strange thing with reversing a string
Goto page 1, 2  Next
The Puma
PostPosted: Thu Oct 11, 2007 6:14 am     Reply with quote
I have this function to reverse a string
The string can hold max 10 chars
Let say: "1234567890"
After the reversing he outputs "=098765432"
Whats is wrong here??
void max7221_fill_char_buffer(char *buffer) {
   int i,j;
   char currentchar;
   char *msgptr,*rev_buffer;
   j=strlen(buffer);
   rev_buffer[j--]=0;
   for(i=0;i<strlen(buffer);i++,j--)
      rev_buffer[j]=buffer[i];
   memset(message,0x00,50);
   msgptr=&message[0];
   currentchar=*rev_buffer;
   while(currentchar) {
      memcpy(msgptr,font5x7[currentchar-0x20],5);
      msgptr+=5;
      currentchar=*(++rev_buffer);
But if i only reverse a string that is lower than the 10 chars is going well
PostPosted: Thu Oct 11, 2007 6:32 am     Reply with quote
Where do you initialise rev_buffer? My guess is it is pointing to a random location in RAM and conflicting with other variables.
The Puma
PostPosted: Thu Oct 11, 2007 7:36 am     Reply with quote
Can you give me a hint how i can change the code, so that it works?
rberek
PostPosted: Thu Oct 11, 2007 7:42 am     Reply with quote
ckielstra did give you a hint. Initialize rev_buffer.
The Puma
PostPosted: Thu Oct 11, 2007 7:54 am     Reply with quote
But how??
Please help me
Wayne_
PostPosted: Thu Oct 11, 2007 8:30 am     Reply with quote
OK, your first problem is that you think strlen returns the length of the string including the null termination char '\0' it does NOT so if you changed the code
j=strlen(buffer);
rev_buffer[j--]=0;
to
j=strlen(buffer);
rev_buffer[j+1] = 0;
That would fix the first problem.
Secondly and more imprtantly.
char *rev_buffer; needs to be changed to
char rev_buffer[MAX_SIZE];
where MAX_SIZE = strlen(buffer) + 1;
Hope that helps.
The Puma
PostPosted: Tue Oct 23, 2007 6:04 am     Reply with quote
I can't get it to work
void max7221_fill_dot_matrix_buffer(char *buffer) {
   int i,j;
   char reverse_buffer[10],*msgptr,currentchar;
   j=strlen(buffer);
   reverse_buffer[j--]=0;
      reverse_buffer[j]=buffer[i];
   memset(dot_matrix_buffer,0x00,50);
   msgptr=&dot_matrix_buffer[0];
   currentchar=*reverse_buffer;
      msgptr+=5;
      currentchar=*(++reverse_buffer);
get the follwoing error:
Expecting LVALUE such as a variable name or * expression
(in line: currentchar=*(++reverse_buffer);)
How can i made this that the 4 four lines reverse the string (in buffer) to reverse_buffer?
PostPosted: Tue Oct 23, 2007 8:25 am     Reply with quote
[spam],
You did not react to Wayne's suggestions. This is impolite and it might have helped you.
j=strlen(buffer);
rev_buffer[j--]=0;
to
j=strlen(buffer);
Sorry Wayne, the original code as posted is correct. You made a similar thinking error because an array starts counting at position 0, not at 1. For example, a string with length 10 would occupy 11 bytes in memory including the terminating zero. Strlen would return 10, writing a terminating 0 at rev_buffer[10] is then correct.
This is an important bug and [spam] did not fix it, the reverse_buffer size is still 10 instead of 11.
I want to extend on this a bit more. It is good coding practice to avoid the use of 'magic numbers', i.e. don't use hard coded numbers. In your small function here you have the hard coded numbers 10, 50 and 5. The big risk you are running here is that you change the size of one such number in one place in your program but forget to change it in another place. Replace the hard coded numbers by a meaningful #defined name.
Another potential problem: You are using the strlen function to get the length of the input buffer, but there is no test on the input buffer being too long. This could cause your program to overwrite other data in RAM.
This one is strange, it looks like you have found a limitation (bug) in the CCS compiler. The compiler complains about the '++reverse_buffer' part. I tried it both in v3.249 and 4.057 and both compiler versions don't allow calculations on the buffer address. This is not good, but I have to say it is an ugly coding style to want to change a buffer's base address. A more elegant solution is to change currentchar into a pointer and then change this pointer instead.
A final remark: Even in a small program it is good practice to add a little comment about what is going on. And when you copy code from other people it is polite to give them credits (add a link to the original code in your program).
#define DOT_MATRIX_BUFFER_SIZE  50
#define FONT_SIZE               5
#define MAX_REV_BUF_SIZE        (DOT_MATRIX_BUFFER_SIZE / FONT_SIZE)  // 50 / 5 = max 10 characters
   int i,j;
   char reverse_buffer[MAX_REV_BUF_SIZE+1],*msgptr;
   char *currentchar;     // Changed into a pointer
   // Reverse the string sequence.
   // Code supplied by asmallri in http://www.ccsinfo.com/forum/viewtopic.php?t=23498
   j=strlen(buffer);
   if (j > MAX_REV_BUF_SIZE)    // Added a test for buffer overflow
     j = MAX_REV_BUF_SIZE;
   // Clear the matrix buffer.
   memset(dot_matrix_buffer, 0x00, DOT_MATRIX_BUFFER_SIZE);
   //Copy the reversed string to the matrix buffer.
   msgptr = &dot_matrix_buffer[0];    // Here you have msgptr for same reason we
                                      // had to make currentchar into a pointer.
                                      // Looks like you had this problem before...?
   currentchar = &reverse_buffer[0];
   while(*currentchar)
      memcpy(msgptr, font5x7[*currentchar-0x20], FONT_SIZE);
      msgptr+=5;
      currentchar++;
Note: You can optimize this function by removing the reverse and walking the input buffer from back to front.
PostPosted: Tue Oct 23, 2007 9:00 am     Reply with quote
Not allowing the base address to be changed, is correct 'C',not a limitation in CCS.
Key to remember, is that 'rev_buffer', is _not_ a variable holding a pointer, but is a shortcut (the name of an array is it's address). Since it is not a variable, it can't itself be incremented.
In K&R, the paragraph about this says:
"There is one difference between an array name and a pointer that must be kept in mind. A pointer is a variable, so pa=a, and pa++ are sensible operations. But an array name is a _constant_, not a variable: constructions like a=pa or a++ or pa=&a are illegal."
If you want to increment the address, then you need to declare:
char *buff_address;
Then add:
buff_address=rev_buffer;
and increment 'buff_address', not 'rev_buffer.
The Puma
PostPosted: Tue Oct 23, 2007 9:01 am     Reply with quote
Ok, thz so far,
but how can i rewrite that code so that the fontdata (5 bytes) are not placed on position 0 of the string, but on position 49
An example:
0x36, 0x49, 0x49, 0x49, 0x7F // 0x42, B
The data for the letter B must be place on postion 49
   currentchar=*buffer;
      memcpy(msgptr,font5x7[currentchar-0x20],MAX_FONT_SIZE);
      msgptr+=MAX_FONT_SIZE;
      currentchar=*(++buffer);
The Puma
PostPosted: Tue Oct 23, 2007 9:56 am     Reply with quote
char *buff_address;
Then add:
I did't understand it anymore
Can you me a working reserve code for above procedure
PostPosted: Tue Oct 23, 2007 10:12 am     Reply with quote
I don't understand anymore either. I gave you a compilable version of your function. I don't know the input or output requirements of your function, but have you tested my code and what did you see going wrong?
The Puma
PostPosted: Tue Oct 23, 2007 10:17 am     Reply with quote
It is very simple:
I pass a string. lets say DEMO
now the passing string (in char buffer) must reversed
   char currentchar;
   char *msgptr;
  HERE MUST THE REVERSE CODE
   memset(message,0x00,MAX_DOT_MATRIX_BUFFER_SIZE);
   msgptr=&message[0];
The Puma
PostPosted: Tue Oct 23, 2007 11:40 am     Reply with quote
I have now this and it works
Can i optimise this ?
Maybe some advise
   int i,j;
   char temp,*msgptr,currentchar;
   for(i=0,j=strlen(buffer)-1;i<j;i++,j--) {
      temp=buffer[i];
      buffer[i]=buffer[j];
      buffer[j]=temp;
   memset(dot_matrix_buffer,0x00,MAX_DOT_MATRIX_BUFFER_SIZE);
PostPosted: Tue Oct 23, 2007 12:29 pm     Reply with quote
Get rid of the lines reversing the buffer, you can do this in the copy-loop by reading the input buffer backwards (from the end to start).
   int8 i;
   char *msgptr, currentchar;
   int8 MsgLength;
   MsgLength = strlen(buffer);
   for (i=0; i<MsgLength; i++)
      currentchar=buffer[MsgLength - i - 1];
Goto page 1, 2  Next
Page 1 of 2
