Calling with a reference of union
Andrew-miksys
PostPosted: Wed Oct 03, 2007 3:08 am     Reply with quote
I'm trying to create buffer writing function.
union LCD_BUF
    struct
       int1 lobat;
       int1 sign;
       int   other:6;
       int1 dot1;
       int   dig1:7;
       int1 dot2;
       int   dig2:7;
       int1 dot3;
       int   dig3:7;
    }bits;
    struct
       int   icons;
       int   lcd1;
       int   lcd2;
       int   lcd3;
    }bytes;
union LCD_BUF disp1, disp2, disp3;
I need few function to operation of displays
f.e
void InsertInteger(...)
void SetPoint(...)
etc.
How should I use reference of union?
PostPosted: Wed Oct 03, 2007 5:14 am     Reply with quote
Exactly the same way as with any other variable. So:
void InsertInteger(union LCD_BUF val) {
Then call this with (for your first variable shown):
InsertInteger(disp1);
While inside the routine, use (for example)
val.icons
Andrew-miksys
PostPosted: Wed Oct 03, 2007 6:32 am     Reply with quote
Thanks,
I'm not sure but this way will be created local copy of union wich be exist only inside function body. So any operation has no effect after end of function. Am I right?
PostPosted: Wed Oct 03, 2007 7:00 am     Reply with quote
Yes.
If you want to reference the external union, thre are two routes:
1) Declare the variables as global (declare them outside the body of the main function). Then you can refer to these anywhere.
2) Pass a pointer to the external declaration. For this:
void InsertInteger(union LCD_BUF * val) {
Note the '*', which says thatthis value is a 'pointer to' a value of this type.
Call this with:
InsertInteger(&disp1);
Note the '&', which means pass the address of this.
Then in the function, use:
val->icons
Note that unions, and structures are identical in their syntax here, both allowing the -> shortcut to access a member,rather than having to use the * to 'dereference' the pointer.
A union, is actually a type of structure in C, which has two (or more) different sets of names, referencing the same data.
Andrew-miksys
PostPosted: Wed Oct 03, 2007 9:03 am     Reply with quote
Thanks!
I tested it berofe but forgot of -> operator Embarassed
It works of course.
