24LC512
Alberto
24LC512
PostPosted: Tue Oct 09, 2007 5:59 pm     Reply with quote
Hello , I´m trying to use the eeprom 24LC512 for the first time , I´m using 24512.c driver . A wrote this code , but he´s only reading zero from the eeprom . Is the code right. Could some confirm me the connections of 24LC512 , pin A1 A2 A3 , Wp ,pullups etc
the code:
#define EEPROM_SDA PIN_B6
#define EEPROM_SCL PIN_B7
main()
long int i;
BYTE d;
BYTE data;
set_tris_b(0b11000000);
init_ext_eeprom();
delay_us(100);
delay_ms(400);
data=1;
//wite eeprom eeprom
for(i=0;i<100;i++)
data=data+1;
write_ext_eeprom(i,data);
delay_us(10);
for(i=0;i<100;i++)
d=read_ext_eeprom(i);
printf(lcd_putc,"%u",d);
printf(lcd_putc,"\f");
PostPosted: Tue Oct 09, 2007 6:13 pm     Reply with quote
See this thread for a link to a schematic. It's for a 24LC256, but the
pins are the same, and it shows how to connect them.
http://www.ccsinfo.com/forum/viewtopic.php?t=27461
dustimv
PostPosted: Tue Oct 09, 2007 10:04 pm     Reply with quote
Please note on the schematic listed above, the pins are mirrored, due to the IC being placed on the back of the board.
PostPosted: Tue Oct 09, 2007 10:24 pm     Reply with quote
That's not true.
Look at the photo of the board on page 7 of the manual:
http://ww1.microchip.com/downloads/en/DeviceDoc/51275b.pdf
The 24LC256 is in a circle labeled "14", and it's on the top side of the
board on the left side.
Here's a large photo of the PicDem2-Plus (non-Rohs version) that
I found on the net. The 24LC256 is U4.
http://www.units.it/~atmocube/presentazioni/galilei_07/picdem2plus.JPG
