nocturno
USB in 18F2450 |
Posted: Sat Oct 20, 2007 12:07 am |
Hello, I'm trying to connect a PIC18F2450 by USB with EX_USB_SERIAL.C example, but he didn't work.
If I try with 18F2550 the example works fine.
If I try with 18F2450 the USB don't work.
If I try with 18F2450 with the 18F2550's firmware, Windows detect an Unknown device.
I try a lot of combinations without success, can you help me?
Hola, estoy practicando la conexión USB con un PIC18F2450 y el ejemplo EX_USB_SERIAL.C sin éxito.
Si pongo un 18F2550 consigo que funcione sin ningún problema.
Si pongo un 18F2450 el usb no funciona.
Si a un 18F2450 le grabo el programa compilado para 18F2550, consigo que aparezca "Dispositivo desconocido" en Windows.
Realmente he hecho muchas pruebas y ya no sé cómo continuar, ¿alguna ayuda?
Gracias _________________ http://www.micropic.es |
Posted: Sun Oct 21, 2007 9:32 am |
The 2450, and the 2550, are _not_ 'close equivalent' chips, where it may be possible to run the code from one in the other. The oscillator configurations are slightly different, (a probable cause of things not working), and there are differences in the peripherals supported, which again make operation with the transferred code unlikely to work...
I'd look first at the oscillator. This would cause an 'unknown device' error, since the USB host, will detect the resistor loads, and the 'presence' of the peripheral, but will not get a valid response. Also, the 2450, is slightly more prone to being 'fussy' about the capacitance on the Vusb pin (the 2550 is better in this regard...). Use a polyster, or ceramic 0.2 to 0.47uF, paralleled with something like perhaps a 4.7uF electrolytic.
nocturno
Posted: Fri Oct 26, 2007 2:16 pm |
Finally I have solved the problem. It's a bug in pic18_usb.h only for 18F2450 PIC model.
The file with solution is:
Code: | /////////////////////////////////////////////////////////////////////////
//// pic18_usb.c ////
//// Hardware layer for CCS's USB library. This hardware layer ////
//// supports the USB peripheral on the PIC18 family chips. Current ////
//// supported families are: ////
//// PIC18F2455/2550/4455/4550 ////
//// PIC18F2450/4450 ////
//// PIC18F65J50/66J50/66J55/67J50/85J50/86J50/86J55/87J50 ////
//// This file is part of CCS's PIC USB driver code, which includes: ////
//// usb_desc_*.h - an example set of config and device descriptor ////
//// usb.c - USB token and request handler code ////
//// usb.h - definitions, prototypes and global variables ////
//// The following examples are provided by CCS: ////
//// ex_usb_mouse.c - A HID Mouse. ////
//// ex_usb_hid.c - A custom application using HID protocol. ////
//// ex_usb_kbmouse.c - A HID Mouse/Keyboard combo using multiple ////
//// interfaces. ////
//// ex_usb_kbmouse2.c - A HID Mouse/Keyboard combo using multiple ////
//// HID Reports. ////
//// ex_usb_scope.c - A digital oscilloscope using a custom ////
//// protocol requiring custom Windows drivers. ////
//// ex_usb_serial.c - ////
//// ex_usb_serial2.c - Two examples of using the CDC driver for ////
//// a virtual COM port. ////
//// *********** NOTE ABOUT 18F2450/4450 LIMITATIONS ********** ////
//// Due to the limited USB RAM of this family, a limitation of ////
//// this driver is that there are only 3 endpoints (0, 1 and 2). ////
//// The HW actually supports more endpoints, but to simplify ////
//// driver development this driver will only support the first 3 ////
//// so there is an easier memory block to work with. ////
//// USB_MAX_EP0_PACKET_LENGTH will also be set to 8 regardless ////
//// of USB speed, to save RAM. ////
//// ************** NOTE ABOUT HW REQUIREMENTS **************** ////
//// If you are not using internal pullups, you will need to put ////
//// an internal pullup resistor on C4 or C5 depending on if you ////
//// want to use slow speed or full speed. This code configures ////
//// the device to use internal pullups, see usb_init() if you ////
//// want to change that. ////
//// You need approximately 470nF cap on C3, even if you are using ////
//// the internal 3.3V USB regulator. ////
//// To run at full speed, you must use the oscillator ////
//// configuration (PLLx) to set the PLL divide to 4MHz. You can ////
//// configure the MCU clock to any speed (up to 48MHz) but the ////
//// PLL must run at 4Mhz to provide the USB peripheral with a ////
//// 96MHz clock. See the datasheet for details. ////
//// To run at slow speed you must configure your MCU to run at ////
//// 24Mhz. See the datasheet for details. ////
//// **************** NOTE ABOUT INTERRUPTS ****************** ////
//// This driver uses INT_USB. It requires INT_USB to interrupt the ////
//// PIC when an event has happened on the USB Bus. Therfore ////
//// this code enables interrupts. A user modification can be made ////
//// to poll the USB interrupt flag instead of relying on an ////
//// interrupt. ////
//// **************** USER FUNCTIONS *********************** ////
//// usb_init() - Initializes the USB stack, the USB peripheral and ////
//// attaches the unit to the usb bus. Enables ////
//// interrupts. ////
//// usb_init_cs() - A smaller usb_init(), does not attach unit ////
//// to usb bus or enable interrupts. ////
//// usb_put_packet() - Sends one packet to the host. ////
//// If you need to send a message that spans ////
//// more than one packet then see usb_puts() in ////
//// usb.c ////
//// usb_kbhit() - Returns true if OUT endpoint contains data from ////
//// host. ////
//// usb_rx_packet_size() - Returns the size of packet that was ////
//// received. usb_kbhit() must return TRUE else ////
//// this is not valid. Don't forget in USB there ////
//// are 0 len packets! ////
//// usb_get_packet() - Gets one packet that from the host. ////
//// usb_kbhit() must return true before you call ////
//// this routine or your data may not be valid. ////
//// Once usb_kbhit() returns true you want to ////
//// call this as soon as possible to get data ////
//// out of the endpoint buffer so the PC can ////
//// start sending more data, if needed. ////
//// This only receives one packet, if you are ////
//// trying to receive a multi-packet message ////
//// see usb_gets() in usb.c. ////
//// usb_detach() - De-attach USB from the system. ////
//// usb_attach() - Attach USB to the system. ////
//// usb_attached() - Returns TRUE if the device is attached to a ////
//// USB cable. A macro that looks at the defined ////
//// connection sense pin. ////
//// usb_task() - Keeps track of connection sense, calling ////
//// usb_detach() and usb_attach() when needed. ////
//// For more documentation on these functions read the comments at ////
//// each function. ////
//// The other functions defined in this file are for use by the ////
//// USB code, and is not meant to be used by the user. ////
//// Version History: ////
//// 07-17-07: Added 18F4450,2450 support ////
//// 07-13-07: Added 87J50 family support ////
//// 11-01-05: usb_detach(), usb_attach() and usb_init_cs() ////
//// changed for the better. ////
//// 10-28-05: Added usb_rx_packet_size() ////
//// 07-13-05: usb_put_packet() changed for 16bit packet sizes ////
//// usb_flush_in() changed for 16bit packet sizes ////
//// usb_get_packet() changed for 16bit packet sizes ////
//// usb_flush_out() changed for 16bit packet sizes ////
//// usb_set_configured() changed for 16bit packet sizes ////
//// 06-30-05: usb_tbe() added ////
//// The way endpoint 0 DTS is set has been changed. ////
//// 06-20-05: Initial Release ////
//// 05-13-05: Beta Release (Full Speed works) ////
//// 03-21-05: Initial Alpha Release ////
//// (C) Copyright 1996,2005 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#IFNDEF __USB_HARDWARE__
#DEFINE __USB_HARDWARE__
//let the USB Stack know that we are using a PIC with internal USB peripheral
#DEFINE __PIC__ 1
#if ((getenv("DEVICE")=="PIC18F87J50") || (getenv("DEVICE")=="PIC18F86J55") || (getenv("DEVICE")=="PIC18F86J50") || (getenv("DEVICE")=="PIC18F85J50") || (getenv("DEVICE")=="PIC18F67J50") || (getenv("DEVICE")=="PIC18F66J55") || (getenv("DEVICE")=="PIC18F66J50") || (getenv("DEVICE")=="PIC18F65J50"))
#define __USB_87J50__
#define USB_TOTAL_BUFFER_SPACE ((int16)getenv("RAM")-0x500)
#define USB_MAX_NUM_ENDPOINTS 16
#elif ((getenv("DEVICE")=="PIC18F2450") || (getenv("DEVICE")=="PIC18F4450"))
#define __USB_4450__
#if (USB_EP3_TX_SIZE+USB_EP3_RX_SIZE+USB_EP4_TX_SIZE+USB_EP4_RX_SIZE+USB_EP5_TX_SIZE+USB_EP5_RX_SIZE+USB_EP6_TX_SIZE+USB_EP6_RX_SIZE+USB_EP7_TX_SIZE+USB_EP7_RX_SIZE+USB_EP8_TX_SIZE+USB_EP8_RX_SIZE+USB_EP9_TX_SIZE+USB_EP9_RX_SIZE+USB_EP10_TX_SIZE+USB_EP10_RX_SIZE+USB_EP11_TX_SIZE+USB_EP11_RX_SIZE+USB_EP12_TX_SIZE+USB_EP12_RX_SIZE+USB_EP13_TX_SIZE+USB_EP13_RX_SIZE+USB_EP14_TX_SIZE+USB_EP14_RX_SIZE+USB_EP15_TX_SIZE+USB_EP15_RX_SIZE)>0
#error This driver only supports endpoints 0, 1 and 2 for this chip.
#define USB_MAX_NUM_ENDPOINTS 3
#define USB_TOTAL_BUFFER_SPACE (0x100 - USB_MAX_NUM_ENDPOINTS*8)
#else
#define __USB_4550__
#define USB_TOTAL_BUFFER_SPACE ((int16)0x300)
#ifndef USB_USE_FULL_SPEED
#define USB_USE_FULL_SPEED TRUE
#ifndef USB_CON_SENSE_PIN
#define USB_CON_SENSE_PIN 0
#if defined(__USB_4450__)
#define USB_MAX_EP0_PACKET_LENGTH 8
#else
#if USB_USE_FULL_SPEED==FALSE
//slow speed requires 8byte max packet size for endpoint 0
#DEFINE USB_MAX_EP0_PACKET_LENGTH 8
#else
//for full speed you can still use 8bytes, but 64 will be faster
#DEFINE USB_MAX_EP0_PACKET_LENGTH 64
#INCLUDE <usb.h>
#define USB_BUFFER_NEEDED (USB_EP0_TX_SIZE+USB_EP0_RX_SIZE+USB_EP1_TX_SIZE+USB_EP1_RX_SIZE+USB_EP2_TX_SIZE+USB_EP2_RX_SIZE+USB_EP3_TX_SIZE+USB_EP3_RX_SIZE+USB_EP4_TX_SIZE+USB_EP4_RX_SIZE+USB_EP5_TX_SIZE+USB_EP5_RX_SIZE+USB_EP6_TX_SIZE+USB_EP6_RX_SIZE+USB_EP7_TX_SIZE+USB_EP7_RX_SIZE+USB_EP8_TX_SIZE+USB_EP8_RX_SIZE+USB_EP9_TX_SIZE+USB_EP9_RX_SIZE+USB_EP10_TX_SIZE+USB_EP10_RX_SIZE+USB_EP11_TX_SIZE+USB_EP11_RX_SIZE+USB_EP12_TX_SIZE+USB_EP12_RX_SIZE+USB_EP13_TX_SIZE+USB_EP13_RX_SIZE+USB_EP14_TX_SIZE+USB_EP14_RX_SIZE+USB_EP15_TX_SIZE+USB_EP15_RX_SIZE)
#if (USB_BUFFER_NEEDED > USB_TOTAL_BUFFER_SPACE)
#error You are trying to allocate more memory for endpoints than the PIC can handle
#reserve 0x400:0x4FF
#else
#reserve 0x400:0x4FF+USB_BUFFER_NEEDED
#define debug_usb(a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z)
//#define debug_usb printf
//#define debug_putc putc_tbe
#define debug_display_ram(x,y)
void debug_display_ram(int8 len, int8 *ptr) {
int8 max=16;
debug_usb(debug_putc,"%U - ",len);
if (max>len) {max=len;}
while(max--) {
debug_usb(debug_putc,"%X",*ptr);
len--;
ptr++;
if (len) {debug_usb(debug_putc,"...");}
//if you are worried that the PIC is not receiving packets because a bug in the
//DATA0/DATA1 synch code, you can set this to TRUE to ignore the DTS on
//receiving.
#ifndef USB_IGNORE_RX_DTS
#define USB_IGNORE_RX_DTS FALSE
#ifndef USB_IGNORE_TX_DTS
#define USB_IGNORE_TX_DTS FALSE
//if you enable this it will keep a counter of the 6 possible errors the
//pic can detect. disabling this will save you ROM, RAM and execution time.
#ifndef USB_USE_ERROR_COUNTER
#define USB_USE_ERROR_COUNTER FALSE
#define USB_PING_PONG_MODE_OFF 0 //no ping pong
#define USB_PING_PONG_MODE_E0 1 //ping pong endpoint 0 only
#define USB_PING_PONG_MODE_ON 2 //ping pong all endpoints
//NOTE - PING PONG MODE IS NOT SUPPORTED BY CCS!
#ifndef USB_PING_PONG_MODE
#define USB_PING_PONG_MODE USB_PING_PONG_MODE_OFF
#if USB_USE_ERROR_COUNTER
int ERROR_COUNTER[6];
//---pic18fxx5x memory locations
//#if defined(__USB_4550__)
#byte UFRML = 0xF66
#byte UFRMH = 0xF67
#byte UIR = 0xF68
#byte UIE = 0xF69
#byte UEIR = 0xF6A
#byte UEIE = 0xF6B
#byte USTAT = 0xF6C
#byte UCON = 0xF6D
#byte UADDR = 0xF6E
#byte UCFG = 0xF6F
#define UEP0_LOC 0xF70
/*#else
#byte UFRML = 0xF60
#byte UFRMH = 0xF61
#byte UIR = 0xF62
#byte UIE = 0xF5C
#byte UEIR = 0xF63
#byte UEIE = 0xF5D
#byte USTAT = 0xF64
#byte UCON = 0xF65
#byte UADDR = 0xF5E
#byte UCFG = 0xF5F
#define UEP0_LOC 0xF4C
#byte UEP0 = UEP0_LOC
//#define USB_BUFFER (0x400 + (USB_MAX_NUM_ENDPOINTS*8))
#define USB_BUFFER 0x418 //if you have an old compiler you will need to use this
#else
#define USB_BUFFER 0x500
#byte BD0STAT = 0x400
#byte BD0CNT = 0x401
#byte BD0ADRL = 0x402
#byte BD0ADRJ = 0x403
#define BD0STAT_LOC 0x400
#define BD0CNT_LOC 0x401
#define BD0ADRL_LOC 0x402
#define BD0ADRH_LOC 0x403
#define UEP(x) *(UEP0_LOC+x)
#BIT UIR_SOF = UIR.6
#BIT UIR_STALL = UIR.5
#BIT UIR_IDLE = UIR.4
#BIT UIR_TRN = UIR.3
#BIT UIR_ACTV = UIR.2
#BIT UIR_UERR = UIR.1
#BIT UIR_URST = UIR.0
#BIT UIE_SOF = UIE.6
#BIT UIE_STALL = UIE.5
#BIT UIE_IDLE = UIE.4
#BIT UIE_TRN = UIE.3
#BIT UIE_ACTV = UIE.2
#BIT UIE_UERR = UIE.1
#BIT UIE_URST = UIE.0
#bit UCON_PBRST=UCON.6
#bit UCON_SE0=UCON.5
#bit UCON_PKTDIS=UCON.4
#bit UCON_USBEN=UCON.3
#bit UCON_RESUME=UCON.2
#bit UCON_SUSPND=UCON.1
#if (USB_PING_PONG_MODE==USB_PING_PONG_MODE_OFF)
#define EP_BDxST_O(x) *(BD0STAT_LOC + x*8)
#define EP_BDxCNT_O(x) *(BD0CNT_LOC + x*8)
#define EP_BDxADR_O(x) *(int16 *)(BD0ADRL_LOC + x*8)
#define EP_BDxST_I(x) *(BD0STAT_LOC + 4 + x*8)
#define EP_BDxCNT_I(x) *(BD0CNT_LOC + 4 + x*8)
#define EP_BDxADR_I(x) *(int16 *)(BD0ADRL_LOC + 4 + x*8)
#else
#error Right now this driver only supports no ping pong
//See UEPn (0xF70-0xF7F)
#define ENDPT_DISABLED 0x00 //endpoint not used
#define ENDPT_IN_ONLY 0x02 //endpoint supports IN transactions only
#define ENDPT_OUT_ONLY 0x04 //endpoint supports OUT transactions only
#define ENDPT_CONTROL 0x06 //Supports IN, OUT and CONTROL transactions - Only use with EP0
#define ENDPT_NON_CONTROL 0x0E //Supports both IN and OUT transactions
//Define the states that the USB interface can be in
enum {USB_STATE_DETACHED=0, USB_STATE_ATTACHED=1, USB_STATE_POWERED=2, USB_STATE_DEFAULT=3,
USB_STATE_ADDRESS=4, USB_STATE_CONFIGURED=5} usb_state=0;
//--BDendST has their PIDs upshifed 2
#define USB_PIC_PID_IN 0x24 //device to host transactions
#define USB_PIC_PID_OUT 0x04 //host to device transactions
#define USB_PIC_PID_SETUP 0x34 //host to device setup transaction
#define USTAT_IN_E0 4
#define USTAT_OUT_SETUP_E0 0
#define __USB_UIF_RESET 0x01
#define __USB_UIF_ERROR 0x02
#define __USB_UIF_ACTIVE 0x04
#define __USB_UIF_TOKEN 0x08
#define __USB_UIF_IDLE 0x10
#define __USB_UIF_STALL 0x20
#define __USB_UIF_SOF 0x40
#define STANDARD_INTS 0x3F
#else
#define STANDARD_INTS 0x3D
#define __USB_UCFG_UTEYE 0x80
#define __USB_UCFG_UOEMON 0x40
#define __USB_UCFG_UPUEN 0x10
#define __USB_UCFG_UTRDIS 0x08
#define __USB_UCFG_FSEN 0x04
#define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | __USB_UCFG_FSEN | USB_PING_PONG_MODE)
#else
#define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | USB_PING_PONG_MODE);
#define __UCFG_VAL_DISABLED__ 0x08
char usb_ep0_rx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_rx_buffer=USB_BUFFER
char usb_ep0_tx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_tx_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH
char usb_data_buffer[USB_TOTAL_BUFFER_SPACE-USB_MAX_EP0_PACKET_LENGTH-USB_MAX_EP0_PACKET_LENGTH];
#locate usb_data_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH+USB_MAX_EP0_PACKET_LENGTH
int8 __setup_0_tx_size;
//interrupt handler, specific to PIC18Fxx5x peripheral only
void usb_handle_interrupt();
void usb_isr_rst();
void usb_isr_uerr();
void usb_isr_sof(void);
void usb_isr_activity();
void usb_isr_uidle();
void usb_isr_tok_dne();
void usb_isr_stall(void);
void usb_init_ep0_setup(void);
//following functions standard part of CCS PIC USB driver, and used by usb.c
void usb_init();
void usb_detach();
int1 usb_put_packet(int endpoint, int * ptr, int16 len, USB_DTS_BIT tgl);
int1 usb_flush_in(int8 endpoint, int16 len, USB_DTS_BIT tgl); //marks the transmit buffer as ready for transmission
int16 usb_get_packet(int8 endpoint, int8 * ptr, int16 max);
int16 usb_rx_packet_size(int8 endpoint);
int16 usb_get_packet_buffer(int8 endpoint, int8 *ptr, int16 max);
void usb_flush_out(int8 endpoint, USB_DTS_BIT tgl);
void usb_stall_ep(int8 endpoint);
void usb_unstall_ep(int8 endpoint);
int1 usb_endpoint_stalled(int8 endpoint);
void usb_set_address(int8 address);
void usb_set_configured(int config);
void usb_disable_endpoints(void);
//// BEGIN User Functions:
/* usb_attached()
/* Summary: Returns TRUE if the device is attached to a USB cable
#if USB_CON_SENSE_PIN
#define usb_attached() input(USB_CON_SENSE_PIN)
#else
#define usb_attached() TRUE
/* usb_detach()
/* Summary: Remove the D+/D- lines from the USB bus. Basically, disable USB.
void usb_detach(void) { //done
UCON=0; //disable USB hardware
UIE=0; //disable USB interrupts
UCFG = __UCFG_VAL_DISABLED__;
set_tris_c(*0xF94 | 0x30);
usb_state=USB_STATE_DETACHED;
usb_token_reset(); //clear the chapter9 stack
__usb_kbhit_status=0;
/* usb_attach()
/* Summary: Attach the D+/D- lines to the USB bus. Enable the USB peripheral.
/* You should wait until UCON_SE0 is clear before enabling reset/idle interrupt
void usb_attach(void) {
usb_token_reset();
UCON = 0;
UCFG = __UCFG_VAL_ENABLED__;
UIE = 0; // Mask all USB interrupts
UCON_USBEN = 1; // Enable module & attach to bus
usb_state = USB_STATE_ATTACHED; // Defined in usbmmap.c & .h
/* usb_init_cs()
/* Summary: Resets and initalizes USB peripheral. Does not attach the peripheral
/* to the USB bus. See usb_attach() and usb_task() on how to
/* attach to the USB bus.
/* You must call this before any other USB code.
/* NOTE: an alternative function, usb_init(), is provided that
/* initializes the USB and then connects.
#define usb_init_cs usb_detach
/* usb_task()
/* Summary: Keeps an eye on the connection sense pin to determine if we are
/* attached to a USB cable or not. If we are attached to a USB cable,
/* initialize the USB peripheral if needed. If we are disconnected
/* from the USB cable, disable the USB peripheral.
/* NOTE: If you are not using a connection sense pin, will automatically
/* enable the USB peripheral.
/* NOTE: this enables interrupts once the USB peripheral is ready
void usb_task(void) {
if (usb_attached()) {
if (UCON_USBEN==0) {
debug_usb(debug_putc, "\r\n\nUSB TASK: ATTACH");
usb_attach();
else {
if (UCON_USBEN==1) {
debug_usb(debug_putc, "\r\n\nUSB TASK: DE-ATTACH");
usb_detach();
if ((usb_state == USB_STATE_ATTACHED)&&(!UCON_SE0)) {
UIR=0;
UIE=0;
enable_interrupts(INT_USB);
UIE=__USB_UIF_IDLE | __USB_UIF_RESET; //enable IDLE and RESET USB interrupt
usb_state=USB_STATE_POWERED;
debug_usb(debug_putc, "\r\n\nUSB TASK: POWERED");
/* usb_init()
/* Summary: Resets and initalizes USB hardware. You must call this first before
/* using code. Will attach the USB periperhal to the USB bus.
/* NOTE: If you are using a connection sense pin, this will wait in
/* an infinite loop until the device is connected to a USB cable.
/* NOTE: If you are not using a connection sense pin, this will wait
/* in an infinte loop until the SE0 condition clears, which usually
/* doesn't take long
/* NOTE: this enables interrupts.
void usb_init(void) {
usb_init_cs();
do {
usb_task();
} while (usb_state != USB_STATE_POWERED);
/* usb_flush_in()
/* Input: endpoint - which endpoint to mark for transfer
/* len - length of data that is being tramsferred
/* tgl - Data toggle synchronization for this packet
/* Output: TRUE if success, FALSE if error (we don't control the endpoint)
/* Summary: Marks the endpoint ready for transmission. You must
/* have already loaded the endpoint buffer with data.
/* (IN is PIC -> PC)
int1 usb_flush_in(int8 endpoint, int16 len, USB_DTS_BIT tgl) {
int8 i;
debug_usb(debug_putc,"\r\nPUT %X %U %LU",endpoint, tgl, len);
i=EP_BDxST_I(endpoint);
if (!bit_test(i,7)) {
EP_BDxCNT_I(endpoint)=len;
debug_display_ram(len, EP_BDxADR_I(endpoint));
#if USB_IGNORE_TX_DTS
i=0x80;
#else
if (tgl == USB_DTS_TOGGLE) {
if (bit_test(i,6))
tgl=USB_DTS_DATA0; //was DATA1, goto DATA0
tgl=USB_DTS_DATA1; //was DATA0, goto DATA1
else if (tgl == USB_DTS_USERX) {
i=EP_BDxST_O(endpoint);
if (bit_test(i,6))
tgl=USB_DTS_DATA1;
tgl=USB_DTS_DATA0;
if (tgl == USB_DTS_DATA1) {
i=0xC8; //DATA1, UOWN
else if (tgl == USB_DTS_DATA0) {
i=0x88; //DATA0, UOWN
//set BC8 and BC9
if (bit_test(len,8)) {bit_set(i,0);}
if (bit_test(len,9)) {bit_set(i,1);}
debug_usb(debug_putc," %X",i);
EP_BDxST_I(endpoint)=i;//save changes
return(1);
else {
debug_usb(debug_putc,"\r\nPUT ERR");
return(0);
/* usb_put_packet(endpoint,*ptr,len,toggle)
/* Input: endpoint - endpoint to send packet to
/* ptr - points to data to send
/* len - amount of data to send
/* toggle - whether to send data with a DATA0 pid, a DATA1 pid, or toggle from the last DATAx pid.
/* Output: TRUE if data was sent correctly, FALSE if it was not. The only reason it will
/* return FALSE is if because the TX buffer is still full from the last time you
/* tried to send a packet.
/* Summary: Sends one packet out the EP to the host. Notice that there is a difference
/* between a packet and a message. If you wanted to send a 512 byte message you
/* would accomplish this by sending 8 64-byte packets, followed by a 0 length packet.
/* If the last (or only packet) being sent is less than the max packet size defined
/* in your descriptor then you do not need to send a 0 length packet to identify
/* an end of message.
/* usb_puts() (provided in usb.c) will send a multi-packet message correctly.
int1 usb_put_packet(int8 endpoint, int8 * ptr, int16 len, USB_DTS_BIT tgl) { //done
int16 j;
int8 i;
int8 * buff_add;
buff_add=EP_BDxADR_I(endpoint);
for (j=0;j<len;j++) {
*buff_add=*ptr;
buff_add++;
ptr++;
return(usb_flush_in(endpoint, len, tgl));
else {
return(0);
/// END User Functions
/// BEGIN Hardware layer functions required by USB.C
/* usb_flush_out()
/* tgl - Data toggle synchronization to expect in the next packet
/* Output: NONE
/* Summary: Clears the previously received packet, and then marks this
/* endpoint's receive buffer as ready for more data.
/* (OUT is PC -> PIC)
void usb_flush_out(int8 endpoint, USB_DTS_BIT tgl) {
int8 i;
int16 len;
#if USB_IGNORE_RX_DTS
if (tgl == USB_DTS_STALL) {
debug_usb(debug_putc, '*');
i=0x84;
EP_BDxST_I(endpoint)=0x84;
return;
i=0x80;
#else
if (bit_test(i,6))
i=0x84;
EP_BDxST_I(endpoint)=0x84; //stall both in and out endpoints
else if (tgl == USB_DTS_DATA1) {
bit_clear(__usb_kbhit_status,endpoint);
len=usb_ep_rx_size[endpoint];
EP_BDxCNT_O(endpoint)=len;
EP_BDxST_O(endpoint)=i;
int16 usb_rx_packet_size(int8 endpoint) {
return(EP_BDxCNT_O(endpoint));
/* usb_get_packet_buffer(endpoint, *ptr, max)
/* Input: endpoint - endpoint to get data from
/* ptr - where to save data to local PIC RAM
/* max - max amount of data to receive from buffer
/* Output: the amount of data taken from the buffer.
/* Summary: Gets a packet of data from the USB buffer and puts into local PIC RAM.
/* Does not mark the endpoint as ready for more data. Once you are
/* done with data, call usb_flush_out() to mark the endpoint ready
/* to receive more data.
int16 usb_get_packet_buffer(int8 endpoint, int8 *ptr, int16 max) {
int8 * al;
int8 st;
int16 i;
al=EP_BDxADR_O(endpoint);
i=EP_BDxCNT_O(endpoint);
st=EP_BDxST_O(endpoint);
//read BC8 and BC9
if (bit_test(st,0)) {bit_set(i,8);}
if (bit_test(st,1)) {bit_set(i,9);}
if (i<max) {max=i;}
i=0;
while (i<max) {
*ptr=*al;
ptr++;
al++;
i++;
return(max);
/* usb_get_packet(endpoint, *ptr, max)
/* NOTE - IF THERE IS NO PACKET TO GET YOU WILL GET INVALID RESULTS!
/* VERIFY WITH USB_KBHIT() BEFORE YOU CALL USB_GET_PACKET()!
/* Until you call usb_get_packet() the data will sit in the endpoint
/* buffer and the PC will get NAKs when it tries to write more data
/* to the endpoint.
int16 usb_get_packet(int8 endpoint, int8 * ptr, int16 max) {
max=usb_get_packet_buffer(endpoint,ptr,max);
usb_flush_out(endpoint, USB_DTS_TOGGLE);
return(max);
/* usb_tbe(endpoint)
/* Input: endpoint - endpoint to check
/* Output: returns TRUE if this endpoint's IN buffer (PIC-PC) is empty and ready
/* returns FALSE if this endpoint's IN buffer is still processing the last
/* transmit or if this endpoint is invalid.
int8 usb_tbe(int8 endpoint) {
int8 st;
st=EP_BDxST_I(endpoint);
if (!bit_test(st,7))
return(TRUE);
return(FALSE);
/* usb_stall_ep(endpoint,direction)
/* Input: endpoint - endpoint to stall.
/* top most bit indicates direction (set is IN, clear is OUT)
/* Summary: Stalls specified endpoint. If endpoint is stalled it will send STALL packet
/* if the host tries to access this endpoint's buffer.
/* NOTE: WE ASSUME ENDPOINT IS VALID. USB.C SHOULD CHECK THIS
void usb_stall_ep(int8 endpoint) { //done
int1 direction;
direction=bit_test(endpoint,7);
endpoint&=0x7F;
if (direction) {
else {
EP_BDxST_O(endpoint)=0x84;
/* usb_unstall_ep(endpoint, direction)
/* Input: endpoint - endpoint to un-stall.
/* Summary: Un-stalls endpoint.
void usb_unstall_ep(int8 endpoint) { //done
int1 direction;
endpoint&=0x7F;
if (direction) {
EP_BDxST_I(endpoint)=0x80;
#else
EP_BDxST_I(endpoint)=0x88;
else {
EP_BDxST_O(endpoint)=0x00;
/* usb_endpoint_stalled(endpoint)
/* Output: returns a TRUE if endpoint is stalled, FALSE if it is not.
/* Summary: Looks to see if an endpoint is stalled, or not. Does not look to
/* see if endpoint has been issued a STALL, just whether or not it is
/* configured to STALL on the next packet. See Set_Feature and Clear_Feature
/* Chapter 9 requests.
int1 usb_endpoint_stalled(int8 endpoint) { //done
int1 direction;
int8 st;
endpoint&=0x7F;
if (direction) {
else {
return(bit_test(st,7) && bit_test(st,2));
/* usb_set_address(address)
/* Input: address - address the host specified that we use
/* Summary: Configures the USB Peripheral for the specified device address. The host
/* will now talk to use with the following address.
void usb_set_address(int8 address) { //done
UADDR=address;
if (address) {
usb_state=USB_STATE_ADDRESS;
else {
/* usb_set_configured(config)
/* Input: config - Configuration to use. 0 to uncofigure device.
/* Summary: Configures or unconfigures device. If configuring device it will
/* enable all the endpoints the user specified for this configuration.
/* If un-configuring device it will disable all endpoints.
/* NOTE: CCS only provides code to handle 1 configuration.
void usb_set_configured(int config) {
int8 en;
int16 addy;
int8 new_uep;
int16 len;
int8 i;
if (config==0) {
//if config=0 then set addressed state
usb_disable_endpoints();
else {
usb_state=USB_STATE_CONFIGURED; //else set configed state
addy=(int16)USB_BUFFER+(2*USB_MAX_EP0_PACKET_LENGTH);
for (en=1;en<16;en++) {
new_uep=0;
if (usb_ep_rx_type[en]!=USB_ENABLE_DISABLED) {
new_uep=0x04;
len=usb_ep_rx_size[en];
EP_BDxCNT_O(en)=len;
EP_BDxADR_O(en)=addy;
addy+=usb_ep_rx_size[en];
i=0x80;
#else
i=0x88;
EP_BDxST_O(en)=i;
if (usb_ep_tx_type[en]!=USB_ENABLE_DISABLED) {
new_uep|=0x02;
EP_BDxADR_I(en)=addy;
addy+=usb_ep_tx_size[en];
EP_BDxST_I(en)=0x40;
if (new_uep==0x06) {new_uep=0x0E;}
if (usb_ep_tx_type[en]!=USB_ENABLE_ISOCHRONOUS) {
new_uep|=0x10;
UEP(en)=new_uep;
/// END Hardware layer functions required by USB.C
/// BEGIN USB Interrupt Service Routine
/* usb_handle_interrupt()
/* Summary: Checks the interrupt, and acts upon event. Processing finished
/* tokens is the majority of this code, and is handled by usb.c
/* NOTE: If you wish to change to a polling method (and not an interrupt method),
/* then you must call this function rapidly. If there is more than 10ms
/* latency the PC may think the USB device is stalled and disable it.
/* To switch to a polling method, remove the #int_usb line above this fuction.
/* Also, goto usb_init() and remove the code that enables the USB interrupt.
#int_usb
void usb_isr() {
if (usb_state==USB_STATE_DETACHED) return; //should never happen, though
if (UIR) {
debug_usb(debug_putc,"\r\n\n[%X] ",UIR);
if (UIR_ACTV && UIE_ACTV) {usb_isr_activity();} //activity detected. (only enable after sleep)
if (UCON_SUSPND) return;
if (UIR_UERR && UIE_UERR) {usb_isr_uerr();} //error has been detected
if (UIR_URST && UIE_URST) {usb_isr_rst();} //usb reset has been detected
if (UIR_IDLE && UIE_IDLE) {usb_isr_uidle();} //idle time, we can go to sleep
if (UIR_SOF && UIE_SOF) {usb_isr_sof();}
if (UIR_STALL && UIE_STALL) {usb_isr_stall();} //a stall handshake was sent
if (UIR_TRN && UIE_TRN) {
usb_isr_tok_dne();
UIR_TRN=0; // clear the token done interrupt., 0x190.3
} //a token has been detected (majority of isrs)
//SOF interrupt not handled. user must add this depending on application
void usb_isr_sof(void) {
debug_usb(debug_putc,"\r\nSOF");
UIR_SOF=0;
/* usb_disable_endpoints()
/* Summary: Disables endpoints 1 thru 15
void usb_disable_endpoints(void) {
int8 i;
for (i=1;i<16;i++) {
UEP(i)=ENDPT_DISABLED;
/* usb_isr_rst()
/* Summary: The host (computer) sent us a RESET command. Reset USB device
/* and token handler code to initial state.
void usb_isr_rst() {
debug_usb(debug_putc,"R");
UEIR=0;
UIR=0;
UEIE=0x9F;
UIE=STANDARD_INTS & ~__USB_UIF_ACTIVE;
UADDR=0;
usb_token_reset();
UEP(0)=ENDPT_CONTROL | 0x10;
while (UIR_TRN) {
UIR_TRN=0; //do this to clear out the ustat fifo
UCON_PKTDIS=0; //SIE token and packet processing enabled
usb_init_ep0_setup();
usb_state=USB_STATE_DEFAULT; //put usb mcu into default state
/* usb_init_ep0_setup()
/* Summary: Configure EP0 to receive setup packets
void usb_init_ep0_setup(void) {
EP_BDxCNT_O(0) = USB_MAX_EP0_PACKET_LENGTH;
EP_BDxADR_O(0) = USB_BUFFER;
EP_BDxST_O(0) = 0x80; //give control to SIE, data toggle synch off
#else
EP_BDxST_O(0) = 0x88; //give control to SIE, DATA0, data toggle synch on
EP_BDxST_I(0) = 0;
EP_BDxADR_I(0) = USB_BUFFER + (int16)USB_MAX_EP0_PACKET_LENGTH;
/* usb_isr_uerr()
/* Summary: The USB peripheral had an error. If user specified, error counter
/* will incerement. If having problems check the status of these 8 bytes.
/* NOTE: This code is not enabled by default.
void usb_isr_uerr() {
int ints;
debug_usb(debug_putc,"E %X ",UEIR);
ints=UEIR & UEIE; //mask off the flags with the ones that are enabled
if ( bit_test(ints,0) ) { //increment pid_error counter
debug_usb(debug_putc,"PID ");
ERROR_COUNTER[0]++;
if ( bit_test(ints,1) ) { //increment crc5 error counter
debug_usbdebug_putc,"CRC5 ");
ERROR_COUNTER[1]++;
if ( bit_test(ints,2) ) { //increment crc16 error counter
debug_usb(debug_putc,"CRC16 ");
ERROR_COUNTER[2]++;
if ( bit_test(ints,3) ) { //increment dfn8 error counter
debug_usb(debug_putc,"DFN8 ");
ERROR_COUNTER[3]++;
if ( bit_test(ints,4) ) { //increment bto error counter
debug_usb(debug_putc,"BTO ");
ERROR_COUNTER[4]++;
if ( bit_test(ints,7) ) { //increment bts error counter
debug_usb(debug_putc,"BTS ");
ERROR_COUNTER[5]++;
UEIR=0;
UIR_UERR=0;
/* usb_isr_uidle()
/* Summary: USB peripheral detected IDLE. Put the USB peripheral to sleep.
void usb_isr_uidle() {
debug_usb(debug_putc,"I");
UIE_ACTV=1; //enable activity interrupt flag. (we are now suspended until we get an activity interrupt. nice)
UIR_IDLE=0; //clear idle interrupt flag
UCON_SUSPND=1; //set suspend. we are now suspended
/* usb_isr_activity()
/* Summary: USB peripheral detected activity on the USB device. Wake-up the USB
/* peripheral.
void usb_isr_activity() {
debug_usb(debug_putc,"A");
UCON_SUSPND=0; //turn off low power suspending
UIE_ACTV=0; //clear activity interupt enabling
UIR_ACTV=0;
/* usb_isr_stall()
/* Summary: Stall handshake detected.
void usb_isr_stall(void) {
debug_usb(debug_putc,"S");
if (bit_test(UEP(0),0)) {
bit_clear(UEP(0),0);
UIR_STALL=0;
/* usb_isr_tok_dne()
/* Summary: A Token (IN/OUT/SETUP) has been received by the USB peripheral.
/* If a setup token on EP0 was received, run the chapter 9 code and
/* handle the request.
/* If an IN token on EP0 was received, continue transmitting any
/* unfinished requests that may take more than one packet to transmit
/* (if necessary).
/* If an OUT token on any other EP was received, mark that EP as ready
/* for a usb_get_packet().
/* Does not handle any IN or OUT tokens on EP0.
void usb_isr_tok_dne() {
int8 en;
en=USTAT>>3;
debug_usb(debug_putc,"T ");
debug_usb(debug_putc,"%X ", USTAT);
if (USTAT==USTAT_OUT_SETUP_E0) { //new out or setup token in the buffer
debug_usb(debug_putc,"%X ", EP_BDxST_O(0));
if ((EP_BDxST_O(0) & 0x3C)==USB_PIC_PID_SETUP) {
EP_BDxST_I(0)=0; // return the in buffer to us (dequeue any pending requests)
debug_usb(debug_putc,"(%U) ", EP_BDxCNT_O(0));
debug_display_ram(EP_BDxCNT_O(0), usb_ep0_rx_buffer);
usb_isr_tok_setup_dne();
//if setup_0_tx_size==0xFF - stall ep0 (unhandled request)
//if setup_0_tx_size==0xFE - get EP0OUT ready for a data packet, leave EP0IN alone
//else setup_0_tx_size=size of response, get EP0OUT ready for a setup packet, mark EPOIN ready for transmit
if (__setup_0_tx_size==0xFF)
usb_flush_out(0,USB_DTS_STALL);
else {
usb_flush_out(0,USB_DTS_TOGGLE);
if (__setup_0_tx_size!=0xFE) {
usb_flush_in(0,__setup_0_tx_size,USB_DTS_USERX);
UCON_PKTDIS=0; // UCON,PKT_DIS ; Assuming there is nothing to dequeue, clear the packet disable bit
else if ((EP_BDxST_O(0) & 0x3C)==USB_PIC_PID_OUT) {
usb_isr_tok_out_dne(0);
if ((__setup_0_tx_size!=0xFE)&&(__setup_0_tx_size!=0xFF)) {
usb_flush_in(0,__setup_0_tx_size,USB_DTS_DATA1); //send response (usually a 0len)
else if (USTAT==USTAT_IN_E0) { //pic -> host transfer completed
__setup_0_tx_size=0xFF;
usb_isr_tok_in_dne(0);
if (__setup_0_tx_size!=0xFF)
usb_flush_in(0,__setup_0_tx_size,USB_DTS_TOGGLE);
else {
if (!bit_test(USTAT,2)) {
usb_isr_tok_out_dne(en);
else {
usb_isr_tok_in_dne(en);
/* usb_request_send_response(len)
/* usb_request_get_data()
/* usb_request_stall()
/* Input: len - size of packet to send
/* Summary: After we process a SETUP request, we have 1 of three responses:
/* 1.) send a response IN packet
/* 2.) wait for followup OUT packet(s) with data
/* 3.) stall because we don't support that SETUP request
/* If we are sending data, the array usb_ep0_tx_buffer[] will hold
/* the response and the USB Request handler code will call
/* usb_request_send_response() to let us know how big the packet is.
/* If we are waiting for more data, usb_request_get_data() will
/* be called by the USB request handler code to configure the EP0 OUT
/* endpoint to be ready for more data
/* If we don't support a request, usb_request_stall() will be called
/* by the USB request handler code to stall the endpoint 0.
void usb_request_send_response(int len) {
__setup_0_tx_size=len;
void usb_request_get_data(void) {
__setup_0_tx_size=0xFE;
void usb_request_stall(void) {
/// END USB Interrupt Service Routine
#ENDIF |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Mon Oct 29, 2007 2:20 pm |
Update your compiler. _________________ I came, I saw, I compiled. |
