low - high + interrupt
Alanis
PostPosted: Tue Oct 02, 2007 12:31 pm     Reply with quote
Hi !
How to read out this low - high sample:
L- L- L- H- H- H- H- L- L- H- H- L- L- H- H
Maybe with some interrupt routine ?
The chip that am using is 16F877.
Alan
Alanis
PostPosted: Thu Oct 04, 2007 4:58 am     Reply with quote
Hi guys !
Do you have and idea how to make this ?
In general, i dont know how to define that L-H read out.
e.g. how to read the levels if i get 3 time L L L or H H H ...
Alan
p.s. incoming data is passed at speed of 9600 B/s.
PostPosted: Thu Oct 04, 2007 5:21 am     Reply with quote
Setup a timer with the correct speed and enable interupt.
Att each interrupt read the value from the actual pin.
Start the timer in the middle of the first bit.
To do this you must have a reference, i.e. start bit or something like that to know when to start.
Alanis
PostPosted: Fri Oct 05, 2007 3:04 am     Reply with quote
-If my internal ring oscillator is 8 MHZ, what is the correct timer setup ?
- I dont understand this part....
