Problem with web server
bloureiro
PostPosted: Thu Oct 11, 2007 4:31 am     Reply with quote
Hi use the stack and example from CCS.
I'm trying make a web server with a 18f4685 and enc28j60 but when i
make a page longer to +-1400 characters the page don't show in the browser.
Hi trying change the "MAC_TX_BUFFER_SIZE" to 4000 but don't resolve.
Someone can help-me?
Thanks.
Douglas Kennedy
PostPosted: Thu Oct 11, 2007 1:34 pm     Reply with quote
It's several years since I did this but there are restrictions imposed upon the MAc encapsulation of a packet . I believe it is 1500 payload plus an 8 byte preamble plus 6 byte destination and 6 byte sender addresses and a 2 byte type . You should look at the internet specifications before trying changes any packet not meeting internet specifications is destined for the bit bucket.
frequentguest
T
PostPosted: Thu Oct 11, 2007 2:23 pm     Reply with quote
The TCP server and HTTP server handle fragmentation of the file if the size of the page > 1 packet. You shouldn't have to change the MAC buffer size to do this. What is happening when you try to read a large file? Do smaller files work? Which web server are you using? What hardware are you using?
bloureiro
PostPosted: Tue Oct 16, 2007 3:28 am     Reply with quote
If hi do smaller files this work.
Hi use the TCP/IP stack of ccs. The hardware is the 18F4685 and enc28j60.
when you try to read a large file the enc28j60 don't respond.
Thanks.
frequentguest
PostPosted: Tue Oct 16, 2007 8:12 am     Reply with quote
Can you debug the code to figure out where it's getting hung up?
bloureiro
PostPosted: Tue Oct 16, 2007 8:25 am     Reply with quote
Sorry but hi only have a programmer gtp+ no a debugger.
