Frame Grabber with PIC18
cfernandez
PostPosted: Thu Oct 11, 2007 9:45 pm     Reply with quote
I need to capture a frame grabber (bitmap) from a CCD with a PIC18 and send this bitmap to other device by serial port.
Anybody know similar project?, which is the best CCD for this job?
Thank you very much!!
Best Regards,
PostPosted: Fri Oct 12, 2007 2:55 am     Reply with quote
Setiously, choose another chip....
To do this properly, requires you buffer an entire frame from the CCD. Even with a small CCD, you will be typically talking over 1/4MB of data. You _can_ do it with a PIC, and external memory, but it'll be more complex, than using a chip which supports an external RAM directly. The PIC is not a 'good choice' for this type of application.
It is a bit like saying, that you 'can' hammer a nail in with a spanner, but it is a lot easier, if you use a hammer!....
If this is for a large application, then I'd be looking at performing everything in a FPGA. However if this is a limited number off type project, then look instead at buying a pre-built camera module, containing the CCD, and it's control electronics already running.
As for 'what is the best', it'll depend totally on what you want. Colour, mono, resolution required, sensitivity, operating temperature range, etc. etc..
cfernandez
PostPosted: Fri Oct 12, 2007 7:47 am     Reply with quote
ttelmah,
I think the same that you, but I found a good choice for my project in www.comedia.com. They have a camera with serial communication.
Thanks,
digicomk
Frame grabber
PostPosted: Sat Oct 13, 2007 7:51 pm     Reply with quote
Cfernandez,
I am looking for a frame grabber for a black & white CCD and browsed the Comedia's site and found nothing about this issue.
Could you help me with more specifics about Comedia?
Thanks,
Digicomk
cfernandez
PostPosted: Sun Oct 14, 2007 8:06 am     Reply with quote
the correct site is www.comedia.com.cn
best regards,
digicomk
Frame grabber
PostPosted: Mon Oct 15, 2007 2:18 pm     Reply with quote
Cfernandez,
Many thanks.
Julian
Digicomk
