while ( input(PIN_B0) ) is it a good idea ? Also a ADC ?
zonemikel
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Tue Oct 23, 2007 8:17 pm     Reply with quote
In case anyone remembers me thanks for your help. I got rs232 to work.
I was wanting to have a sort of "switch" in my program so if i have high or low to a certain pin it would do something it does not normally do. For instance
if ( input(PIN_B0) ) {
// do something extra that you were not doing already
Is this a good way of doing things? If it is a good way of doing things should i make the "switch" go to ground or to hot ? if( !input(PIN_B0) ) or
if( input(PIN_B0) ). Ive been experimenting with it a bit and it seems that if i have if( !input(PIN_B0) ) and its not grounded it sometimes executes.
also for a pic 877a and #device adc=8 is this the correct way to convert from the adc number to a float number that represents the voltage? I always get about +.10 more than i should.
//declartations (at the top)
   int16 adc_value;
   float volts;
// a little further down
adc_value = read_adc();
volts = (float)(adc_value * 5)/1023.0;   // convert to volts
Tia
PostPosted: Tue Oct 23, 2007 10:35 pm     Reply with quote
See this post for links to schematics which show how to connect a switch
to a PIC.
http://www.ccsinfo.com/forum/viewtopic.php?t=21958&start=1
Here is a routine that waits for you to press the switch. It handles
debouncing the switch.
http://www.ccsinfo.com/forum/viewtopic.php?t=19874&start=1
#device adc=8 will produce values from 0 to 255. That won't work
properly with the code given above. It expects you to use
#device adc=10, which will produce values from 0 to 1023.
I think you got that code from here:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
If you look at that program, it does use #device adc=10.
rnielsen
PostPosted: Wed Oct 24, 2007 8:58 am     Reply with quote
Take a look at the debounce code I posted a while back.
http://www.ccsinfo.com/forum/viewtopic.php?t=24103
zonemikel
PostPosted: Fri Oct 26, 2007 9:10 pm     Reply with quote
Look at this schematic. He has 1K pullup resistors on RA0-RA2.
Each pin also goes to a switch, and the other side of the switches
go to ground. You don't need to use 1K. I would have used 4.7K
or 10K resistors.
http://www.vermontficks.org/pellets.gif
I went off of this code and suggestion. I used a 10K resistor like this
gnd
 sw------------------
+5V------/\/\/\/\-------PicPin C3
so the 10K resistor goes from 5v to the pic pin, at this same point there is a wire that goes to a two pin header and on the other side of the two pin header is gnd.
When i read the pin with a volt meter there is like no Voltage. Is the 10K resistor too much ? Isnt it supposed to be high until you hit the switch it goes to ground ?
jecottrell
PostPosted: Sat Oct 27, 2007 9:08 am     Reply with quote
Yes, that should work.
I'm not sure of your meter's ability (Z) to measure the voltage. I would try some tests with code to see if the PIC is detecting the change in voltage w/ the switch press. If that doesn't check good I'd look for shorts/bad connections.
Humberto
PostPosted: Sat Oct 27, 2007 10:27 am     Reply with quote
With a 10K resistor connected as you shown, you should read +5V -even with a chinnesse
$10 multimeter- unless such pin was set as an output LOW.
Humberto
