Error 51 on #ORG
priesty100
Error 51 on #ORG
PostPosted: Tue Oct 16, 2007 6:28 am     Reply with quote
Compiler Version - 4.025
Target PIC - PIC18F8722
Oscillator Speed (10MHz) (clocking at 40MHz)
I am trying to specify the location of some code using #org however the compiler is throwing up an error51 (a numeric expression must appear here). I cant see anything wrong with the code and have even copied the example from the help and this doesn’t work either.
Here's the code:
    output_high(pin_B2);
    output_low(pin_B2);
    #org 0x100,0x1FF
    #asm
    RLNCF LoopDelay,F
    MOVF LoopDelay,W
    ADDWF 0xFF9,F           //0xFF9 = PCL
    nop
    nop
    nop
    #endasm
    output_high(pin_B0);
    output_low(pin_B0);
    StrobeDelay++;
    if(StrobeDelay==102)
       StrobeDelay=100;
    LoopDelay=StrobeDelay;
Any help on the #ORG problem would be most appreciated.
(The code is for a variable delay loop however this seems to work with small numbers and no #org, the code location needs to be specified so that it is within page boundaries).
Thank you for your help
Sam
PostPosted: Tue Oct 16, 2007 8:49 am     Reply with quote
You cannot just set an org 'inline'. It places the subsequent _function_, at the desired address. What you post, would require the addresses of everything else to be retroactively altered to reposition the bit of code at the required location...
You need to declare your routine as a separate function, and then set it's origin.
Why not just use the 'delay_cycles function....
priesty100
PostPosted: Wed Oct 17, 2007 1:39 am     Reply with quote
Thank you for your help, the problem is now sorted.
And yes, the delay_cycles function would be a much better implimentation.
Thanks again
Sam
