12F683 Hangs up?
nmeyer
12F683 Hangs up?
PostPosted: Fri Oct 05, 2007 9:07 am     Reply with quote
Can anyone see what i am doing incorrectly on this program? When i program the chip, it does nothing. The first thing it should do is turn an output pin on then off. It does not doe this. It is almost like the program never starts. I think i am missing something in the set up. And yes, i have confirmed that my circuit is working by loading a different program into the chip.
Compiler version 4.058 PCWHD
#include <12F683.h>
#device adc=10
#use delay(clock=2000000, RESTART_WDT)
#fuses WDT,INTRC_IO, PUT, MCLR, NOBROWNOUT, NOCPD, NOPROTECT
#include <math.h>
#use fast_io(A)
#define GPIO1 PIN_A0
#define LED2 PIN_A1
#define LED3 PIN_A2
#define time_in PIN_A3
#define trn PIN_A4
#define lbo PIN_A5
#define INTS_PER_SECOND 25
char int_count,loop;
long time1,time2,time3,seconds,voltage,hour,day,minute;
#int_rtcc
void clock_isr(void)
if(--int_count==0) //decrement counter until 0
++seconds; //count up seconds
int_count=INTS_PER_SECOND; //reset counter
if (seconds>=65000)
seconds=65000;
setup_oscillator(osc_2mhz);
setup_adc_ports(sAN2);
setup_adc(ADC_CLOCK_DIV_8);
setup_wdt(WDT_ON | WDT_DIV_16);
//setup_wdt(WDT_72MS | WDT_ON);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
set_rtcc(0);
enable_interrupts(INT_RTCC);
//setup_timer_1(T1_DISABLED);
set_tris_a(0b00011111);
output_high(trn); //shut off solenoid
int_count=INTS_PER_SECOND; //used for timer
seconds=0; //clear out variable
hour=0; //clear low volage counter for seconds
day=0; //clear out day counter
minute=0;
time1=0; //counter for time
loop=TRUE;
output_low(trn); //shut off solenoid
while (TRUE)
output_high(trn); //turn off solenoid
set_adc_channel(2); //
//output_low(trn); //turn on solenoid
voltage=read_adc();
while(loop)
if((voltage<=1024) && (voltage>=1010))
time1=0;
if((voltage<=1009) && (voltage>=512))
time2=1024-voltage;
time1=time2/8;
if((voltage<=511) && (voltage>=0))
time3=1024-voltage;
time2=time3-512;
time1=time2*60;
if(day>=2)
time1=0;
if(seconds>time1)
output_high(trn);
output_low(trn);
seconds=0;
loop=false;
output_low(trn);
seconds=seconds+1;
minute=minute+1;
if(minute>=3600)
hour=hour+1;
minute=0;
if(hour>=24)
day=day+1;
hour=0;
output_low(trn);
PostPosted: Fri Oct 05, 2007 9:28 am     Reply with quote
Er. MCLR....
You have the MCLR pin defined as 'time_in'. What is connected to this?.
nmeyer
PostPosted: Fri Oct 05, 2007 9:58 am     Reply with quote
It is pulled to Vdd through a 10K. Nothing else.
PostPosted: Fri Oct 05, 2007 10:36 am     Reply with quote
I assume you're referring to the 'trn' pin ?
#define trn PIN_A4
Look closely at your TRIS statement.
nmeyer
PostPosted: Fri Oct 05, 2007 10:43 am     Reply with quote
Yes, I just caught and fixed that. It works now.
