Interrupt handler
Dimmu
Interrupt handler
PostPosted: Wed Oct 03, 2007 1:52 pm     Reply with quote
16f876A
pcwh 4.053
Is there a way to reduce the size of the interrupt handler generated by CCS ?
Here is a very simple program that shows the size of the generated code for a simple assignment :
#include <16F876A.h>
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES DEBUG                    //Debug mode for use with ICD
int i;
#int_TIMER0
void TIMER0_isr(void)
   i++;
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   038
0003:  NOP
----- default IT handler begin !!
0004:  MOVWF  7F
0005:  SWAPF  03,W
0006:  CLRF   03
0007:  MOVWF  21
0008:  MOVF   0A,W
0009:  MOVWF  20
000A:  CLRF   0A
000B:  MOVF   04,W
000C:  MOVWF  22
000D:  MOVF   77,W
000E:  MOVWF  23
000F:  MOVF   78,W
0010:  MOVWF  24
0011:  MOVF   79,W
0012:  MOVWF  25
0013:  MOVF   7A,W
0014:  MOVWF  26
0015:  MOVF   7B,W
0016:  MOVWF  27
0017:  BCF    03.7
0018:  BCF    03.5
0019:  BTFSS  0B.5
001A:  GOTO   01D
001B:  BTFSC  0B.2
001C:  GOTO   030
001D:  MOVF   22,W
001E:  MOVWF  04
001F:  MOVF   23,W
0020:  MOVWF  77
0021:  MOVF   24,W
0022:  MOVWF  78
0023:  MOVF   25,W
0024:  MOVWF  79
0025:  MOVF   26,W
0026:  MOVWF  7A
0027:  MOVF   27,W
0028:  MOVWF  7B
0029:  MOVF   20,W
002A:  MOVWF  0A
002B:  SWAPF  21,W
002C:  MOVWF  03
002D:  SWAPF  7F,F
002E:  SWAPF  7F,W
002F:  RETFIE
--- default it handler end !!
0030:  BCF    0A.3
0031:  BCF    0A.4
0032:  GOTO   033
.................... int i;
.................... #int_TIMER0
.................... void TIMER0_isr(void)
....................    i++;
0033:  INCF   28,F
0034:  BCF    0B.2
0035:  BCF    0A.3
0036:  BCF    0A.4
0037:  GOTO   01D
0038:  CLRF   04
0039:  BCF    03.7
003A:  MOVLW  1F
003B:  ANDWF  03,F
003C:  BSF    03.5
003D:  BSF    1F.0
003E:  BSF    1F.1
003F:  BSF    1F.2
0040:  BCF    1F.3
0041:  MOVLW  07
0042:  MOVWF  1C
0043:  SLEEP
Configuration Fuses:
   Word  1: 3772   HS NOWDT PUT DEBUG NOPROTECT BROWNOUT NOLVP NOCPD NOWRT
Dimmu
PostPosted: Wed Oct 03, 2007 2:14 pm     Reply with quote
Look at the CCS example file for #int_global. It's in this directory:
c:\program files\picc\examples\ex_glint.c
See this thread which explains the CCS interrupt dispatcher:
http://www.ccsinfo.com/forum/viewtopic.php?t=29173
Dimmu
PostPosted: Thu Oct 04, 2007 1:03 am     Reply with quote
Thank you for the perfect answer, as usual !!
Dimmu
