nach
File 12HV615.h |
Posted: Tue Oct 23, 2007 1:28 pm |
Hi..
I'm working with ccs and the PIC12HV615...but my CCS compiler doesn't have the file 12HV615.h in its data base of devides ...It's possible???
(i can't remenber the version but my compiler isn't old)
Please, Who has it?
many thanks...
/nacho |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Wed Oct 24, 2007 12:32 am |
I have this file. I have compiler version v4.057. I do not know at which compiler version the file appeared.
As far as I know it is not allowed to exchange the CCS libraries.
So my advice is to update your compiler.
(see also: http://www.ccsinfo.com/forum/viewtopic.php?t=26245 point 10) |
Posted: Wed Oct 24, 2007 2:13 am |
This file is not a 'library'. It i just a simple 'include' file, containing defintions used by the internal functions. You can create these yourself easily, but they won't give you support for another processor.
Repeat after me:
"Adding the .h file for a processor, _will not_ add support for that processor to the compiler".
The actual support for the processor, is in the 'devices.dat' file.
You _can_ add an extra chip to this yourself (if you are using the 'windowed' compiler), using device editor, but if you want a compiler with a latter chip included, I'm afraid the only solution is to buy a latter compiler version.
