removing the default statement from switch-case, compiler will then generate a 'table jump' codes but this in turn will cause your microcontroller to run an approximate 30 instructions before executing functions within each case
AnthonyF Guest
Posted: Fri Oct 12, 2007 3:17 pm
Thanks,
Looks like if you are comparing with constants as I am the lookup table is hard coded exactly as I want requiring minimal processing during each run.
I think we all would like to have minimal processing before executing each task.
how do you propose to code 'a table read using computed GOTO method' in C?
