GetC stops working after ISR_RB0
nmeyer
PostPosted: Mon Oct 08, 2007 4:41 pm     Reply with quote
Compiler PCWHD 4.058
I have the following program that has two loops depending on if you press RB0 or RB1. When it is running in the RB0 loop it is writing and reading information over the RS232. The data it reads it does a CRC-CCITT on and verifies. When i first start the program and go to RB0 it works fine. If i hit the RB1 it goes to that loop, and then i hit RB0 again it goes back but then it does not compute the correct CRC. It is as if the getc() is no longer working, because the crc value is then always the same. The rest of the program still runs fine. Does anyone have any thoughst on this?
#include <18F4520.h>
#device adc=10
#include <stdio.h>
#include <math.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                    //Extended set extension and Indexed Addressing mode enabled
#use delay(clock=4000000,RESTART_WDT)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,RESTART_WDT,ERRORS)
#define  LCD_POWER   PIN_D7
#include <Flex_LCD.C>
int   i,step,phase1,phase2;
char  reply;
int   byte1,byte2,byte3,byte4,byte5,byte6,byte7,byte8,byte9,byte10,byte11,byte12;
int   byte13,byte14,byte15,byte16,byte17,byte18,byte19,byte20;
int   rbyte1,rbyte2,rbyte3,rbyte4,rbyte5,rbyte6,rbyte7,rbyte8,rbyte9,rbyte10;
int   rbyte11,rbyte12,rbyte13,rbyte14,rbyte15,rbyte16,rbyte17,rbyte18,rbyte19,rbyte20;
long  crc_result,tempbyte,disbyte,mult;
int16 crc,r_crc;
#int_ext1
void rb1_isr(void)
step=1;
#int_ext
void rb0_isr (void)
step=2;
int16 crc_1021(int16 old_crc, int8 data)
   //int16 crc;
   int16 x;
   x=make8(old_crc,1)^data;
   x^=x>>4;
   crc=(old_crc<<8) ^ (x<<12) ^ (x<<5) ^ x;
   crc&=0xffff;
   return crc;
   setup_adc_ports(AN0|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_EXT1);
   ext_int_edge(0,H_TO_L);
   ext_int_edge(1,H_TO_L);
   enable_interrupts(global);
   output_high(LCD_POWER);
   output_low(LCD_RW);
   output_low(PIN_B5);
   lcd_init();
   set_tris_a(0b00000001);
   set_tris_b(0b00000011);
   byte1=0x55;
   byte2=0x55;
   byte3=0x55;
   byte4=0x54;
   byte5=0xF1;
   byte6=0x44;
   byte7=0x10;  //0x10
   byte8=0x00;
   byte9=0x05;  //0x05
   byte10=0x00;
   byte11=0x00;
   byte12=0x04;
   byte14=0x00;
   byte15=0x03;
   byte16=0xE8;
   byte19=0xFF;
   byte20=0xFF;
   step=0;
   i=0;
   set_adc_channel(0);
   while (true)
      while (step==0)
         printf(lcd_putc,"\f Rawson Control\n");
         printf(lcd_putc,"  Accurate II");
         phase1=1;
         phase2=1;
      while (step==1)
         while (phase1==1)
            //output_high(PIN_B5);
            crc=0;
            crc_1021(crc,byte5);
            crc_1021(crc,byte6);
            crc_1021(crc,byte7);
            crc_1021(crc,byte8);
            crc_1021(crc,byte9);
            crc_1021(crc,byte10);
            crc_1021(crc,byte11);
            crc_1021(crc,byte12);
            byte13=0xC0;
            crc_1021(crc,byte13);
            crc_1021(crc,byte14);
            crc_1021(crc,byte15);
            crc_1021(crc,byte16);
            byte17=make8(crc,1);
            byte18=make8(crc,0);
            output_high(PIN_C5);
            //delay_us(20);
            printf("%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c",byte1,byte2,byte3,
            byte4,byte5,byte6,byte7,byte8,byte9,byte10,byte11,byte12,byte13,
            byte14,byte15,byte16,byte17,byte18,byte19,byte20);
            phase1=0;
            output_low(PIN_C5);
         //output_low(PIN_B5);
         rbyte1=getc();
         rbyte2=getc();
         rbyte3=getc();
         rbyte4=getc();
         crc=0;
         rbyte5=getc();
         crc_1021(crc,rbyte5);
         rbyte6=getc();
         crc_1021(crc,rbyte6);
         rbyte7=getc();
         crc_1021(crc,rbyte7);
         rbyte8=getc();
         crc_1021(crc,rbyte8);
         rbyte9=getc();
         crc_1021(crc,rbyte9);
         rbyte10=getc();
         crc_1021(crc,rbyte10);
         rbyte11=getc();
         crc_1021(crc,rbyte11);
         rbyte12=getc();
         crc_1021(crc,rbyte12);
         rbyte13=getc();
         crc_1021(crc,rbyte13);
         rbyte14=getc();
         crc_1021(crc,rbyte14);
         rbyte15=getc();
         crc_1021(crc,rbyte15);
         rbyte16=getc();
         crc_1021(crc,rbyte16);
         rbyte17=getc();
         rbyte18=getc();
         r_crc=make16(rbyte17,rbyte18);
         if(crc==r_crc)
            output_low(PIN_B5);
         mult=read_adc();
         tempbyte=make16(byte15,byte16);
         disbyte=tempbyte/1000;
         printf(lcd_putc,"\f Speed=%LuRPM\n",disbyte);
         printf(lcd_putc,"%LX",crc);
         //printf(lcd_putc,"   clockwise   ");
         for (i=0;i<=1;i++)
         phase2=1;
         phase1=1;
         tempbyte=(mult/20)*1000;
         byte15=make8(tempbyte,1);
         byte16=make8(tempbyte,0);
      while (step==2)
         while (phase2==1)
            crc=0;
            byte13=0x80;
            byte14=0x00;
            byte15=0x00;
            byte16=0x00;
            //delay_us(20);
            phase2=0;
            output_low(PIN_C5);
         printf(lcd_putc,"\f   Speed=0RPM\n");
         printf(lcd_putc,"     stopped");
         for (i=0;i<=10;i++)
         phase1=1;
         phase2=1;
PostPosted: Tue Oct 09, 2007 6:32 pm     Reply with quote
My advice is to cut out large sections of the code and see if you still
have the problem. If you do, getting rid of all the excess code will
make it easier to see the problem.
