Problems about programming DMX in PIC in C
Oscar_20
PostPosted: Wed Oct 17, 2007 10:43 am     Reply with quote
I'm using a PIC18F2420 using MPLAB IDE with C18 C compiler.
What I want to do, is receiving the information of DMX. I made a code like the others that you can find in this forum, following the same ideas, but it doesn't work. The first problem is that the usart never generates a FERR error to detect the break. if you have enough time, have a look and tell me what is wrong. If you want to modify it, do it!
Thanks for your attention!
The code is:
#include <p18f2420.h>
#include <stdio.h>
#include <string.h>
#include <delays.h>
//-------------------------Confiurations-----------------------------------
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config PWRT= OFF
//-------------------------Inicializacion----------------------
#define NUM_CH 2
#define ESPERA_BREAK 0
#define ESPERA_START 1
#define REBRE_DATA 2
char rx_status;
char DMX_DIR;
char DMX_VAL;
char CH_DIR[NUM_CH];
char CH_VAL[NUM_CH];
int j;
//-------------------------declarations of functions-----------------------------------
void isr_high(void);
//-------------------------Funtions-------------------------------------------------
void actualitza_valors(char DMX_DIR, char DMX_VAL, char CH_DIR[], char CH_VAL[])
 int i=0;
 for (i=0;i<NUM_CH> 12)
       rx_status=ESPERA_BREAK;
  RCSTAbits.CREN = 0;
  RCSTAbits.CREN = 1;
  PIR1bits.RCIF=0;
 INTCONbits.GIEH=1;
//------------------------Programa Principal-----------------------------------------
//------------------------Configuració de les interrupcions---------------------------
RCONbits.IPEN=1;       // Habilitem les prioritats de les interrupcions
INTCONbits.GIEH=1;       // Habilitem les interrupcions de prioritat alta
INTCONbits.GIEL=0;      // DesHabilitem les interrupcions de prioritat baixa
//------------------------Configuració de la USART ------------------------------------
BAUDCONbits.ABDEN=0;     // Baud rate measurement disabled or completed
TXSTAbits.BRGH=1;      // High speed Baud Rate Select
BAUDCONbits.BRG16=0;     // 8-bit Baud Rate Generator (només SPBRG)
SPBRG=4;        // Càlcul per a un Baud Rate de 250000 bps -> Fosc/[16(n+1)]
RCSTAbits.SPEN=1;       // Habilitem RX com a serial port
TXSTAbits.SYNC=0;      // Usart a Asynchronous mode
IPR1bits.RCIP=1;      // Donem high priority interrupt a la Usart
PIR1bits.RCIF=0;      // Netegem la bandera de la interrupció de la Usart
PIE1bits.RCIE=1;      // Habilitem la interrupció de recepció
RCSTAbits.RX9=1;      // Habilitem el nové bit en recepció
RCSTAbits.ADDEN=0;      // Deshabilitem la detecció d'adreces en el RX9
TXSTAbits.TXEN=0;      // Deshabilitem la transmissió
RCSTAbits.CREN = 0;      // DesHabilitem la recepció i netegem els errors
RCSTAbits.CREN = 1;      // Habilitem la recepció
//------------------------Configuració dels ports--------------------------------------
PORTA=0x00;
TRISA=0b11000000;
//------------------------Final de la configuració, rutina principal-------------------
CH_DIR[0]=1;
CH_DIR[1]=2;
CH_VAL[0]=255;
CH_VAL[1]=0;
do {
 }while(1);
PostPosted: Wed Oct 17, 2007 10:54 am     Reply with quote
Please ask your question in the Microchip C18 forum:
http://forum.microchip.com/tt.aspx?forumid=3
