RS-485 woes.....
Goto page 1, 2  Next
RS-485 woes.....
PostPosted: Fri Sep 28, 2007 12:36 pm     Reply with quote
Hi All,
I am developing a device that will communicate with other hardware using either RS-232 or RS-485. So far all of my development has been done using RS-232 and a PC, and everything has worked as expected. Now, I'm trying to validate the RS-485 communications, and things aren't going so well.... The development prototype has both a MAX232 type device, and an SN75176, as well as a pair of jumpers to switch the TxD and RXD lines on the PIC between these devices.
I have a very simple program that illustrates the "odd" behavior that I am seeing:
#include <16F628.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOLVP, BROWNOUT
#define Rx_In PIN_B1         // serial data receive pin
#define Tx_Out PIN_B2         // serial data transmit pin
#define Serial_Enable PIN_A7   // Serial data enable
//-----< Serial Port Definition >-----
#use rs232(baud=9600, xmit=Tx_Out, rcv=Rx_In, enable = Serial_Enable, ERRORS, stream = Network)
   while(1){
      fputc('1', Network);
      fputc('2', Network);
      fprintf(Network, "\r\nHello World!\r\n");
When this code is run in "RS-232 mode" I see this on the Hyperterminal screen:
Hello World!
12
Hello World!
12
Hello World!
When this code is run in "RS-485 mode" I see this on the Hyperterminal screen:
121212121212121212
As you can see, something is happening to prevent the fprintf statement from working properly when in RS-485 mode....... The fputc funtion works perfectly, but the fprintf does not Sad !
Perhaps my selection of RA7 as the enable control for the RS-485 chip is the problem? Nothing in the datasheet seems to suggest it would be a bad choice, however!
I'm doing this development on a custom prototype board using v3.249 of the CCS compiler.
Anyone see what I might be doing wrong??
Thanks,
Charlie
PostPosted: Fri Sep 28, 2007 3:16 pm     Reply with quote
I think there's a bug. As a work-around, you could re-direct the output
of printf (not fprintf) to a routine that calls fputc(). Since fputc() works,
this should fix the problem. Example:
#include <16F628.h>
#use rs232(baud=9600, xmit=Tx_Out, rcv=Rx_In, enable=Serial_Enable, ERRORS, stream=Network)
void Network_fputc(char c)
fputc(c, Network);
   while(1){
      printf(Network_fputc, "\r\nHello World!\r\n");
PostPosted: Fri Sep 28, 2007 3:45 pm     Reply with quote
Hi PCM,
Yeah, that worked - thanks!! I wish I thought of it!!
By, 'bug', I assume you mean a bug in the fprintf function in v3.249??
Hmmm, maybe this will prompt me to (finally) give the v4 compiler a try!
Thanks,
Charlie
PostPosted: Fri Sep 28, 2007 3:51 pm     Reply with quote
It appears to be fixed in vs. 4.056. Here's the ASM code. Notice
that fprintf() now calls the same routine as the fputc() lines do.
..............       fputc('1', Network);
005C:  MOVLW  31
005D:  MOVWF  22
005E:  CALL   02E
..............       fputc('2', Network);
005F:  MOVLW  32
0060:  MOVWF  22
0061:  CALL   02E
..............       fprintf(Network, "\r\nHello World!\r\n");
0062:  CLRF   21
0063:  MOVF   21,W
0064:  CALL   004   // Get char from const string
0065:  INCF   21,F
0066:  MOVWF  77
0067:  MOVWF  22
0068:  CALL   02E  // Call fputc() routine
0069:  MOVLW  10
006A:  SUBWF  21,W
006B:  BTFSS  03.2
006C:  GOTO   063
PostPosted: Tue Oct 02, 2007 10:36 am     Reply with quote
Hi all.
OK, I've moved beyond the fprintf issue with a work-around, but now I'm encountering a problem with my INT_RDA interrupt handler in RS-485 mode. Again, my hardware and code work flawlessly when I am communicating with a PC via RS-232, but when I switch over to RS-485, things fall apart quite quickly...... Basically, in RS-485 mode, the interrupt handler is firing continuously, and nothing else is being executed. I suspect that the ENABLE logic that is supposed to control the direction of the RS-485 data has a bug in v3.249??
Can anyone confirm this? If it is a bug, has it been fixed?
Charlie
treitmey
PostPosted: Tue Oct 02, 2007 11:07 am     Reply with quote
No, enable works ok in 3.249
Neutone
PostPosted: Tue Oct 02, 2007 11:13 am     Reply with quote
Anonymous wrote:
Hi all.
Charlie
What is the voltage level on the PIC RX? If it is not high it will fire interrupts continuously.
treitmey
PostPosted: Tue Oct 02, 2007 11:26 am     Reply with quote
perhaps he needs bias resistors
http://www.ni.com/support/serial/resinfo.htm
Storic
PostPosted: Tue Oct 02, 2007 4:18 pm     Reply with quote
another doc that may be of intrest with RS485
www.bb-europe.com/bb-euro/literature/485appnote.pdf
What has been learnt if you make the same mistake? Wink
PostPosted: Thu Oct 04, 2007 12:10 pm     Reply with quote
Hi All,
My RS-485 receive problem can be illustrated quite clearly with the EX_SISR.C example program. When my prototype board is in RS-232 mode, the program works flawlessly, but when it is in RS-485 mode, it does not. The problem appears to be caused by the serial receive ISR being triggered by the transmission of any characters. That is, Tx data from the PIC seems to be triggering the Rx ISR. This is only a problem in RS-485 mode. For the record, I do have the ability to "terminate" and "bias" the RS-485 connection, but this doesn't have any effect. My RS-485 hardware configuration is exactly the same one that I have used successfully in other hardware designs, so I don't think this is a hardware issue??
I've tried compililing with v3.249 and v4.050, with the same result.
Any thoughts?
Charlie
treitmey
PostPosted: Thu Oct 04, 2007 1:40 pm     Reply with quote
Ahhh.....
In my TX isr I turn off RX so I don't see that data.
TX and RX are sharing the same 2 wires(right??)
note :CREN
//=======================TXisr============================//
//Takes data from buffer and puts it into a TX stream (RS485)
//uses interrupts to empty buffer at proper rate
#INT_TBE
void TXisr(void)
  CREN = 0;//CREN: Continuous Receive Enable bit=0 ie: no RX
  idle_bus=FALSE;
  fputc(TX_BUF[tx_indx_o],RS485);
  tx_indx_o++;      //not used//tx_indx_o &= TXMASK;
  if(tx_indx_o==tx_indx_i)
    disable_interrupts(INT_TBE);//Done TXing turn on RX again
    CREN = 1;//CREN: Continuous Receive Enable bit=1 ie: RX enabled
PostPosted: Thu Oct 04, 2007 2:29 pm     Reply with quote
Hi treitmey,
Thanks for the reply!
I'm sure it works, but I wonder if your technique is strictly necessary? The SN75176 is a two-line (RxD and TxD) to differential bus tranceiver. The IC has an internal Tx driver and Rx receiver, each with an enable line. One is active-high and the other is active-low, so that when tied together they act like a "direction" control. This direction control line is connected to the PIC pin specified in the #use rs232 directive as ENABLE. This is supposed to control the flow of data to/from the RS-485 bus without conflicts.
I've done this before with no problems using earlier compiler versions, but I can't seem to get it to work now!
Thanks,
Charlie
treitmey
PostPosted: Thu Oct 04, 2007 3:04 pm     Reply with quote
I think this may be used as a bus contention trick.
So you read what you transmit and check it against the buffer.
If another device is in contention, the RX data would be garbled.
just a thought.
also see something like it in the drivers/rs485.c
inside
int1 rs485_send_message(int8 to, int8 len, int8* data)
there is a
RCV_OFF();
and then
RCV_ON();
perhaps you could use this known good code?
ThomasC
PostPosted: Tue Feb 05, 2008 8:46 am     Reply with quote
#include <16F628.h>
fputc(c, Network);
   while(1){
I'm getting output here to Comm Operator (hyperterminal like program) I'm getting:
9D 9B E5 EB 6F 35 27 27 21 BF 51 21 1B 27 37 BD E5 EB (HEX)
I'm running:
PIC16F690 / PCM 4.060 / ICD2 / MAX485 / Telebyte Model 245 Superverter (RS485 to RS232 converter)
I do not understand why it comes out differently.
I notice that the value changes when the frequency is increased. Why does it do that?
Sorry to hijack this thread. Thanks!
treitmey
PostPosted: Tue Feb 05, 2008 9:15 am     Reply with quote
A 16F628 has a hardware USART on B1 and B2.
A 16F690 does not. A software implementation will be built.
Try starting a new thread with your new questions/problems.
Goto page 1, 2  Next
Page 1 of 2
