Floating data
nilim05
Floating data
PostPosted: Wed Oct 03, 2007 10:57 am     Reply with quote
Hi all,
Can I send floating data to output channel of the PIC microcontroller? If it is then how.
Thanks in advance.
nilim
jecottrell
PostPosted: Wed Oct 03, 2007 12:03 pm     Reply with quote
Your question would be easier to answer if you explained what your output is connected to and what you wanted to see there. Do you want to output a voltage, a serial stream of data, a PWM duty cycle?
nilim05
Floating data
PostPosted: Wed Oct 03, 2007 7:59 pm     Reply with quote
Hi jecottrell,
Thanks for your reply. You exactly got my point. The output would be serial stream data or PWM duty cycle. Could you please explain the situation for cases?
Thanks a lot gain.
Nilim
jecottrell
PostPosted: Thu Oct 04, 2007 3:54 am     Reply with quote
Take some time and explain what you want to achieve. Then someone will be able to explain how to do it. So far, you haven't offered any details on what you would like to achieve. Until then, I don't think you'll find anyone willing to play 20 Questions.
SherpaDoug
PostPosted: Thu Oct 04, 2007 8:16 am     Reply with quote
For a serial stream look at the printf() function.
For PWM look at the set_pwm, set_power, and setup_power functions.
