How to detect input - output signal
Goto page 1, 2  Next
sonix
PostPosted: Thu Sep 27, 2007 3:18 am     Reply with quote
I have one signal that is "almost" like to square wave.
What i want to do is to detect when the signal is high and when low.
How to make this ?
PostPosted: Thu Sep 27, 2007 3:19 am     Reply with quote
forget to say that this signal last cca 1 second and the speed is 9600 b/s.
inservi
PostPosted: Thu Sep 27, 2007 5:23 am     Reply with quote
Can you give us the electrique voltage for low and high levels ?
dro.
in médio virtus
tom_hanks
PostPosted: Thu Sep 27, 2007 9:31 am     Reply with quote
Assign this signal to interrupt pin...
use a timer according to the speed of the signal....
so when ever signal transit from high to low, ISR will set the flag to low....
1. with the help of while loop in main....you can reset the flag on going high...
2. or use a timer
Humberto
PostPosted: Thu Sep 27, 2007 1:38 pm     Reply with quote
It seems that you really are needing is to decode a data packet.
1) Are you able to freeze a frame with a scope?
2) If so, could you tell us the pulses amplitude?
3) And the width and level of the shortest pulses?
Humberto
sonix
PostPosted: Fri Sep 28, 2007 3:20 am     Reply with quote
1.) Can you give us the electrique voltage for low and high levels
- low level is 3.5 and high 4V.
2) Are you able to freeze a frame with a scope?
- the frame looks almost like "answer to select (ATS)" signal in chip cards and it contains the same bytes (long byte, checksum bytes etc.)
inservi
PostPosted: Fri Sep 28, 2007 4:21 am     Reply with quote
Most of the PIC (and probably all) have TTL/CMOS input as standard.
Have a look there : http://www.interfacebus.com/voltage_threshold.html
The treshold voltage is 1.5V then with low and high level between 3.5 and 4v, you can not detect the changing level in TTL mode. Some PIC have Triggered input with a different treshold level.
So there are two solutions one without hardware signal formating/adapting and one with hardware signal formating/adapting.
I can propose 2 solutions:
1 - Without hardware signal formating/adapting:
Use A/D converter if the converter is fast enough for you signal.
9600b/s require at least 9600 conversion by seconds (the double or triple
is probably more resonable) Ok, 30 000 / sec = 33µ sec/sampling.
That look to be difficult with a 16f877. but other PIC are quickest.
The A/D conversion look to be possible with the right PIC !
2 - With hardware signal formating/adapting :
use small electronic circuit for change level in the correct TTL range . That can be achieved with 3 resistors and one transistor ( and maybe only two resistors as voltage divider ).
I'm sure that some one can send a circuit sample for that. For me, it's a few haggling for find the right resistors value.
Personally, i prefer the second solution !
When the PIC can detect the electrical levels, you can start with software side.
Best regards,
dro.
in médio virtus
tom_hanks
PostPosted: Fri Sep 28, 2007 6:03 am     Reply with quote
use a opamp in comparator mode...
for 3.5 v it should give u low voltage
and for high 4v it shoudl give u high logic at the output...
LMC7101 is best for this type of application
SherpaDoug
PostPosted: Fri Sep 28, 2007 7:15 am     Reply with quote
How about a PIC like the 16F630 which has a built in comparator and reference voltage generator? I have never used it but a quick look at the datasheet seems promising.
Humberto
PostPosted: Fri Sep 28, 2007 8:03 am     Reply with quote
Lets assume that the signal levels you are reading are out of TTL levels, unless you
are reading a signal like RS485.
1) From what device the signal is coming from?
2) How many wires are carrying such signals?
3) How did you determine the 9600 b/s speed.
4) Tell us the minimum measured width.
Humberto
inservi
PostPosted: Fri Sep 28, 2007 8:32 am     Reply with quote
SherpaDoug, you are right, that look to be a very good solution !
As How about a PIC like the 16F630 which has a built in comparator and reference voltage generator? I have never used it but a quick look at the datasheet seems promising.
dro.
in médio virtus
Alanis
PostPosted: Fri Sep 28, 2007 9:09 am     Reply with quote
- from embedded system based on prepaid cards.
- one input - output
- protocol. It could be 9600 or 19200. But 9600 used as test.
- 2,2V
Humberto
PostPosted: Fri Sep 28, 2007 12:09 pm     Reply with quote
I can´t figure what do you mean
1 wire (bidirectional input/output) + Reference?
2 wires (1 Input + 1 output?)
3 wires (1 Input + 1 Output + Ref)
I mean, the shortest pulse time duration (in usec) that you can see or measure in the frame.
For 9600 bauds, the minimum width you will found should be 104usec and all other
wider pulses should be multiples of these.
What is the reference level used when you did the measurements?
Humberto
Alanis
PostPosted: Sat Sep 29, 2007 3:00 am     Reply with quote
- thats the one.
- if i use freq of 3,5 MHZ the puls is cca 110 uS.
- if i use 5 MHz the puls is cca 82 us
Basically, its defined in ISO/IEC 7816-3 standard.
Is this what you mean ?
Humberto
PostPosted: Sat Sep 29, 2007 7:40 am     Reply with quote
Did you found THAT ISO Standard trying to respond my previous comments? Cool
ISO 7816-3 refer to Electronic Signals and Transmission Protocols for Smart Cards.
If you are trying to read a Smart Card (ISO 7816), simple answer: you can´t.
Unless you have enough skills/tools/knowledge to decipher complex cryptographic
algoritms, cryptogrphic protocols or both.
If you want to play with a Smart Card, you will find good info in some AN in the Microchip site.
If you want useful technical data you will find it in this link:
http://www.cardwerk.com/smartcards/smartcard_standard_ISO7816-3.aspx
Humberto
Goto page 1, 2  Next
Page 1 of 2
