How to use timer2 to blinking led7 whenever push a button
phithuc
PostPosted: Sat Sep 29, 2007 2:09 am     Reply with quote
Question
Hi all!
I'm using 16F877A. I write a program to blink led7 when push a button . I use timer2 with set up:
void Init_Timer(void)
setup_timer_2(T2_DIV_BY_4, 250, 1);
and isr as the following:
void timer2_isr(void)
Flag=~Flag;
and in scan routine I write:
Switch (ModeValue)
case 1:
clear_interrupt(INT_Timer2);
output_high(PIN_E0);
SetHour();
ds1307_set_date_time(day,mth,yr,dow,hr,min,sec);
Init_Timer();
if(Flag==true)
if(level==0) level=1;
Progam runs, led blinking. but sometime led7 don't lighten when I push button. Please help me how to drive a interrupt, stop it whenever I want. Thanks!!
Humberto
PostPosted: Sat Sep 29, 2007 2:47 pm     Reply with quote
In this forum it is not necessary to be a member to post a question related to CCS
C Compiler oriented to PIC MCU´s, also it is not mandatory to login, but to start a new
thread we expect you follows some basic rules.
Nobody likes to read C code in the way you posted, this one can be one of the reasons
why nobody answered you.
You will find some guide here:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
http://www.ccsinfo.com/forum/viewtopic.php?t=29483
Then post your question accordingly.
Humberto
