Hex File in wrong place
qwerty2002
PostPosted: Sun Sep 30, 2007 2:00 am     Reply with quote
I have a bootloader PICDEM FS USB demo board that has the 18F4550. This bootloader requires that user code range from 800h to 7FFFh. The other parts are for EEPROM and other things. Can someone check my hex file i.e. import into MPLAB to make sure its right. I used the ORG statement to start my code at 7000h. I have a feeling its not in the right spot because my program does not work.
Does anyone have a bootloader like mine?
qwerty2002
PostPosted: Sun Sep 30, 2007 2:03 am     Reply with quote
http://rapidshare.com/files/59238200/18F2550_USB_HID_CRC_Oscilloscope.hex.html
Here is the link to the hex file.
PostPosted: Sun Sep 30, 2007 2:30 am     Reply with quote
If the user code needs to start at 800, then you need to use the _build_ statement, to put the boot vector at this address, and an ORG statement to put the main code up there as well. If the start is 800, why on earth use an ORG of 7000.....
PostPosted: Sun Sep 30, 2007 8:49 pm     Reply with quote
I just used 7000 just cause. I was getting an error saying invalid ORG range, so I was just picking random numbers?
qwerty2002
PostPosted: Sun Sep 30, 2007 9:24 pm     Reply with quote
#build(memory=0x7000:0x7FFF)
#build(reset=0x800:0x807, interrupt=0x808:0x8A6)
Does this look good? I left out the ORG I don't think its doing anything.
PostPosted: Mon Oct 01, 2007 1:34 am     Reply with quote
The memory directive is only used when you have external memory chips. And I would remove the end addresses for the reset and interrupt vectors, this makes life easier on you.
Also make sure you have in the beginning of your program a #org statement telling the compiler to reserve the memory up to 0x800 for the bootloader.
#build(reset=0x800, interrupt=0x808)
#org 0, 0x800 {}
qwerty2002
PostPosted: Mon Oct 01, 2007 12:17 pm     Reply with quote
Thanks alot.
Could someone check out my hex file? I think its starting where the bootloader code is, even though I have a ORG statement.
#ORG 0x08A9,0x3000 {}
http://rapidshare.com/files/59568343/18F2550_USB_HID_CRC_Oscilloscope.hex.html
PostPosted: Mon Oct 01, 2007 3:50 pm     Reply with quote
Please read the manual. Here you are telling the compiler _not_ to use the memory from 0x08A9 to 0x3000, just the opposite of what you want to achieve.
Have you tried my code? Did that work?
qwerty2002
PostPosted: Mon Oct 01, 2007 6:52 pm     Reply with quote
Thank you so much. I did read the CCS manual and I was misinterpreting it. I thought that the memory address in ORG was for the code. I.E. saying in this segment don't allow the bootloader code.
I got it now!!!
It does work!!!
PostPosted: Tue Oct 02, 2007 1:36 am     Reply with quote
Your initial assumption was right, with the ORG statement you do reserve a memory region for program code, but the addition of '{}' changes the ORG statement to reserve an empty region.
Happy to hear you have it working now.
