mean.
#include <18F4620.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV28 //Brownout reset at 2.8V
#FUSES NOLVP //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_high(PIN_A0);
output_low(PIN_E0);
output_toggle(PIN_A0);
output_toggle(PIN_E0);
Humberto |
rnielsen
Posted: Thu Nov 01, 2007 9:56 am |
Plus one thing to know, the set_tris command is useless unless fast_io is stated. At least that's what the help file states. |
SherpaDoug
Posted: Thu Nov 01, 2007 11:38 am |
rnielsen wrote: | Plus one thing to know, the set_tris command is useless unless fast_io is stated. At least that's what the help file states. |
I would say the set_tris command is UNNECESSARY unless you are using fast_io. _________________ The search for better is endless. Instead simply find very good and get the job done. |
jt06
Posted: Sat Nov 03, 2007 1:00 am |
PCM programmer wrote: | Quote: | #byte portA=0x80 // Port A Address
Many thank's for that.
Regards |
jt06
Posted: Sat Nov 03, 2007 2:20 am |
Thanks to everyone |
