checksum related doubts
isotopus
PostPosted: Thu Oct 04, 2007 7:13 am     Reply with quote
Until now, I have been working with PIC16F, and I've managed "checksum" with directive #id. this way, I may store a fixed version to any code that I have compiled.
But now I have just started working with PIC18F4510, and I have the following problem. I try the same instruction that before:
#id VERSION_01, VERSION_02,VERSION_03,VERSION_04
But now, when I compile any source code change, MPLAB IDE "checksum" field changes, although VERSION_0X macros have not changed.
I have also tried with:
#rom 0x20000={VERSION_ID0, VERSION_ID1, VERSION_ID2, VERSION_ID3, VERSION_ID4, VERSION_ID5, VERSION_ID6, VERSION_ID7}
But the same problem....
Sorry because of my ignorance about the checksum calculation, but I'm a beginner... Does anyone know how does MPLAB generate the checksum (which data is used)??
Could somebody help me please?
Thank you very much!!
Neutone
PostPosted: Thu Oct 04, 2007 11:02 am     Reply with quote
So you wish to have a checksum for the HEX file match your program version? I suppose if you have a macro that edits a few bytes of program memory to the right value this could be achieved. I have never heard of this being done before.
Whats your macro look like?
PostPosted: Fri Oct 05, 2007 12:36 am     Reply with quote
Thanks for your reply Neutone !
An example of macro used until now (PIC16F):
#define VERSION_ID0 0
#define VERSION_ID1 1
#define VERSION_ID2 2
#define VERSION_ID2 3
#id VERSION_ID0, VERSION_ID1, VERSION_ID2, VERSION_ID3
With the PIC18F4510 I have tried the same and as it doesn't seem to work I have used as well:
What do you think about it ? Have you got any other idea ?
Thanks for your help !!
PostPosted: Fri Oct 05, 2007 2:21 am     Reply with quote
Yes.
One very simple comment. :-)
How many 'zeros' should there be in the ROM address for the ID bytes?.
PostPosted: Mon Oct 08, 2007 12:50 am     Reply with quote
Hi and Thanks again !!
Yes, I know that I must put #rom 0x200000 (One more zero )...but it does not work as well...
I do not know what more can I do...
As people say in my country " I see phantoms everywhere with this stuff..."
Thanks...
